Notices
Fuel Economy This is a discussion on Got the Glide! within the Fuel Economy forums, part of the Toyota Prius Forums category; So after really trying to glide and always getting arrows in one direction or another, tonight, I got a full ...
Old 05-24-2007, 12:06 AM   #1
vdubstress
vdubstress's Avatar
So after really trying to glide and always getting arrows in one direction or another, tonight, I got a full 2 minutes of pure glide, no arrows whatsoever! It felt as though the Prius was a gazelle.
vdubstress is offline
Old 05-24-2007, 12:16 AM   #2
bgdrewsif
bgdrewsif's Avatar
Location: Glendale, Arizona (formerly Bowling Green, Ohio)
<div class='quotetop'>QUOTE(vdubstress @ May 24 2007, 12:06 AM) [snapback]448772[/snapback]</div>
Congratulations!!! I truly is a great feeling to roll along silently using zero gas... Welcome to the gliders club!
bgdrewsif is offline
Old 05-24-2007, 12:59 AM   #3
Priusaurus110
<div class='quotetop'>QUOTE(vdubstress @ May 23 2007, 11:06 PM) [snapback]448772[/snapback]</div>
Bgdrewsif; just out of curiosity, what velocity range were you maintaining during your 2 min glide?
Priusaurus110 is offline
Old 05-24-2007, 01:50 AM   #4
vdubstress
vdubstress's Avatar
<div class='quotetop'>QUOTE(Priusaurus110 @ May 23 2007, 09:59 PM) [snapback]448824[/snapback]</div>
I haven't a clue, I wasn't really 'downhill' but had a very slight downgrade, I've been trying this pulse and glide schtick for a week (had the car for almost two) with NO success on flat open road. Always had arrows in one direction or another, no matter how I positioned the pedal! Grrrrr, I'm a drivers driver (and, yes bigmahma, I have ovaries, shocking!) I've always been able to clutch-less shift, perfectly matching engine and gear speed, L8 apex using cars power and weight shift at the auto-x, I am zen masta of heel and toe. So not be able to this, which seems fairly straight forward and simple, was beyond aggravating. I was just stoked to see no arrows, and pure silence Crap, I think I'm really starting to dig this car!
Old 05-24-2007, 02:20 AM   #5
kdk84
kdk84's Avatar
I've had my Prius for just about a month now. It took my quite a while to get the hang of the pedal position for a glide but I can now find it everytime I try. I find it easiest to "find" after releasing the acclerator completely then feathering back on to get to glide mode. However, this method does decelerate the car slightly since there is a slight moment of regen. I am now practicing on feathering off to glide mode without ever hitting the regen state. I'm sure I will be able to master this technique with more practice. P&G is a great driving technique.
2007 Magnetic Gray Prius Package 6
Heated Leather Seats, Disabled Reverse Beep, Disabled Seatbelt Beep, MFD Display Hood, Factory EV button Mode, Engine Block Heater
Calculated Lifetime MPG : 54.61mpg over 2948 miles
kdk84 is offline
Old 05-24-2007, 09:10 AM   #6
Brian04
Brian04's Avatar
<div class='quotetop'>QUOTE(vdubstress @ May 24 2007, 12:50 AM) [snapback]448850[/snapback]</div>
What kind of shoes do you wear when driving? Seriously.
I find it harder to P&G wearing boots or heavier work shoes during the week compared to my running shoes on the weekend.
Is it sad that my car dictates my fashion choices?
Brian04 is offline
Old 05-24-2007, 09:26 AM   #7
hugokhughes
<div class='quotetop'>QUOTE(Brian04 @ May 24 2007, 09:10 AM) [snapback]448960[/snapback]</div>
dont ever drive your prius with boots on.i am a carpenter and i know. you cant help but push the pedal harde r when you have on boots.i am getting 62.5 after 440 miles on current tank.with light shoes i can feel with my foot when my car hits p&g
hugokhughes is offline
Old 05-24-2007, 09:28 AM   #8
Ichabod
Artist In Residence
Ichabod's Avatar
Send a message via AIM to Ichabod
Friends: 7
That's not sad. I feel like we should all be wearing V-neck silver jumpsuits in our Prii. My favorite sighting of Prius-fashion combo was a guy in tweed and a bow-tie though. Very old-fashioned style with a very new-fangled car!
P&G is really easy when you're in the right operating mode. During some stages of warmup it's not easy to get, so for the first few minutes of a drive you might not get pure glide. After that, you can do as KDK84 mentioned and take your foot completely off the gas and quickly but gently re-apply pressure. I always find it easier to hit glide through regen, rather than by slowly releasing pressure. Sometimes it feels like you have to trick the car into doing it.
2006 Barcelona Red Metallic - a.k.a. "The Professor" :: Accessories/Mods :: BT Tech Stiffening Plate - Engine Block Heater - OEM EV button - OEM Mud guards - Rear Bumper Protector :: Near-future :: ScangaugeII
Ichabod is offline
Old 05-24-2007, 03:17 PM   #9
vdubstress
vdubstress's Avatar
<div class='quotetop'>QUOTE(Brian04 @ May 24 2007, 06:10 AM) [snapback]448960[/snapback]</div>
I usually wear my dansko clogs (work dictates my fashion) :P But I usually slide them off, The tilt on the stearing wheel makes my knees bump it with them on, and drive with my socks on.
Old 05-24-2007, 04:18 PM   #10
douglas001001
smug doug
douglas001001's Avatar
<div class='quotetop'>QUOTE(vdubstress @ May 24 2007, 02:17 PM) [snapback]449263[/snapback]</div>
try just using your big toe on the pedal
douglas001001 is offline
Pulse and Glide surfacinglove Fuel Economy 14 05-08-2007 12:44 PM
Pulse and Glide Soylent Fuel Economy 26 09-21-2006 10:12 PM
Pulse and glide Tadashi Fuel Economy 3 06-19-2006 09:17 PM
Pulse & Glide *-*101 rufaro Fuel Economy 21 06-13-2006 12:27 PM
I sure can PULSE.... why can't I GLIDE? kirbinster Prius Main Forum 6 08-11-2005 11:59 AM
