This is a discussion on Solar Shallow Well Pump within the Environmental Discussion forums, part of the PriusChat Forums category; Here on the coastal plain the soil conditions and water table make shallow well pumps possible. I have a shallow ...
Old 07-18-2009, 06:59 PM   #1
CarolinaJim
CarolinaJim's Avatar
Default Solar Shallow Well Pump
Here on the coastal plain the soil conditions and water table make shallow well pumps possible. I have a shallow well in my backyard which I use to water my garden.
Until recently I used a pitcher pump and elbow grease to pump water. Yes I have pumped thousands of gallons of water by hand.
Not any more. My dad put together a very simple shallow well pump which uses a 45 watt solar planel, 65 watt DC water pump with a 23' lift capability and bits and pieces of plumbing paraphanalia.
Copying his design I installed a simple solar shallow well pump last week. I absolutely love it...so does my arm! I keep my gardens watered, my little dragonfly pond topped off and it is a great conversation piece.
I put together a non commercial flash slideshow/video of the pump. Maybe some of you could use a system like this to pump from a shallow well, pond, river or use it to aereate a pond.
Here is the link to the video. http://www.redbayfarm.com/files/solarwaterpump.swf
Jim
www.redbayfarm.com - a website about a little 46 acre family owned tree farm
Become Carbon Neutral - Buy land and plant trees
CarolinaJim is offline
The Following User Says Thank You to CarolinaJim For This Useful Post:
dogfriend (07-19-2009)
Old 07-19-2009, 07:01 PM   #2
icarus
Default Re: Solar Shallow Well Pump
FYI,
Solar Water Pumping - Solar Electric Power Discussion Forum by Northern Arizona Wind & Sun
Whole long list of thread and information on solar water pumping.
T
icarus is offline
Old 07-19-2009, 10:05 PM   #3
CarolinaJim
Originally Posted by icarus View Post
FYI,
T
Thanks for the link!
pump, shallow, solar
ABS pump replace, does bleeding the brake lines get rid of air that might be in the abs pump? john1 Gen II Prius Care, Maintenance and Troubleshooting 5 10-08-2009 12:22 PM
"most hybrid-worshippers are vain and shallow"? zenMachine Gen II Prius Main Forum 12 10-13-2007 11:56 AM
Thin Film Solar Panel (Rollable Solar Powered Battery Chargers) JeffElectric Gen II Prius Technical Discussion 5 03-09-2007 05:15 PM
Removal of very shallow clearcoat scratch? DaveG Gen II Prius Care, Maintenance and Troubleshooting 5 03-28-2004 09:08 PM
