Notices
Fuel Economy This is a discussion on Pulse and Glide within the Fuel Economy forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(DaveinOlyWA @ Sep 15 2006, 07:30 AM) [snapback]320059[/snapback]</div> great improvement Henry!! but i think you still have to look ...
Old 09-15-2006, 10:50 AM   #21
Frank Hudon
great improvement Henry!! but i think you still have to look at the break in being part of that improvement as well. i am breaking in a new Prius and my mileage has dropped about 8 mpg and im in the best of parallel tests you can do. same driver, same basic routes, same driving technique. went from averaging 60+ mpg in the summer to struggling to get 53. whats worse, just saw article in paper that most of the country is going to winter formula gas today (sept 15) there goes another 5-8% lower mileage...
just had my first fillup on my Prius Part Deux and now i know why there is 3 asterisks around the
***Full Tank of Gas***
i think it means "your fullness may vary"
computer mileage 53.3
pump mileage......44.4
oh well, next year when the LT difference is less than ½ mpg and my average is up 4 mpg, the pain will begin to fade
pump milage 44.4
I always recommend the first stop is a gas station and fill the car up as you would normally do, yes I know Toyota says a "full tank of gas" but the person filling your new car pulls the nozzle at the first click just like he was told to do. So your first tank is never "full". Fill, reset and go. I don't think it makes almost 9 miles to the gallon difference but a level playing field is always the best for those who track every drop of gas the car uses.
Frank Hudon is offline
Old 09-15-2006, 10:58 AM   #22
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
Friends: 6
ya Frank. should have, but same thing happened with my 04 although not as drastic. my 04's first tank was 42.9 pump, 48.2 computer. and it all evened out at the end so...
besides, i knew it would suck since my first bar disappeared at about 30 miles. to be honest with ya, with the varying accuracy of the pumps, i never did pay much attention to the figures anyway. i track the numbers only because... i can i guess. some will always be interested in actual dollar figures. my CPM uses actual pump and dollar figures... but then again, that wouldnt change anyway...hehehe
My 2006: Last tank 341.6 miles @44.7 pump (43.3 computer) 3.81 cpm
winter mpg 50.44 summer mpg 54.71
lifetime: 34,290.1 miles 52.55 mpg pump (53.78 mpg computer) 5.67 cpm
My 2007 Zenn Driven 5945 miles, 2.01 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh
Savings over my Prius $302.66 The Corolla...573.26
The REAL SAVINGS from not driving Corolla 693.39 +Prius= 996.05 (excludes maintenance costs...would be unfair to ICE vehicles)
DaveinOlyWA is offline
Old 09-17-2006, 11:14 PM   #23
hdrygas
I am not entirely sure about that from September to November , at 1880 miles, I bumped from 51-54 to 56-61 (my best tank till spring) after that was the winter slump 49.7 to 58 in April and after May was all over 60. Now I admit I cheat. I have the radiator blocker in winter and the block heater. Both are going to be started real soon now!
hdrygas is offline
Old 09-17-2006, 11:27 PM   #24
Frank Hudon
<div class='quotetop'>QUOTE(hdrygas @ Sep 17 2006, 08:14 PM) [snapback]321004[/snapback]</div>
I said to the wife today if the temps stay like this I'm putting in my winter lips. That should give us a little late summer. If your temps are like ours and with the abillity to monitor our temps I think we have nothing to loose.
Old 09-19-2006, 09:49 AM   #25
DaveinOlyWA
Friends: 6
well not that i have a Prius with no CANVIEW, i will probably get something to block the radiator anyway. unlike other cars, my 2004 never got hot even under the worst of summer conditions. highest recorded temp i had was 197º. even without a radiator or antifreeze, the water wouldnt boil. that to me shows how little energy is lost in waste heat like a normal car. shows you how much is really wasted while idling in a normal car.
plus with CANVIEW and no radiator block, my average running temps for my short commute was only around 165-175º. summer time was 188-191º so have to assume that my Prius was struggling to get to the proper operating temperature when driving at street speeds most of the time anyway.
so will be looking at ideas on the best way to do it. i like Henry's idea for convenience but not sure i like the bra look. plus, convenience would be less of a factor since overheating seems to be a non-issue even in mild climates like ours, so may dish that since it would be a twice a year project.
Old 09-21-2006, 12:28 AM   #26
hdrygas
<div class='quotetop'>QUOTE(DaveinOlyWA @ Sep 19 2006, 06:49 AM) [snapback]321578[/snapback]</div>
Dave I have a ScanGage that I am willing to lend you until you get the new 06 > Can View. It is limited but will give temps, and from that you can infer S4 operation! Give me a call!
hdrygas is offline
Old 09-21-2006, 10:12 PM   #27
DaveinOlyWA
Friends: 6
wow, how does it hook up?
Something different than pulse and glide LongRun Fuel Economy 6 01-07-2007 10:50 PM
Pulse and glide Tadashi Fuel Economy 3 06-19-2006 09:17 PM
Pulse & Glide *-*101 rufaro Fuel Economy 21 06-13-2006 12:27 PM
Pulse and Glide hjon71 Prius Main Forum 8 04-01-2006 06:53 AM
Pulse and Glide or Not hdrygas Prius Main Forum 3 12-28-2005 03:39 PM
