| Notices |
| Fuel Economy This is a discussion on Newbie question within the Fuel Economy forums, part of the Toyota Prius Forums category; Hi! New poster, just got myself a pristine -06 with 20K on it some weeks ago. LOVE this car!!!!! Still ... |
| Junior Member Join Date: Mar 2007 Location: Greensboro, NC
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi! New poster, just got myself a pristine -06 with 20K on it some weeks ago. LOVE this car!!!!! Still trying to figure things out though I'm an efficiency nut, so I did what I always do with my cars - put synthetic in there and pump up those tires real good. And drive smoothly, with an eye to the situation in front of me. So far I'm getting a solid 55 mpg indicated, so so far so good. A few things I can't quite figure out though, having scoured this site: 1. If you're just driving around the parking lot, or between stoplights when you know that you won't need to accelerate very much and/or will need to slow down soon, is it best to accellerate so slowly and to such a slow speed as to just run on electric only? And how about a longer stretch of road where traffic allows you to keep it so slow as to run electric only, seems like you can do several miles if you're careful! 2. When you know that you'll need to speed up to highway speed, is a slow start best, and let the ICE kick in when it needs to, or accellerate briskly and let it start up almost immediately? And when it does (in the absence of an rpm gauge), what is the best rate of accelleration and how do you judge it? By the instantaneous mpg readout, and if so, what's the optimum, if any? Appreciate your thoughts - and this forum. Many thanks! Bo (how could you not love a car that turns on the interior lights and unlocks the doors when you approach it!!!!) |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Well, if it's inbetween stoplights where you know you don't need to speed up a lot, then running on the battery is best. The situation you talk about where you can go on battery only for miles you should do the P&G if possible. If you can't do P&G then you should run on battery for a little bit then on the gas engine to charge the battery for a bit, then back to battery. Make sure that you end the segment using the gas engine though, else the battery may run down more than you want it to. |
| Junior Member Join Date: Feb 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Alexstarfire @ Apr 1 2007, 10:11 AM) [snapback]415695[/snapback]</div> Quote:
Newbie here. Surely the computer would know when the battery charge drops to the level requiring ICE to recharge? Or does the method described above improve MPG? Cheers | |
My Car: 2007 Prius Package: #5 Nominated 6 Times in 1 Post TOTM Awards: 1Friends: 53 | Welcome to PriusChat, Bo and Wakdos! Bo, if you accellerate to the point that the ICE starts, get as much speed out of the ICE as you need and quickly as you can without flooring it. Look at Evan Fusco's The Four Stages of Prius Enlightenment. Much depends on the temperature of the ICE and catalytic converter and the state of HV battery charge. There are a few good suggestions in sticky threads about maximizing MPG. Wakdos, the computer takes very good care of the HV battery, trying to maintain it at around 60% charged. The battery display on the Energy screen goes from all green (about 80% fully charged battery) to 1 pink or purple bar (about 40% charged). Most people rarely see these extremes. If you go down a long hill and regenerative braking "overcharges" the HV battery, the computer will first switch to hydraulic brakes to keep from taking even more charge, then spin up the ICE without fuel to "burn" the excess charge.
__________________ Bill Bill.Merchant@PortlandHSD.info 2007 NL 5 Silver Wraith 2005 BC 6 Silver CloudPortland Area HSD Meetup Group: PortlandHSD.info Become carbon neutral: Carbonfund.org or TerraPass.com |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Wakdos @ Mar 31 2007, 10:50 PM) [snapback]415747[/snapback]</div> Quote:
I've seen it improve my MPG, but I do know that my situation is different than yours. Around here you can't go half a mile without going up or down a hill. So I'm always charging my battery going up the hills. Provided you don't use too much battery it'll be fine, but it won't be near as good as P&G. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(BoHenriksson @ Mar 31 2007, 06:07 PM) [snapback]415665[/snapback]</div> Quote:
Cogito | |
My Car: 2007 Prius Package: #5 Nominated 6 Times in 1 Post TOTM Awards: 1Friends: 53 | Hi Cogito, welcome to PriusChat! Your brain is the best computer, but it has learned many things that don't apply to the Prius. For example, to accelerate, step on the accelerator pedal; sounds simple enough, but sometimes the ICE will go into high rpm that sounds like the clutch is slipping, so you ease off on the pedal like you would in a '71 Corolla to keep from burning the clutch up, and wonder why the Prius has poor acceleration. Or you judge how fast you must be going from the shift-jerks as the automatic transmission kicks up, and suddenly notice you're doing 80 mph. The ICE is controlled by the computer, and a high-rev state is taking motive power directly as well as running one motor like a generator so the other motor can contribute power. If you take your foot off the pedal, you're telling the computer you don't want to go so fast, so acceleration slows down. You can't hurt the ICE or HSD with a high-speed rev. The HSD smoothly shifts power, with no gear changes, so you don't waste time or feel the kick of a gear change. Somethings you have to unlearn. Or learn anew for the Prius. |
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Just finished a road trip Ohio - North Carolina, total of 400 miles. For the first two hours or so of flatlands I got 62 mpg indicated on the screen, then its hilly almost all the rest of the way, dropping mpg to around 54. The trip total was 59.0 mpg. I aimed to maintain an even 60 mph throughout, using cruise control occasionally. I am surprised at what big drop the terrain caused in mpg. I would have thought that some of the obvious inefficiencies of driving under those conditions would be partially offset by the ICE working a little harder on the way up (which, up to a point, should make it more efficient) and then coasting on the way down - a sort of constant speed "pulse and glide". Any thoughts on this, and how to improve my mpg when driving back through VA and WV? |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(BoHenriksson @ Apr 5 2007, 04:17 PM) [snapback]418524[/snapback]</div> Quote:
Dave M. | |
| Senior Member Join Date: Dec 2006 Location: Columbia, SC
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Up to a point you are correct about ICE efficiency. They don't get much energy out of the fuel at light throttle/low load. But then there's the Prius. HSD works in such a way that above ~1200RPM or so the engine is always operating at 80% load, which is very efficient. So the truth is that your car takes care of it for you and you don't need to worry about going to wider throttle position to get peak efficiency. In fact you can't because you have no direct control over the throttle. All I've been doing, which works, is to strive to keep the engine turning at a sufficiently low speed that the intake doesn't drop out of the efficient atkinson profile (~2400RPM is best, ~3,000RPM or so still seems to be fine when you need the power). I used the terrain to pull 59mpg over about 65mi of really nasty New England hills. For the really big ones I made it a point to gain speed on my way down so that I could use that momentum to supplement engine power on the way back up, trading some speed for altitude rather than flogging the engine. For gentler hills I just held speed with the engine turning at whever speed it needed. How you handle the other side of the hill is important. Since the engine seems to lose efficiency at very low RPM, you don't want it to be turning when you don't need the power. (This is where your understanding of efficiency comes into play.) Rather than letting it idle, try to get some Warp Stealth glide time in (same as a normal glide except you will see battery power to the wheels, no arrows to or from the engine.) If you can maintain speed while gliding, great! If you can't, go into a light P&G to get back your speed once in a while. There's not much you can do but brake if you need to stop yourself from picking up too much speed on a really steep hill, but keep in mind that lighter braking should capture more energy than heavy braking. (Lower current means lower losses.) All that said, you're doing great! Play around a little more with that terrain if traffic allows and you'll see some improvement. It sounds like you've already figured out at least 90% of what I'm saying. |
| Another newbie question! | jdauteuil | Prius Main Forum | 8 | 10-17-2006 10:30 PM |
| Newbie MFD Question | tadyergey | Prius Main Forum | 9 | 05-26-2006 07:35 AM |
| Newbie question | steve10b | Prius Main Forum | 11 | 01-22-2006 01:18 PM |
| Newbie Question | SixInchPrius | Prius Main Forum | 10 | 12-06-2005 12:44 AM |
| One more newbie question | jonmac243 | Audio and Electronics | 1 | 04-15-2005 04:15 PM |
