| Notices |
| Fuel Economy This is a discussion on First fill-up since Dealer - MFD says 45.0 MPG within the Fuel Economy forums, part of the Toyota Prius Forums category; So I had to fill up the ol tank this AM. First time since I took delivery of my new ... |
| Junior Member Join Date: Nov 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | So I had to fill up the ol tank this AM. First time since I took delivery of my new baby a couple weeks ago. Pumped 9.0 gallons in but since I have no idea what "Full" means to the dealership, I'll have to wait to manually calculate MPG. From what I read here, I can count on the MFD MPG to be roughly 1-1.5 MPG higher than actual. Considering driver weight (350#), time of the year, new-car break-in, location (mid atlantic) and driver (in)experience, I'm very pleased with this first tank. Beats the hell out of my now-retired motorcycle and more comfortable by far! |
| Platinum Member Join Date: Mar 2006 Location: Minnesota
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Well, that depends on what you consider "actual"... The MFD is capable of measuring the exact (or nearly so) amount of fuel that is injected into the engine, as well as the exact (or nearly so) distance traveled. Calculating, on the other hand, introduces a number of potential problems. First, you're using the same distance calculation the MFD is using (except maybe not quite as precise - you can only go down to 1/10 of a mile). Next, you don't know if the bladder has contracted or expanded at all between the start of the previous tank and this fill up. Third, you don't know if the pump you're using automatically shuts off at the exact same level as the previous pump used (and even the same pump can have variations from week to week as it gets abused by customers). And finally, you don't know for certain the accuracy of the pump. it may read 9 gallons but given you 9.02 gallons. So, in conclusion, drive happy, keep your logs, and fret over those "missing" 1-2 mpg like the rest of us :P |
| Ruler of Omicron Persei 8 Join Date: May 2004 Location: Far-North Chicagoland
My Car: 2004 Prius Package: #9 Nominated 4 Times in 2 Posts TOTM Awards: 0 Friends: 18 | Monquire, I have to agree with Eagle here. In fact, i ran out of gas a few months back because I thought I knew what was going on in the tank when in fact, I did not. For all the reasons Eagle point out, you absolutely can not use "amount of fuel used to refill the tank" as an indicator of true and accurate fuel efficiency. It is best to trust that the Prius knows two very vital pieces of information: exactly how much fuel was consumed and exactly how many miles were traveled. If you want, you can check out my mileage chart in my signature. If you do the math on my tanks, you will find that there is always some level of discrepancy between that the MFD shows per tank and what the math will reveal. Some people would argue that this is a horrible thing. I figure that since the MFD is providing that information, I won't even bother trying to do the math myself. I'm glad that you are pleased with your mileage. I know that it will only get better over time. Drive Hybrid. Drive Happy.
__________________ Proud father of Priapus: the '04 Tideland BC9 with an OEM EV button and sense of self-righteousness >>Current Mileage<< |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(VABeachPrius @ Nov 28 2006, 04:07 AM) [snapback]354737[/snapback]</div> Quote:
The Prius must net you some fantastic MPG down in the flats. | |
| Senior Member Join Date: Jun 2005 Location: Bucks County, PA
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The general consensus here is that although the MFD may be a bit higher than calculated values, it is at least consistantly so. So, if you accecpt the assumption that the MFD is at least consistant, if not 100% accurate, then you have to ask yourself what you are really trying to track with your tank averages... Is it the actual MPG value that is important to you or is it the trend that is important to you? If what you actually care about is whether you got better gas milage this tank than last tank, or this month than last month, then just use the MFD and be happy. It will provide you this trend quite well with very little effort. If for some reason it's really, really important to you to know that you really got 53.2 MPG instead of the MFD's 54.8 MPG this tank, and 52.5 MPG instead of the MFD's 54.1 MPG last tank... Well, then you have a problem, because you can't get that kind of accuracy with manual calculations... Ever. With MPG numbers around 54 MPG, a mere quarter of a gallon inaccuracy in your fillup gallons will cause a 1.5 MPG inacuracy in your calculated value. A quarter of a gallon is just 2.7 percent of a 9 gallon fillup. So you have to ask yourself... Just how accurate was that pump. Is the fill level this fillup the same as the fill level from last time? How do I really know how much gas was used to drive the miles I've registered for this tank? And anyhow, how do I really know I traveled x miles when tire size and tread wear can affect the odometer reading? You can increase the accuracy by averagung your manual calculations over 4 or so fillups. This will reduce the error caused by fill level inaccuracy (but not pump inaccuracy or odometer inaccuracy), but it doesn't give you a definitive "I got 53.2 MPG this tank" result. So... My opinion is "Why bother?". People are just fooling themselves if they think their tank by tank calculations are any more accurate than the MFD. Every single number you use in your calculation has some level of inaccuracy in it, so why expect a calculation using them to be anything other than an approximate value. And it's the trend that's more important anyway. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Marlin @ Nov 28 2006, 10:34 AM) [snapback]354781[/snapback]</div> Quote:
| Senior Member Join Date: Oct 2004 Location: Dallas TX
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I keep an Excel spreadsheet to track my "calculated" MPGs compared to the MFD numbers, not so much as a compulsion since I did the same on my previous cars: Toyota Camry, Cadillac diesel and Jaguar XJ6. I have only ~350 miles on my new 2007 Touring Edition Prius, so it's much too early for meaningful numbers.
__________________ Charles Suitt Dallas Texas 2007 Touring Edition (Former Prius: 2004) |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Marlin @ Nov 28 2006, 08:34 AM) [snapback]354781[/snapback]</div> Quote:
| Woo hoo! First Fill Up! | LMA | Fuel Economy | 3 | 09-15-2006 10:44 PM |
| Oil Fill | jackkpts | Prius Main Forum | 0 | 08-19-2006 01:53 PM |
| When do you fill up? | withersea | Prius Main Forum | 29 | 07-15-2006 12:59 PM |
| My First Fill-up: 54.2 MPG! | AfonsoSilva | Fuel Economy | 9 | 06-11-2005 03:13 PM |
| To fill up or not to fill up?? | Hokie-Dave | Fuel Economy | 12 | 05-11-2005 12:37 PM |
