| This is a discussion on Can't erase external HD! within the Fred's House of Pancakes forums, part of the PriusChat Forums category; So when I was thinking I was going to have to take my computer in (my thread "Computer does not ... |
Friends: 0 | So when I was thinking I was going to have to take my computer in (my thread "Computer does not see modem") I decided to be extra careful by backing up my Documents folder onto the older external HD, even though everything is also backed up on the regular backup HD via Time Machine. That old HD had the backups made by Genie backup from the old Windows PC. I don't need those backups any more. So I wanted to erase them and free up the space. But it would not let me delete the old backups. Even logged into my admin account, it would not let me delete files from that HD. I tried to format, and got the error message that it could not unmount the drive (apparently it wanted to unmount the drive before formatting???) When I try to rmdir the directories it tells me they are read-only system. Any ideas what's going on? I opened a terminal and tried to chmod the permissions, but I don't seem to know the syntax. There's got to be a way to erase or reformat the drive???
__________________ Daniel Primary car: 100% Electric 2003 Porsche 911 Carrera. Estimated range at 55 mph: 81 miles total or 64 miles to 80% discharge. Top speed 70 mph. Secondary car: Zap Xebra SD, also 100% electric. 1.9 cents per mile. Range: 40 miles total, or 32 miles to 80% discharge. Top speed 35 mph. Faster downhill. Both EVs use electrons generated from water power. Gas guzzler for when I have to travel farther than 60 miles: 2004 Prius. "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck |
Friends: 12 | Might be because the external drive was formatted FAT or NTFS for the Windows machine. I know NTFS causes issues if I try to mount such a drive for Ubuntu |
| Senior Member Join Date: May 2008 Location: Florida & DC
My Car: Other Non-Hybrid Model: Package: N/A Thanks: 31
Friends: 1 | Oh Crap. Get that porn off there before you bring it in |
| Rare Under-30 Priuschat Member Join Date: Jun 2008 Location: Chicago, IL
My Car: 2008 Prius Model: N/A Package: #3 Touring Thanks: 9
Friends: 9 | Wow man, for all the supposed superiority of Apple/OSX you seem to have a lot of problems. * used to be an Apple tech a long time ago |
BTW, OS X can read the drive and copy files from it. The problem is that I have read-only permission, and even logging on with my admin account the drive won't let me delete files. I presume the backup program set the permissions so only it could delete files. But it's MY drive and I have a right to wipe it!!! | |
Compared with the unending mountain of problems I had with Windows, this is nothing! | |
Friends: 0 | |
My Car: 2007 Prius Model: Package: #6 Thanks: 282
Friends: 11 | Daniel, You should go into Applications >Utilities and launch Disk Utility. In the window on the left select your external drive. You want to Erase. Choose HFS+ as the file type. It should reformat to Mac HFS+. You can only read NTFS, so that is why you can't just delete the Windows (NTFS) files. |
| The Following User Says Thank You to dogfriend For This Useful Post: | jayman (10-13-2009) |
Friends: 9 | Hey, it looks like all you have to do is login to the guest account and then the admin account to delete all your data! Fanbois howl over data-munching Snow Leopard bug ? The Register Apple acknowledges Snow Leopard data loss issue | Circuit Breaker - CNET News |
| The Following User Says Thank You to a_gray_prius For This Useful Post: | dogfriend (10-13-2009) |
| erase, external |
| external dvd | cdl2374 | Gen II Prius Audio and Electronics | 0 | 07-14-2007 07:46 PM |
| External CD changer? | mmoncur | Gen II Prius Audio and Electronics | 3 | 05-29-2007 04:48 PM |
| External MPG display | Bruski | Gen II Prius Modifications | 14 | 05-03-2007 10:39 PM |
| Vote in House Seeks to Erase Oil Windfall | DaveinOlyWA | Gen II Prius Fuel Economy | 3 | 05-22-2006 08:57 PM |
