| Notices |
| Fuel Economy This is a discussion on MPG variance between actual and computer? within the Fuel Economy forums, part of the Toyota Prius Forums category; Originally Posted by Fuzzy Thanks, a priori! What I haven't figured out quote-wise is how you quote just certain selections ... |
| | #31 | ||
| Senior Member Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
Ah hah! I can fix that! . . . All you need to do is wrap the phrase in the beginning and ending codes. The ending code (or whatever it is really called) is always "[/quote]", while the beginning code identifies the specific posting. Of course there are other ways of doing this, but to "quote" this phrase: Hitting the "quote" button appears to duplicate the entire post I'm replying to. I tried highlighting selections, but that doesn't seem to do it. I have some vision problems and can look right at stuff and not see it - LOL. . . . just encase it in the quote= . . . and /quote phrasing like this (I've changed out "quote" for "quite" so you could see behind the curtain): [quite=Fuzzy;618330] Hitting the "quote" button appears to duplicate the entire post I'm replying to. I tried highlighting selections, but that doesn't seem to do it. I have some vision problems and can look right at stuff and not see it - LOL.[/quite]” When I replace quite with quote, I’ve included only the desired portion of your post in my reply: Quote:
Hope this helps! | ||
| | #32 |
| Senior Member Join Date: Oct 2007 Location: Maryland
My Car: 2002 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Over the last just under 10K miles, my pump average is 45, MFD average is 48.5. This is from October to May. Hopefully it will improve a bit over the summer, though I noticed that A/C usage eats-up about 3-5 MPG so it might not change the average due to the hit from A/C usage (and I seem to need to use A/C when temps are over 80 F and I can't open the windows). I have almost never had an MFD lower than the pump reading. '02 with 126K miles... |
| | #33 | |
| Junior Member Join Date: May 2008 Location: Florida Keys
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Aha... I think I got it, a priori (trying it now to see if I got it right). And by the way, those codes are called html tags. Thanks. And we caught another rat in a trap under our hood last night (I posted to the "Rats attack our Prius" thread). Last edited by Fuzzy; 05-17-2008 at 07:12 AM. Reason: backed up to fine-tune my reply | |
| Actual Cost Per Mile? | olcorral | Prius Main Forum | 13 | 05-14-2008 04:13 PM |
| Possible Answer to MPG Variance between 04-05 and 06+ Models | Tideland Prius | Prius Main Forum | 4 | 02-10-2007 04:28 PM |
| actual VS computer | barbaram | Fuel Economy | 7 | 07-23-2006 09:15 PM |
| Huge variance between computed mpg and MFD | gnagel | Fuel Economy | 10 | 07-05-2006 12:09 PM |
| Computer estimate way off... 52.5 actual vs. 45.4 displayed | Escalade_on_22s | Fuel Economy | 13 | 04-26-2005 04:49 PM |
