| Notices |
| Fuel Economy This is a discussion on Highway mileage within the Fuel Economy forums, part of the Toyota Prius Forums category; Just got back from visiting my mom in Iowa. On the way there, set the cruise control at 74 mph ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Just got back from visiting my mom in Iowa. On the way there, set the cruise control at 74 mph (took the autobahn, so it was legal.) Got 42.0 mpg for the trip there. On the way back, set the cruise control at 65 mph. Got 48.4 mpg. Caveats - the way there was during the day, with the AC on, but pretty low. Way back was mixed, in the evening. I had the AC on at first, and then turned it off when I had to put the lights on. Mileage seemed consistent for the two legs, perhaps a hair better with the lights over AC. But the mileage back was no less than 48.2 mpg with the AC on. Also, now that I'm back, the car's overall mpg seems better, on the street and highway. At the end of the trip, I had 1500 miles on the car, so the trip may have helped break it in. I'll repeat a similar experiment on the next visit, compare and report. Regards, aeronaut
__________________ 2007 Touring Edition, Package #2, Silver Pine Mica Reverse beep disabled Coastal Tech EV mode mod Coastal Tech Front Power Outlet always-on mod Damplifier and Spectrum applied to rear doors Clif Designs QX6550 2 way speakers in rear doors |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Unfortunately going there and back from a place aren't really comparable. One may be slightly uphill while the other one is slightly downhill. Interesting to see that even at 74MPH that you still got 42 MPG, but I don't think those are very comparable. |
| Senior Member Join Date: Jan 2006 Location: Chatsworth, CA
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I do 90 miles a day at 70+ mph for most of the trip. Lifetime average is over 50.3 mpgs, in 38,000 miles over the last year and a half +. Its almost impossible to drive the same exact road at a given speed for comparison. I guess you might use the Scan gage to compare average speed over the same trip every day, and get a ball park comparison of speed vs. mpg. One trip won't provide much data. Just drive the car. Don't think too much about it. The Prius will do better than any other car you've probably owned, at least for me.
__________________ Chatsworth, CA 06 Prius, White, Option 6, Visual Garage Shark Fin Antenna, BT Chassis Plate, BFG G-Force Sport 205-60 15 NO trim rings, Scangauge II. Other cars: '96 Subaru Outback, '00 Subaru Impreza RS |
| Senior Member Join Date: Apr 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(aeronaut @ Jul 26 2007, 10:06 PM) [snapback]485883[/snapback]</div> Quote:
What tire pressure are you running? | |
| Senior Member Join Date: Dec 2006 Location: Columbia, SC
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Running the A/C reduces my highway mileage by a reliable 7-8%. (That's better than my old Accord that was hit by at least 15%...chalk it up to the variable speed compressor working its icy magic.) It may not drain the battery like it does in city conditions (ouch) but it does require a fair amount of energy to move all that heat up-hill. |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(brick @ Jul 27 2007, 08:33 PM) [snapback]486471[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I started the trip in Evanston, ended in Marion, IA. Evanston is 600 feet above sea level, Marion is 850 feet above. The trip was over 250 miles in length. What I was looking for was the change in MPG as a function of speed. I'm not willing to get on a test track to cancel out wind, elevation, etc, as that would be wasting gas to do the test. But while I'm travelling, I can do certain "experiments" and get some info about the car. Both A/C and lights will drain power from the car, which eventually comes from the gas tank, costing one some MPGs. How many is the question, and is a function of the outside temperature for the A/C. Lights will also cost you some, although probably not as much. Regards, aeronaut |
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(aeronaut @ Jul 26 2007, 10:06 PM) [snapback]485883[/snapback]</div> Quote:
| EPA MPG #'s killer Join Date: May 2007 Location: Elkhart, IN
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(morpheusx @ Jul 28 2007, 09:39 PM) [snapback]486880[/snapback]</div> Quote:
| poor mileage in town, better on highway | cslipman | Fuel Economy | 20 | 06-06-2006 02:31 AM |
| 2 things, love my 2006, highway mileage? | clifford | Prius Main Forum | 19 | 05-05-2006 10:06 PM |
| Prius tends to beat EPA highway mileage | driveprius | Fuel Economy | 1 | 02-05-2006 11:47 AM |
| 2005 Highway Gas Mileage | PriusNeedy | Prius Main Forum | 6 | 06-16-2005 09:53 PM |
| Awesome Highway Mileage | Bigsk8r | Fuel Economy | 4 | 04-07-2005 12:08 PM |
