Go Back   PriusChat Forums > PriusChat Forums > Fred's House of Pancakes
This is a discussion on Help me find the best ice chest/cooler ever! within the Fred's House of Pancakes forums, part of the PriusChat Forums category; Tom previously posted some of his thoughts on the matter in Post #10 of this thread: Originally Posted by qbee42 ...
Old 09-22-2009, 02:08 PM   #41
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
Default Re: Help me find the best ice chest/cooler ever!
Originally Posted by darelldd View Post
Thanks for the great input guys! So, if I'm not mistaken, there's just no getting around thick polyurethane insulation? It would seem that a layer of reflective foil (think space blanket) laminated to the interior walls would go a long way toward needing less bulk. The Quality and durability are just dripping off the units that Mike linked to... but where is the high-tech insulation that I just assumed would be out there somewhere... at some price? Has anybody ever attempted a vacuum insulation on something this big?
I've done extensive research on this topic for sailboat ice boxes. They are built-in, but the same principles apply. It comes down to durability and cost. There are many types of insulation with better R values than blue board, but each comes with some baggage.
Some types of foam work well when dry, but rapidly absorb moisture and loose most of their insulating properties. Blue board is impervious to water.
Vacuum panels are incredible, and can used for large ice boxes. The limitations with vacuum panels are cost, inability to cut to size, and short life span. While they have great R values when new, in a couple of years the panel will loose its vacuum and then it's not nearly as good as plain old blue board. You also have trouble insulating the corners between the panels, and the whole assembly tends to be fragile.
Silica tiles like those used on the Space Shuttle would work well, but the price is also in low earth orbit.
What we found is that all of the higher tech insulations provided an R value gain only at great expense with limited life. Plain old blue board has the best overall characteristics. We use four inches of it all of the way around, and cover the outside with a heat reflective material, such as aluminized mylar. We line the inside with layed-up GRP (fiberglass).
Best regards, Tom
07 Magnetic Gray #2 - GY TripleTreds 195/60R15, BT Tech Stiffening Plate & Strut Tower Brace, Philips X-Treme Power Headlights, Webasto 4300 Sunroof, Sharkfin Antenna, Chrome Wheelskins Wheel Covers & Door Handles, BumperDefender.com Bumper Guard Strips, Body Side Moldings & Rear Bumper Protector, NoBump.com License Plate Screw Bumpers, Bumper Bully, Sheepskin Seat Cover, Leather Steering Wheel Cover, Leather Center Console Cover, Center-Hump Litter Basket, Non-Slip Pads, Dalmatian Bobble Heads.
Boo is offline
Old 09-22-2009, 07:00 PM   #42
MarinJohn
MarinJohn's Avatar
Friends: 7
Practical Sailor has contracted with me to write a "how to" article about this topic, so look for it sometime this winter.
Tom if you get your 'how to' article written I would appreciate a PM. I'm curious as to why you had to build from the ground up instead of just replacing one top with another using the same cooler compartment (ice box). I'm sure it'll be in your article.
MarinJohn is offline
Old 09-22-2009, 10:32 PM   #43
a_gray_prius
Rare Under-30 Priuschat Member
a_gray_prius's Avatar
Package: #3 Touring
Friends: 9
You need one of these:
a_gray_prius is offline
Old 09-22-2009, 11:12 PM   #44
I had the parts, and it was cheap. The second reason is that it let me fit my space exactly, instead of using an existing assembly. That said, I think removing the parts from a stock cooler is an excellent idea, and one that I mention in my article.
Old 09-23-2009, 02:29 AM   #45
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
There's no call for injecting logic or reason into this otherwise perfect thread!
In order to make this thread even more perfect than it already is, I've saved and preserved as files (you have to do this with important stuff from the internets) and attached below:
(1) Reprint of Power Boat Reports & Practical Sailor's December 2005 review of coolers; and
(2) Reprint of Practical Sailor's September 2008 review of coolers.
Boo is offline
Old 09-23-2009, 11:53 AM   #46
darelldd
Prius is our Gas Guzzler
darelldd's Avatar
Sweet! Well done, Mr. Boo.
darelldd is offline
Old 09-24-2009, 02:54 PM   #47
ShellyT
Has anyone here considered and used dry ice in the cooler for extended trips?
ShellyT is online now
Old 11-14-2009, 04:26 PM   #48
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
Off-topic:
I see from the Bernie Madoff auction that's going on now, that Madoff used Igloo Marine coolers on his boat:
Boo is offline
Old 11-14-2009, 05:05 PM   #49
Originally Posted by Boo View Post
Off-topic:
I'm surprised they weren't gold plated, not that gold makes a good insulator.
chest or cooler, ever!, find, ice
Cooler than a Prius? Prianista Gen II Prius Main Forum 13 11-06-2007 08:59 AM
Ever get that sharp pain in your chest? gge5 Fred's House of Pancakes 8 02-14-2007 07:29 AM
Portable Cooler icemanjrperu Gen II Prius Modifications 2 04-20-2006 12:01 AM
Leaking Ice Chest in Prius Lefty Gen II Prius Main Forum 8 07-30-2005 03:04 PM
Electric cooler maggieddd Gen II Prius Main Forum 8 07-18-2005 03:42 PM
