| This is a discussion on Man Based Global Warming.... within the Environmental Discussion forums, part of the PriusChat Forums category; Originally Posted by F8L Tim, I don't think you can treat a short period of temperature stagnation or even a ... |
| LinkBack (5) | Thread Tools |
| | #1001 | |
| Senior Member Join Date: Sep 2005 Location: WA
My Car: 2005 Prius Model: Package: #5 Thanks: 13
In any case, I agree that a temperature dip for a few years does not disprove AGW. However, one really has to reconsider the impact of CO2 when a 50 year span produces no net warming. But the real climate "litmus test" is probably better assessed using ocean heat content. There is a nice discussion here, on Pielke's website: "...Ocean heat touches on the very core of the AGW hypothesis: When all is said and done, if the climate system is not accumulating heat, the hypothesis is invalid. Writing in 2005, Hansen, Willis, Schmidt et al. suggested that GISS model projections had been verified by a solid decade of increasing ocean heat (1993 to 2003). This was regarded as further confirmation the IPCC’s AGW hypothesis. Their expectation was that the earth’s climate system would continue accumulating heat more or less monotonically. Now that heat accumulation has stopped (and perhaps even reversed), the tables have turned. The same criteria used to support their hypothesis, is now being used to falsify it. It is evident that the AGW hypothesis, as it now stands, is either false or fundamentally inadequate. One may argue that projections for global warming are measured in decades rather than months or years, so not enough time has elapsed to falsify this hypothesis. This would be true if it were not for the enormous deficit of heat we have observed. In other words, no matter how much time has elapsed, if a projection misses its target by such a large magnitude (6x to 8x), we can safely assume that it is either false or seriously flawed." As Pielke notes here: "Thus, according to the GISS model predictions, there should be approximately 5.88 * 10**22 Joules more heat in the upper 700 meters of the global ocean at the end of 2008 than were present at the beginning of 2003. For the observations to come into agreement with the GISS model prediction by the end of 2012, for example, there would have to be an accumulation 9.8 * 10** 22 Joules of heat over just the next four years. This requires a heating rate over the next 4 years into the upper 700 meters of the ocean of 2.45 * 10**22 Joules per year, which corresponds to a radiative imbalance of ~1.50 Watts per square meter. This rate of heating would have to be about 2 1/2 times higher than the 0.60 Watts per meter squared that Jim Hansen reported for the period 1993 to 2003." Last edited by TimBikes; 05-11-2009 at 03:29 AM. | |
| | #1002 | |
| Senior Member Join Date: Apr 2006 Location: Victoria, BC
My Car: 2004 Prius Model: Package: B Thanks: 97
Friends: 1 | Quote:
More importantly, there is no way you need to poll more than 50 percent of a population to get an accurate result. Give us a break. | |
| | #1003 | |
Friends: 1 | Quote:
My personal gauge is the real expert consensus, and for me that's the IPCC. But because the IPCC reports are somewhat dated and conservative, I have no problem supplementing them with news from major outlets like the CBC - which report on recently published studies from journals like Science and Nature. So why do I say you are a liar? Because, within every AGW thread that you have participated in, you've repeatedly demonstrated disdain for the big-picture conclusions of the climatologist community. You discount clear evidence that GW is happening now and you try to spread doubt about the seriousness of the damage it will cause in the future. That is total dishonesty at the core - completely shameful and irresponsible. This is not a simple intellectual debate with no serious consequences for the future. This is not just an academic exercise for your entertainment. 100s of millions of real people are going to suffer needlessly unless we take bold steps and yet you think it's more important to win this little game of distract and deny. Grow a conscience and stop trying to manipulate selective bits of data to suite your big picture agenda of dishonesty and irresponsibility. | |
| | #1004 | |
On your second point, I suppose I am lying about n=516, right? Of course, I just pulled the # out of my a$$, right? You need 516 to represent a sample of 1,000 at 95% confidence with a margin of error of +/- 3%. This does not mean you need to sample 516,000 to represent a population of 1 million. It doesn't work that way Fibber. See the sample size calculator here if you don't believe me. Last edited by TimBikes; 05-11-2009 at 04:14 PM. | |
| | #1005 | |
On point two, should science simply ignore the fact that the climate system - in contradiction to AGW models - is no longer accumulating heat? As the ocean heat content calculations demonstrate, "It is evident that the AGW hypothesis, as it now stands, is either false or fundamentally inadequate." Don't you think it is important for science to understand this, even if it doesn't fit neatly into the AGW narrative? Last edited by TimBikes; 05-11-2009 at 04:01 PM. | |
| | #1006 |
| Senior Member Join Date: Aug 2008 Location: Texas
My Car: 2009 Prius Model: Package: #2 Thanks: 8
Friends: 1 | http://www.climateaudit.org/pdf/ohioshort.pdf This is 45 pages long. (1 mb in this format) It is an explication of the history of what happened when someone completely outside climate science decided to look at the famous Mann et. al. 'hockey stick' used to jump start the whole global warming 'debate'. The scientists (who claim to have superior knowledge in their area of expertise) come off looking rather petty, vindictive, uncooperative, well, generally unscientific. It is no accident that the statistician with that initial curiosity authors one of the best science blogs on the internet ( climateaudit.org )and quite regularly embarrasses the so-called experts at realclimate.org. If you are not frightened of a truthful look at what transpired(s), have a gander. |
| | #1007 | |
| | #1008 | ||
Friends: 1 | Quote:
It also shows that to accurately sample a population of 10,200 you need only 966 respondents. Well since the authors got 3146 respondents, they did pretty well then. A good poll. Quote:
| | #1009 | |
Friends: 1 | Quote:
| | #1010 | |
In any case, as I mentioned previously and as you well know, the veracity of AGW will not be determined by a poll. But I don't doubt that a majority of climate scientists believe CO2 will have an effect on climate (as do I). The heart of the matter to me is will that effect be minimal or catastrophic. Based on the evidence, I judge it will be the former. But am open to evidence, beyond inadequate models, that would demonstrate it is the latter. Last edited by TimBikes; 05-11-2009 at 05:50 PM. | |
| based, global, man, warming |
LinkBack to this Thread: http://priuschat.com/forums/environmental-discussion/56792-man-based-global-warming.html | ||||
| How the global warming industry is based on one MASSIVE lie – Telegraph Blogs | This thread | Refback | 10-02-2009 09:10 AM | |
| TheEEStory.com: Forbes magazine: "Why Do We Worship the Electric Car?" | This thread | Refback | 08-12-2009 01:10 AM | |
| TheEEStory.com: oil now at 71.56 - peak oil believers? | This thread | Refback | 08-05-2009 12:51 AM | |
| Hybrid Cars Global Warming, Hybrid Cars Impact On Future, Hybrid Cars Can Use Any Type Of Fuel - Ridleyfield | This thread | Refback | 03-10-2009 07:13 AM | |
| RealClimate | This thread | Refback | 02-07-2009 10:35 AM | |
| "Why Americans are Skeptical of Their Role in Global Warming" (aka Global Climate Disruption) | Mirza | Fred's House of Pancakes | 56 | 05-22-2009 08:07 PM |
| More on Global Warming... | TimBikes | Fred's House of Pancakes | 8 | 11-11-2007 12:22 PM |
| Global warming | imntacrook | Fred's House of Pancakes | 12 | 04-12-2007 01:42 PM |
| High court to hear global warming case-Must Bush Change Course on Global Warming | hb06 | Environmental Discussion | 17 | 12-21-2006 02:34 PM |
| Global Warming | DaveinOlyWA | Environmental Discussion | 2 | 10-26-2004 05:13 PM |
