| This is a discussion on Smoke Alarm Battery Dies: Throw it out? within the Environmental Discussion forums, part of the PriusChat Forums category; Originally Posted by jayman I'm going to have to have a word with you about how you've raised your cat ... |
| | #21 |
Friends: 10 | |
| | #22 |
Friends: 12 | |
| | #23 |
My Car: 2007 Prius Model: Package: #6 Thanks: 288
Friends: 11 | |
| | #24 |
Friends: 12 | If you cook, clean, and keep an eye on the house while I'm away at work .... I might think about it But no frilly French Maid outfits, or Man Boobs either. I'm not a prude, but that is where I draw the line |
| | #25 | ||
Friends: 11 | Quote:
I do have a household tip though: Folding Fitted Sheets 1. Wait until your spouse/partner/friend with benefits has left the house. This will allow you to concentrate on the task with undivided attention. 2. Fold pillowcases first, then the top (flat) sheet and then finally the bottom (fitted) sheet. This allows you to fold the easier sheets first and build confidence. 3. After folding and neatly stacking the pillowcases and top sheet, pick up the bottom sheet and find the seam in each corner. Place your hand inside the corner and match the corners to each other until you have all four corners gathered together. 4. Wad the whole thing up into a ball and shove it into the back part of the closet where it won't be obvious. Stack the top sheet on top to keep your spouse from finding it. Go about your day. | ||
| | #26 |
Friends: 12 | Um ... you have to *fold* fitted sheets before you put them away??? I guess that's why mine are so wrinkly ... |
| | #27 | |
There are people who can do this; otherwise when you bought a new set of sheets, they would come in a wad in the package. | |
| | #28 |
Friends: 12 | I figure if fitted sheets had to be neatly folded after coming out of the dryer, they would just fold themselves |
| | #29 |
Friends: 10 | Better to have fitted sheets than shitted feets. Tom |
| | #30 |
Friends: 11 | Can't argue with that. Don't think I would want to fold shitted feets either. |
| alarm, battery, dies, smoke, throw |
| New HV Battery & inverter, still dies. Help! | gaithersteve | Generation 1 Prius Discussion | 5 | 07-23-2009 07:38 AM |
| If and when the battery dies, wouldn't that... | burritos | Gen II Prius Main Forum | 14 | 04-25-2007 03:59 PM |
| electric battery dies--what to do? | lauejp | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 04-03-2007 03:12 PM |
| electric battery dies--what to do? | lauejp | PriusChat Website Questions | 0 | 12-31-1969 07:00 PM |
