| This is a discussion on Faced with this crisis within the Environmental Discussion forums, part of the PriusChat Forums category; Originally posted by tomdeimos It's getting a bit late to fix this now, but it is really simple to do: ... |
| | #11 | |||||||||||||
| Senior Member Join Date: Jun 2005 Location: Bucks County, PA
On the bright side, you did manage to reduce emissions from airplanes, because there are fewer of them in the air. Quote:
Of course, there's that whole other problem about the national power grid. You see, it's pretty much at capacity. If you're going to be cranking out electric cars, you'll need to do something about it. And it's not just the generation plants, it's also the transmission network between the generation plants and the consumer. We'll just have to legislate that they upgrade everything in time for the delivery of our new electric cars. But then again, they'll have to pass on the cost to the consumer, which would likely trigger a recession resulting in nobody being able to buy all of those new electric cars. Companies go bankrupt, causing more recession, and round, and round. Quote:
Now, all that you propose could probably be accomplished via incentives and subsidies, allowing these things to be phased in when the time is right for everyone involved. But remember, the call went out for "Proper Regulations" and not for subsidies, incentives, and market forces. You see, the problem with regulations is that if you come out with a "Thou shalt reduce your emissions by 50% by next Feburary" kind of regulation, it will ignore the cost of compliance with the regulation. It won't matter if the company trying to comply with the regulation has $3 billion in equipment that hasn't been paid for yet that will have to be scrapped and replaced with $6 billion in new equipment. It won't matter if the regulation requires the company to build something that nobody can or will buy. If they can, they'll pass the new cost on to the consumer. If they can't, they'll go bankrupt. Bankrupt enough companies and you trigger a recession. A recession puts even more pressure on the companies that were just managing to squeek by complying with the regulations. Some of them will go bankrupt too. Then lots of really bad stuff starts to happen. Now maybe, just maybe, you could design the regulations in cooperation with the companies you will regulate, and therefore build in time tables and targets that can be accomplished. That way the government gets the regulations it wants without putting too much pressure on the economy. But as soon as the Democrats see you talking to corporations, either in public or behind closed doors, be prepared for the backlash. | |||||||||||||
| | #12 |
| Senior Member Join Date: Jun 2005 Location: Morris County - New Jersey
Friends: 0 | As the previus poster showed some interesting ideas, but nothing is ever as simple as it seems. I question the soundness of two of your ideas: "6 Start using wave and tide power for electricity along both coasts. " No one knows the climatic impact of these things on a large scale. If you slow the winds down and slow the waves down - as generating power from them will do, what impact will that have on the overall ecosystem. Think about it, on a large scale you could have a very bad impact on the planet. 8 ...... and convert more buildings to electric heat. Electric heat is the most ineffective way to heat. To make electricity you burn fosil fuel and then suffer a loss of over 65% of the energy to go to electricity, you then have transmission losses moving this electricity around. Why not just use a high eff gas furnace to heat your house. I have one that converts 96% of the energy to heat. A more appropriate way to do things is to make them economically viable. Here in NJ there is a small fee everyone pays on their electric bill (based on how much they use) that the state then uses to encourage people to both conserve and generate green power. The current system encourages photovoltaic solar panels. The state will pay up to 70% of the cost of a system you install on your house. I did this last year. The system has a 100% payback in only 4 years with this subsidy. After that I will have free electricity for the life of the system which is estimated at between 25-30 years. That is how you do things - make it a win-win for everyone. |
| | #13 | |
Friends: 0 | <div class='quotetop'>QUOTE(kirbinster\";p=\"106683)</div> Quote:
Wave power may have environmental effects, but so does everything. I don't see us getting all energy from windmills. But every bit must come from solar, at least till someone perfects hydrogen fusion. Nuclear is another stop gap solution at best till we run out of places to store the spent fuel. Gas furnaces are no help at all because it makes more CO2. Once we fix the problems with vehicles, heating our buildings will be a big remaining problem. We can heat with solar directly some places, and for the rest it pretty much comes down to hydrogen or electric. Electricity should always be cheaper to distribute than hydrogen I should think and be cheaper. Tidal power should be great for our coasts, by protecting them from storms much like lakes for water power do today to protect cities along rivers. Wave power I can' imagine any major harmful effects unless it was done too many places. If we grow our economies till the planet is engulfed, nothing will work. | |
| IRS Suffers Staggering defeat...jury returned zero convictions on 161 charges faced by nine defendants. | burritos | Fred's House of Pancakes | 4 | 10-13-2007 06:16 PM |
| Global Warming Is Not A Crisis | TimBikes | Fred's House of Pancakes | 67 | 03-21-2007 08:30 AM |
| General motor crisis | AlbertoC67 | Gen II Prius Main Forum | 33 | 10-13-2006 07:09 AM |
| Biofactories to help energy crisis? | Technogeek | Environmental Discussion | 1 | 11-08-2005 01:39 PM |
| A frightening prediction of our oil crisis | jaguaraja | Fred's House of Pancakes | 41 | 04-27-2005 11:27 AM |
