Notices
Fuel Economy This is a discussion on New Tires = Lower MPG???? Help!! within the Fuel Economy forums, part of the Toyota Prius Forums category; Got new tires on Maggie about 3 weeks ago. On the way to the dealership was getting 51 mpg and ...
Old 06-10-2007, 12:51 AM   #1
s.e.tx_parrothead
s.e.tx_parrothead's Avatar
Thumbs up
Got new tires on Maggie about 3 weeks ago. On the way to the dealership was getting 51 mpg and after getting Maggie's "New Shoes" the MPG started going down hill. On the way home, was struggling to get 45-46mpg. Don't know if this is normal or not, but after 3 tanks of gas, I am still averaging about 45-46. With the old tires, I was averaging around 49-50. I live about an hour north of Houston and I have had to run the A/C due to the high humidity but I run it just enough to cool down the cabin and then I turn it on to a lower fan speed. I have the temp set to about 77 degrees which is comfortable for me (little warm for the hubby).
I put the same ole Goodyears back on the car since I have the Extra Mile pkg. I am not sure if they did an alignment or not but I did check the air pressure about a week after the install and three tires were at 33 and one was at 30. I bumped the front two to 39 psi and the back two to 37 psi. If I fill up the car on the way home and check the mpg when I pull in the drive way, it is back up to the high 40s but as the week/tank wears on it drops. I drive the speed limit or a mile or two over (do use the cruise) and the commute is rather hilly.
I am at wits end wondering if just the A/C running a bit more caused the drop or what happened. Any suggestions????? Oh, have just under 32,000 miles on the car. Got the oil changed about 3 days prior to getting the new tires. Haven't done the officially sanctioned Toyota 30, 000 mile service at this time.
Thanks-
Kris
"It's the sound of the low tide, the smell of the rain, Travelin' alone on my boat and my plane. Take it all in, it's as big as it seems. Count all your blessings, Remember your dreams." -- Jimmy Dreams
"Maggie" Magnetic Gray pkg#7 w/leather upgrade, XM radio, MFD sunhood
Hubby -- 1989 Toyota pickup
1999 Jeep Wrangler
2005 Toyota Tundra
We share custody of the 05 Tundra and Maggie. I am no longer doing a long commute, the hubby is.
s.e.tx_parrothead is offline
Old 06-10-2007, 11:45 AM   #2
TonyPSchaefer
Ruler of Omicron Persei 8
TonyPSchaefer's Avatar
Nominated 4 Times in 2 Posts
Send a message via AIM to TonyPSchaefer Send a message via MSN to TonyPSchaefer Send a message via Yahoo to TonyPSchaefer
Friends: 18
There have been reports of new tires lowering mileage. Since I haven't changed tires, I don't know directly.
About the tank/week wearing on and the mileage dropping, as goofy as it sounds I truly believe that when I'm super-sensitive about mileage I actually hinder my own mileage by worrying more about it and working too hard at it. Sounds silly, I know.
About the A/C, because it is not hooked mechanically to the engine, it doesn't draw directly from it. However, running the A/C does draw from the battery which will reduce the State of Charge and may cause the engine to run more to recharge it and limit your stealthing distance.
Proud father of Priapus: the '04 Tideland BC9 with an OEM EV button and sense of self-righteousness >>Current Mileage<<
Spreading information and passing gas in the Greater Chicagoland area
TonyPSchaefer is offline
Old 06-10-2007, 12:14 PM   #3
Rangerdavid
Rangerdavid's Avatar
Hi Kris:
I remember reading several posts on here in the last year about new tires, and the reduced mileage until the "new" wears off the tires and they are broken in a bit. I'll look and see if I can add a link to one of the posts for you, but all else being equal, sounds like its just new tires and that should change after you get 2500 - 5000 miles on the new tires.
Good luck, and I like your avitar, Buffett rules !!
Rangerdavid is offline
Old 06-11-2007, 11:17 PM   #4
jamesl
Kris you didn't say what was the brand and type of tire you put on that is getting the lower mpg....
jamesl is offline
Old 06-12-2007, 12:13 AM   #5
s.e.tx_parrothead
I guess I just need to be patient...Not real good at that I will forget about it and see what happens after the 35000 mile oil change. I know that as soon as the Extra Mile pkg is up, I am probably going with something other than the OEM Goodyears.
RangerDavid, glad you liked the avitar. It is off a Caribbean Soul T-Shirt. We were lucky that JB made it to Houston for the Bama Breeze tour. He opened the tour there at Minute Maid. It was good, but I miss the smaller venues...The acoustics are better. But oh well it is JB!!!!!
Thanks again!
Kris
Possible to lower the drivers seat? mtissington Prius Modifications 12 11-16-2007 04:34 AM
New tires - Do Primera's lower gas mileage mikenancy1 Prius Main Forum 1 10-19-2007 08:50 PM
Looking to pay a lower price? Just ask Somechic Fred's House of Pancakes 6 10-03-2007 02:49 PM
55K MPG Lower than last Summer, what to do? mauricefrank Prius Main Forum 5 07-26-2006 10:38 AM
Lower milege Walker1 Fuel Economy 18 02-23-2006 09:43 PM
