| This is a discussion on ULSD impact on backup generators within the Environmental Discussion forums, part of the PriusChat Forums category; Originally Posted by Shawn Clark The one part of the U.S. that has not experienced this recession or even the ... |
| | #11 | |||||
My Car: 2004 Prius Model: Package: B Thanks: 89
Friends: 14 | Quote:
There is nothing wrong with a 30-50 year old prime mover, assuming it has been properly maintained. Indeed, a lot of the older prime movers, such as Nordberg and Vivian, were over-engineered and over-built to a level that modern folks would find astounding The Nordberg V-20's and the Radial 10's were used as prime power in applications that demanded absolute reliability. They were finally scrapped - in some cases 60 years after installation - not because they were broken or worn out, but because they could no longer meet emissions They didn't really understand the impact of emissions back then. The Prime Movers +50 years old, were designed to run 24x7 for years, even decades, with only routine maintenance. Quote:
Some of the additives, such as those from PRI, are very good and I highly recommend them. For stationary applications, such as emergency gensets, the biggest problem is diesel getting old and having biological growth By "exercising" the genset - preferably 20 mins once a week - you may prevent sludge and biologic growth in the prime mover and day tanks, but the primary tanks and piping may still have problems. I've seen inline strainers for primary tanks, where the fuel was probably 10 years old, that were plugged solid with a gooey muck The additives can help, if they are proven additives. The Military also specifies a very short list of approved additives that work. The problem is when a well meaning client just pours any old snake oil into the primary tanks, and/or day tanks. They can cause a lot more trouble than they solve No doubt!
__________________ 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion | |||||
| | #12 |
| Senior Member Join Date: Feb 2006 Location: eastern Pennsylvania
My Car: Other Non-Hybrid Model: Package: N/A Thanks: 3
Friends: 1 | Seeing as how this is an off road use, couldn't they use no. 2 heating oil for fuel, or is that too much sulphur? |
| | #13 |
Friends: 14 | Heating fuel and diesel fuel have somewhat different properties. Although an older diesel engine with an inline/plunger style injection pump will run on it, there are better choices For example, the US Military has a general recommendation of using jet fuel, JP-8, for everything, including diesel powered equipment. This is a good idea logistically, but JP-8 can be quite hard on modern common rail fuel injection |
| | #14 |
| Senior Member Join Date: Feb 2009
My Car: 2009 Prius Model: Package: #4 Thanks: 67
Friends: 0 | I completely agree that it's unfair for these facilities. But there are larger issues at stake here and that is why ULSD is the future with no going back. How Air Pollution Can Damage the Heart - TIME http://www.energy.wsu.edu/documents/...ltefilters.pdf "DOE found that DPFs cease to reduce PM emissions with fuels containing 150 ppm sulfur and become a source of PM emissions with 350 ppm sulfur fuels. Overall, baseline PM emissions increased as the fuel sulfur level increases. At 3 ppm sulfur both devices reduced PM emissions by 95 percent, and at 30 ppm sulfur the PM reduction efficiencies of both devices dropped to the around 72 percent." |
| backup, generators, impact, ulsd |
| Losers and noise generators | bwilson4web | Gen II Prius Main Forum | 15 | 05-11-2009 10:46 PM |
| Impact of hybrids | Dispie | Gen II Prius Main Forum | 2 | 05-04-2009 12:34 AM |
| High-Efficiency Generators for Hybrid Vehicles | Wiyosaya | Prius and Hybrid News | 12 | 10-21-2008 08:20 AM |
| AC impact on MPG | ghopper01 | Gen II Prius Fuel Economy | 15 | 08-22-2007 01:10 AM |
| NG Emergency Generators | randreed | Environmental Discussion | 4 | 10-17-2006 11:32 AM |
