Notices
Fuel Economy This is a discussion on 2006 Gas Mileage: MFD vs. Purchase within the Fuel Economy forums, part of the Toyota Prius Forums category; In 2005, I created a spreadsheet to compare my fuel economy for the year between that computed from a log ...
Old 12-30-2006, 02:20 AM   #1
aforkosh
In 2005, I created a spreadsheet to compare my fuel economy for the year between that computed from a log of my gas purchases versus a weighted average from the consumption display on the MFD (I recorded the miles and MPG every time I put gas in the car). This spreadsheet was the subject of the thread at this link. That thread discusses how the weighted average was computed.
I made my last gas purchase for 2006 today and have now completed the 2006 spreadsheet based on the final version of the 2005 spreadsheet (file attached).[attachmentid=6055]
I travelled a bit less this year (12958 miles vs. 14439--I didn't take a driving vacation this year) and used 37 fewer gallons of gas (273 vs. 310). I improved on last year's gas mileage (47.5 vs. 46.6 via the log and 48.3 vs. 47.9 via the MFD). Note that the log differential is more impressive and the difference between the log and the MFD decreased from 2.73% to 1.58%.
The 2006 difference between the two ways of computing mileage comes from the MFD showing 2.5 fewer miles and 4.3 fewer gallons of gas. Part of ther reason that the MFD numbers are lower is that the MFD does not reset immediately after a fill-up, but only after driving a short distance (usually between 0 and 0.25 miles). I think that the 2006 numbers are closer than the 2005 numbers partially because I changed the way I add gas. I should note that most fill-ups occurred at the same gas station, although at different pumps there. However, in past years, I tried to come close to topping off the tank, usually adding gas until the clicks occurred with very little gas being added (usually more that 1 gallon after the 1st click--no spills happened). However, this year, I was much more relaxed about it, usually forcing only 2-3 clicks after the the 1st click off. My hypothesis is that the pump accuracy degrades when small volumes of gas are added, leading to a slightly higher listed total (and charge) for the gas than was actually pumped.
Alan Forkosh
Tideland Pearl #9--2/9/2004
Plate: AL4KOSH
aforkosh is offline
Old 12-31-2006, 12:38 AM   #2
Bill Merchant
absit invidia
Bill Merchant's Avatar
Nominated 6 Times in 1 Post
Nominated TOTM Awards: 1
Friends: 53
Talking
Thanks for your spreadsheet, Alan. I read on PC somewhere, but I can't find it again, that the MPG shown on the MFD is quite accurate, based on the time fuel injectors are open and other criteria. If you or anyone else can point me to that post again, I'd appreciate it. A deviation of under 2% over 13K miles is pretty accurate!
Bill Merchant is offline
Old 12-31-2006, 11:27 AM   #3
tomforst
I've found that on average my MFD mileage is about 2-3 mpg better than my calculated mileage. I've recorded every refueling I've done since March 5th, 2005 when I purchased it. I'm attaching my spreadsheet that also includes a graph that shows a very interesting seasonal variation, and also what happened when I replaced my Goodyear Integrities with Goodyear Comfortreds. I'm now approaching 60,000 miles on my Prius - my mileage would be about 1 mpg better on average if my wife didn't drive it.
tomforst is offline
Old 01-03-2007, 11:15 PM   #4
barbaram
Send a message via AIM to barbaram Send a message via Yahoo to barbaram Send a message via Skype™ to barbaram
my spreadsheet vs MFD is close....as it's been said look at the big picture... 45+ MPG vs......25+???????
no contest!!!
don't worry- be happy!
barbaram is offline
Can 2006 purchase be claimed on 2007 taxes? njamhour Prius Tax Credit Discussion 4 04-17-2007 10:44 PM
To purchase or not to purchase a 2001 Prius? hppygrl Prius Main Forum 18 10-07-2006 09:19 PM
Lifetime mileage on 2006 MFD ghinners Prius Main Forum 6 01-10-2006 09:19 AM
2005 Gas Mileage: MFD vs. Purchase aforkosh Fuel Economy 1 01-01-2006 09:01 PM
When will the 2006 MY be available for purchase? dawall Dealers & Pricing 19 10-25-2005 12:17 AM
