Go Back   PriusChat Forums > PriusChat Forums > Other Cars > EV (Electric Vehicle) Discussion
This is a discussion on Electricity hidden CO2? within the EV (Electric Vehicle) Discussion forums, part of the Other Cars category; Originally Posted by cwerdna As an FYI, EIA - Electricity Data, Analysis, Surveys is a graph of the US electricity ...
LinkBack (1) Thread Tools
Old 03-19-2009, 02:43 PM   #21
DaveinOlyWA
3rd Time was Solariffic!!
DaveinOlyWA's Avatar
Default Re: Electricity hidden CO2?
Originally Posted by cwerdna View Post
As an FYI, EIA - Electricity Data, Analysis, Surveys is a graph of the US electricity generation mix. How clean is the electricity I use? - Power Profiler | Clean Energy | US EPA lets you look up the generation mix for your area.
hmmm. rather large difference between what is reported here and what my power company actually tells me is used. now i do contribute to the "green power" intiative, but cant imagine that would make up that much difference....
they mention gas. well according to the bill insert i get, there is little or no gas in Olympia area being used
**edit**
ok, i have now punched in zip codes for 3 different cities in Wa and Or and the numbers are not changing. so despite what it says, its giving a very large regional average. so not really specific to any one area at all
DaveinOlyWA is offline
Old 03-19-2009, 03:02 PM   #22
richard schumacher
Destination: Eschaton
Originally Posted by daniel View Post
Your whole post confuses amounts of energy with rates of energy flow. It will probably take 20 kW, not 20 kWh, to charge a 40 mile Volt, if there ever is a 40-mile Volt.
I may well be wrong about the amount of energy required to fully charge a Volt with 40 mile electric-only range, but I do mean 20 kW-hours. If the real energy figure is smaller than 20 kW-hours, so much the better. A charging power (rate) of 20 kW would be amazingly large; no typical household could provide 1/20th of that.
richard schumacher is offline
Old 03-19-2009, 03:22 PM   #23
DaveinOlyWA
figure 4 miles per KWH so most likely to be around 10 Kwh
Old 03-19-2009, 07:54 PM   #24
daniel
Cat Lovers Against the Bomb
daniel's Avatar
Oops. My bad. I think I had a "senior moment" there. Sorry, Richard.
daniel is offline
Old 03-19-2009, 10:08 PM   #25
fuzzy1
Model: II
Originally Posted by DaveinOlyWA View Post
hmmm. rather large difference between what is reported here and what my power company actually tells me is used. ... they mention gas. well according to the bill insert i get, there is little or no gas in Olympia area being used
**edit**
Same here, the numbers are quite different than reported by Seattle City Light. But SCL is a big public utility, getting first pick of the desirable sources. The private utilities are last in line, so get the undesirable sources.
The website shows 45% of our regional energy coming from fossil carbon, while SCL claims just 1.22%. I operate on the principle that most of the clean energy I don't consume still gets sold to someone else, displacing carbon somewhere down the line.
fuzzy1 is offline
Old 03-20-2009, 04:21 AM   #26
lys
AerodynamicMac
lys's Avatar
The Rav4EV official numbers:
City
24 kwh/100 miles
Highway
35 kwh/100 miles
And this in a poor aerodinamic and heavy SUV -although very impressive and just working years ago-.
There is a lot to gain in efficiency with pure BEVs over PHEVs.
lys is offline
Old 03-20-2009, 11:33 AM   #27
daniel
daniel's Avatar
City
24 kwh/100 miles
Highway
35 kwh/100 miles
A minor point, but a matter of curiosity to me:
Are the above numbers measured at the wall or at the electric motor? The difference, of course, is battery inefficiency (charging and discharging losses). My Xebra (low-speed, light-weight, but inefficient) gets 3 miles per kWh, when driven gently, measured at the wall with a kwh meter. I have no way of measuring how many kWh the motor is actually using.
It would be interesting to know if the Rav4EV is being measured the same way.
daniel is offline
Old 03-20-2009, 09:05 PM   #28
DaveinOlyWA
well, it has to do with inefficiencies and different motors. my Zenn originally had a bigger motor which provided greater acceleration and i was getting 3.3 to 3.6 miles/kwh. well it burned up and instead of replacing it (and waiting up to 4 weeks for replacement) i opted to reinstall the standard motor instead.
well, its slower but it gets around 4 to 4.5 miles/kwh and its like 15 lbs lighter. so weight did not play a part. so the actual power used by the motor is probably less, so i would have to say that the RAV 4 numbers could be either way all depending on the motor, gearing and the fact that a transmission with a vehicle that heavy could easily greatly increase performance at higher speeds
co2, electicity, hidden
LinkBack to this Thread: http://priuschat.com/forums/ev-electric-vehicle-discussion/58473-electricity-hidden-co2.html
Info.com - electricity co2 - www.Info.com This thread Refback 07-09-2009 12:08 PM
Hidden EBH Plug TheForce Gen II Prius Modifications 25 06-13-2008 11:14 PM
Hidden MFD Screens jarhtmd Gen II Prius Main Forum 8 06-02-2007 12:03 PM
Any hidden secrets? rjmiz Gen II Prius Main Forum 6 12-24-2006 09:07 PM
A hidden SUV market among PCers? Jack 06 Other Cars 19 04-01-2006 11:35 PM
