| Notices |
| Fuel Economy This is a discussion on Why different tire pressure in front and rear tires? within the Fuel Economy forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(poodlemaster @ Jan 17 2007, 08:47 AM) [snapback]376784[/snapback]</div> i've noticed on several posts that people say you should put ... |
| | #1 | |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | <div class='quotetop'>QUOTE(poodlemaster @ Jan 17 2007, 08:47 AM) [snapback]376784[/snapback]</div> Quote:
You'll see that the Prius' engine is ahead of the front axle while in most cars, the engine is on the front axles or slightly behind it (one exception is the Yaris which I also presume has a 2lb difference). Hence, the Prius is quite nose-heavy and needs an exrta 2lbs to even things out. Check the door jamb. The manual should say 35/33 as well. You may be looking at the wrong section. In a regular car, you can also put 2lbs higher in the front to gain a very slight handling improvement. It may not be enough to actually feel a difference but it may help in some cases (e.g. emergency manoeuvre). It's not necessary but you could if you wanted to.
__________________ 2005 Tideland Pearl Premium Package as of 25th Oct 2004 VVT-i Emblem, Sport Pedals, OEM All-Weather Mats, Cargo Mat, EV Mod, JDM Prius Interior Footwell Lighting, DICE iPod Integration Kit, LED licence plate lights, Phillips Vision Plus ![]() 2008 smart fortwo passion coupé as of 28th Apr 2008 Foglights, dash pods, leather seats, OEM rubber mats, BRABUS alum. handbrake, LED licence plate lights & dome lamp | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | i've noticed on several posts that people say you should put 2 less lbs in the rear tires, so 42/40, 40/38, etc.. why? i know people say it affects the handling of the car, but i don't buy that. first of all, i just purchased an 07 prius a couple of weeks ago and the dealer had 42psi in all four tires. secondly, the manual says absolutely nothing about this, and i'd tend to trust toyota over a prius owner. i just don't understand why so many people believe this is the best setup. anybody have any thoughts on this? |
| Senior Member Join Date: Feb 2004 Location: Washington DC
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(poodlemaster @ Jan 17 2007, 11:47 AM) [snapback]376784[/snapback]</div> Quote:
I believe it's because the front of the car is significantly heavier than the rear. Tire Load Ratings are pressure sensitive. | |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Higher pressure in front is for attempting to compensate for the weight balance of the car, basically trying to keep maximum stickiness of the rear tires with respect to the road. I have found that I like 38/35, but experiment and see what works for you, as someone noted, lots of folks run 42/40. Higher than recommended pressures should help with MPG. Note that keeping all 4 the same could result in some surprises of the unpleasant kind if you have to make any drastic moves. |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | The extra two pounds in the front tires makes the Prius heavier in the front, which causes it to roll downhill during normal driving. This is the real secret to great gas mileage, but don't tell anyone else. Tom |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hey guys, what about wear on the tires? You know, the reason the tires get rotated every 5k miles, or whatever it is, is to ensure even wear on the tread of the tires. So don't you think that the front having 2 more pounds of air than the back also has to do with ensuring even wear on the tires? Especially since there's more weight at the front. Just a thought that it probably has more to do than just with ride comfort. |
| Senior Member Join Date: Jan 2006 Location: Chatsworth, CA
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | "i'd tend to trust toyota over a prius owner." Why do you waste time talking to Prius owners? Why not ask Toyota? Its common knowledge that in understeering cars (99% of cars on the road, including Prius) more air in the front than rear will balance out the handling a little. If you carry heavy luggage in the trunk, pump the rears a little more to compensate for the weight change front to rear. Front heavy cars need more air in the front tires, as a general rule. 2 psi can make a difference. Of course, I'm just a Prius owner.
__________________ Chatsworth, CA 06 Prius, White, Option 6, Visual Garage Shark Fin Antenna, BT Chassis Plate, BFG G-Force Sport 205-60 15 NO trim rings, Scangauge II. Other cars: '96 Subaru Outback, '00 Subaru Impreza RS |
| Senior Member Join Date: Oct 2005 Location: West Central Florida
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(qbee42 @ Jan 18 2007, 11:21 PM) [snapback]377583[/snapback]</div> Quote:
Rick #4 2006 | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | <div class='quotetop'>QUOTE(viking31 @ Jan 19 2007, 03:30 PM) [snapback]377906[/snapback]</div> Quote:
Tom | |
| tire shop broke a TPMS tire pressure monitor sensor during tire change | theorist | Care, Maintenance and Troubleshooting | 28 | 04-18-2008 12:53 PM |
| Best tires and best pressure | Ronald56 | Prius Main Forum | 5 | 07-20-2007 12:42 AM |
| Tire Pressure in your Hydroedge Tires? | Bill Compton | Prius Main Forum | 5 | 10-14-2005 08:27 AM |
| Do you really need more air pressure in front? | Ironworks | Prius Main Forum | 3 | 04-16-2005 04:03 PM |
