This is a discussion on Aussies believe in global warming... within the Environmental Discussion forums, part of the PriusChat Forums category; Originally Posted by patsparks Yep, knew all that, I used to repair air conditioners. I meant use water as the ...
Old 04-29-2009, 12:32 PM   #61
jayman
Default Re: Aussies believe in global warming...
Originally Posted by patsparks View Post
Yep, knew all that, I used to repair air conditioners. I meant use water as the refrigerant in a vacuum on the low pressure side. I'm guessing it would cause cavitation and corrosion.
The water may freeze, causing problems with piping. The biggest concern is as you stated, corrosion. For chiller assemblies and cooling towers on rooftops of commercial buildings, you have to monkey around with a lot of different chemicals to minimise corrosion
Nu-Calgon: Products: Cooling Tower Water Treatment
Probably not much demand for central boiler systems where you live, but they're literally a life-and-death deal here. You will experience scale, rust, and nasty corrosion of expensive boiler parts unless proper chemicals are treated in
Nu-Calgon: Products: Boiler & Closed System Water Treatment
Perhaps the biggest drawback to using plain old water is efficiency. The dedicated refrigerants are *much* better thermal efficiency. Eg, even in the chemical industry, for heat exchangers they will use a process working fluid instead of water, to minimise corrosion and increase efficiency
http://www.dynalene.com/pdf/DySF.5.2.07.pdf
jayman is offline
Old 04-29-2009, 12:40 PM   #62
jayman
Here is a picture of my brother at work, well he is most likely ordering a pizza for dinner but it looks like a business call.
A nice clean shiny control room. The photo resolution isn't very high though. Is that a Siemens Simatic PCS7 or an Emerson PlantWeb control system he is using??
Shhhhh! don't tell anyone, that's also Bev's husband.
Looks like the Sparks Brothers have good luck with finding women!
jayman is offline
Old 04-29-2009, 12:42 PM   #63
jayman
Originally Posted by DaveinOlyWA View Post
OK Jay, please dont hammer me on terminology!!
Ok, I won't
Though I may tease you just a little bit ...
Seriously, I agree with most of your rant
jayman is offline
Old 04-29-2009, 12:43 PM   #64
jayman
Originally Posted by bevspark View Post
He is my own Homer Simpson, he's an environmentalist isn't he?
Yes, I can see the Sparks Brothers have had good luck with their women ... some guys have *all* the luck
jayman is offline
Old 04-29-2009, 10:09 PM   #65
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
Default .
...In the case of an Alkali plant, the recycle water is generally used in other parts of the plant...A brand new plant, a very effective arguement could be made for having different applications - say irrigation - for the water assuming it isn't contaminated with heavy metals...
Sounds better to 'remove the water' before the limestone is added to the mix. Assuming a relatively unpolluted source of seawater, would heavy metals and other contaminants still be a problem? How about a 'first stage' process with only seawater and sunshine as the inputs? It could produce clean water, and provide brine as an input to the rest of the alkili production. This could be part of a new plant, or a replacement for the evaporation ponds of an older one. A smaller scale version might be useful in the third world, or anywhere else the water would be the most valuable commodity.
My other high mileage, low emission vehicles are my bicycles and my shoes.
hyo silver is offline
Old 04-30-2009, 01:59 PM   #66
jayman
Default Re: .
If you do that, the chemical reaction will no longer work
The problem isn't the water, it's the feedstock source. Limestone sources in North America can have ferrugenous mercury, sometimes in very high concentrations. I'm unsure if Australia has this issue, perhaps Pat or another Aussie can chime in
The cement industry recognizes that mercury emissions from lime kilns are a problem.
EPA urged to control mercury from cement kilns
Surprisingly, most folks are completely unaware that mercury can be present in limestone
Although that probably wouldn't meet the demands of a modern Alkali facility, it would certainly require much less thermal energy input. In the third world scenario, this process would absolutely work, although potable water output would be modest by current standards
jayman is offline
Old 05-06-2009, 03:52 PM   #67
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
Default Re: .
If you do that, the chemical reaction will no longer work...
But if the aim is to produce water and electricity...
...Although that probably wouldn't meet the demands of a modern Alkali facility, it would certainly require much less thermal energy input. In the third world scenario, this process would absolutely work, although potable water output would be modest by current standards
My original intent was to learn about producing water, and perhaps electricity, from seawater and sunshine. Asking about the usability of the leftover salt, I've learned something about the Alkili industry. Enough, I think, to conclude that the two aims really aren't all that compatible.
The third world scenario seems closest to what I was thinking. Something robust that will work in remote areas with minimal intervention, to provide people with clean water and some electricity where there is none.
Old 05-06-2009, 05:59 PM   #68
jayman
Oh, gotcha. Guess I went a wee bit off topic
jayman is offline
aussies, global, warming
"Why Americans are Skeptical of Their Role in Global Warming" (aka Global Climate Disruption) Mirza Fred's House of Pancakes 56 05-22-2009 08:07 PM
Global warming imntacrook Fred's House of Pancakes 12 04-12-2007 01:42 PM
Global Warming Mary Snyder Environmental Discussion 1 01-02-2007 05:30 PM
High court to hear global warming case-Must Bush Change Course on Global Warming hb06 Environmental Discussion 17 12-21-2006 02:34 PM
Cause of Global Warming dragonfly Environmental Discussion 32 08-25-2006 11:10 AM
