| Notices |
| Fuel Economy This is a discussion on Dynamic Braking within the Fuel Economy forums, part of the Toyota Prius Forums category; Are there any guidelines on how much of your braking energy goes to recharge the battery versus heat? When I ... |
| Junior Member Join Date: Jan 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Are there any guidelines on how much of your braking energy goes to recharge the battery versus heat? When I am coasting along and see a stop sign or red light, when should I start applying the brakes? I assume that a hard stop is a big waste. I assume a light stop mostly charges the battery. So if I am a block or two away should I slowly slow down to a crawl or what? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Frank Feuerbacher @ Jan 22 2007, 10:17 PM) [snapback]379290[/snapback]</div> Quote:
2. Anticipating stops and getting off the gas is good no matter what you drive. 3. Your MPG and your brake pad life will increase no matter what you drive. On the prius, I think you're just as well off coasting as lightly braking. Besides, if you start slowing down soon enough for a traffic light, it might turn to green before you have to brake to a stop. | |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Frank Feuerbacher @ Jan 22 2007, 10:17 PM) [snapback]379290[/snapback]</div> Quote:
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 26 | This'll give you some basic non-tech info: http://privatenrg.com/#100kBrakePads (scroll down a bit after the page loads) Here's some technical data points: http://www.vassfamily.net/ToyotaPriu...veffindex.html and http://www.vassfamily.net/ToyotaPrius/CAN/...ndex.html\ and (finally) http://www.vassfamily.net/ToyotaPrius/CAN/brindex.html Bottom line is that the earlier you start slowing down the better. If you must wait you want moderate brake pressure...when you have the tools to see it you're shooting for 60amps regen for optimal charge rate. |
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | One of the techniques of some of the master "hypermilers" is called DWB -- driving without brakes. Here is its decription from CleanMPG.com: <blockquote>"In its simplest form, you drive as if you do not have brakes. If you have degraded or no brakes for whatever reason, you will increase buffers in traffic like you may never have considered previously. In heavy traffic and traffic jam conditions, this will allow you to maintain some speed before throwing away energy to heating up the pads/shoes. With larger buffers comes the ability to maintain a very slow speed while most others are in a stop and go jam. You can use this in any traffic tie up or heavy congestion. Pro’s include higher FE, less wear on the ICE and braking systems, and easier on your mental state. Con’s include drivers around may continuously fill your buffers and thus you will again back off to recreate them. It may actually tax your mental state depending on your aggressiveness."</blockquote> I apply this technique whenever practical as I approach stop signs and red lights, guided by traffic conditions (I try to balance courtesy and maximum fuel economy).
__________________ Jim Lifetime fuel mileage: ![]() After learning how to hypermile: ![]() Click here for car details. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Beryl Octet @ Jan 22 2007, 10:01 PM) [snapback]379322[/snapback]</div> Quote:
If I am in heavy, stop-n-go traffic (highway at 5pm that is crawling at 1-20 mph) do I maximize use of battery + coasting or do I use the engine as much as possible, or do I just crank up the toons and relax | |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 26 | <div class='quotetop'>QUOTE(Frank Feuerbacher @ Jan 23 2007, 11:28 AM) [snapback]379569[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Depends on how fast you're going. On some of the secondary highways they've got the "RED signals ahead" signs that actually work right, i.e. start flashing the RED long before the actual light goes yellow. This is the time to start that beautiful long less-than-50-amps gentle regen glide, that happily sucks up all that kinetic energy all the way down to the light but still moving about 10 mph when it goes green and traffic clears out. Never hits the binders at all. . On the other hand, there's often the "sixty-to-zero surprise" where they don't care about helping traffic time itself and set up the light controllers like they were on any random suburban streetcorner and on a fixed-time cycle instead of using the traffic sensors like they should. A lot of townie proles aren't paid to think. . _H* |
| Using "B" for dynamic braking | Spike Jones | Fuel Economy | 32 | 12-15-2007 09:17 AM |
| B braking mode on CVT | jstack | AZ - Phoenix | 1 | 07-30-2007 03:11 PM |
| Coasting and braking | Pappy | Fuel Economy | 7 | 02-17-2006 12:36 AM |
| Regenerative Braking | Kaos1 | Prius Main Forum | 3 | 02-08-2006 09:22 PM |
| Using "B" for dynamic braking | Spike Jones | Prius and Hybrid News | 0 | 12-31-1969 07:00 PM |
