| Notices |
| Fuel Economy This is a discussion on 4 hints to save money within the Fuel Economy forums, part of the Toyota Prius Forums category; I ran across an interesting bit of advice today: Pumping gas.... good things to know. I've been in petroleum pipeline ... |
| Senior Member Join Date: May 2007 Location: Huntington Beach, Ca
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I ran across an interesting bit of advice today: Pumping gas.... good things to know. I've been in petroleum pipeline business for about 31 years, currently working for the Kinder-Morgan Pipeline here in San Jose, CA. We deliver about 4 million gallons in a 24-hour period from the pipe line; one day it's diesel, the next day it's jet fuel and gasoline. We have 34 storage tanks here with a total capacity of 16,800,000 gallons. Here are some tricks to help you get your money's worth: 1. Fill up your car or truck in the morning when the temperature is still cool. Remember that all service stations have their storage tanks buried below ground; and the colder the ground, the denser the gasoline. When it gets warmer gasoline expands, so if you're filling up in the afternoon or in the evening, what should be a gallon is not exactly a gallon. In the petroleum business, the specific gravity and temperature of the fuel (gasoline, diesel, jet fuel, ethanol and other petroleum products) are significant. Every truckload that we load is temperature-compensated so that the indicated gallonage is actually the amount pumped. A one-degree rise in temperature is a big deal for businesses, but service stations don't have temperature compensation at their pumps. 2. If a tanker truck is filling the station's tank at the time you want to buy gas, do not fill up; most likely dirt and sludge in the tank is being stirred up when gas is being delivered, and you might be transferring that dirt from the bottom of their tank into your car's tank. 3. Fill up when your gas tank is half-full (or half-empty), because the more gas you have in your tank the less air there is and gasoline evaporates rapidly, especially when it's warm. (Gasoline storage tanks have an internal floating 'roof' membrane to act as a barrier between the gas and the atmosphere, thereby minimizing evaporation.) 4. If you look at the trigger you'll see that it has three delivery settings: slow, medium and high. When you're filling up do not squeeze the trigger of the nozzle to the high setting. You should be pumping at the slow setting, thereby minimizing vapors created while you are pumping. Hoses at the pump are corrugated; the corrugations act as a return path for vapor recovery from gas that already has been metered. If you are pumping at the high setting, the agitated gasoline contains more vapor, which is being sucked back into the underground tank, so you're getting less gas for your money. Hope this will help ease your 'pain at the pump' |
| Senior Member Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(LYLUVLY @ Sep 8 2007, 12:19 AM) [snapback]508943[/snapback]</div> Quote:
A question for you: Because the Prius has a bladder within the gas tank, does that take away from the concerns noted in "trick" 3, above? I could always see #1. In fact, we had a neighbor who filled up on a very cold evening and then parked his car in a warm garage. The gas expanded so much it popped his gas-cap and the garage quickly filled with vapors. We all found out about it during the middle of the night when the local fire department showed up for a hazmat response! I hadn't thought much about #2, but it does make a bit of sense. I thought the pumps had in-line filters to protect us! Again, thanks for the helpful info. a priori | |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | Yeah, #3 is a moot point for Prius owners because of the bladder that helps minimise vapour. However, you should still pump a bit slower because the bladder will not fully collapse when the tank is empty (like.. say a balloon without air) so pumping at high in an empty tank will still have vapour from the fuel. Here's a few more tips I can pass on: 5. Have the nozzle at an angle (usually with the handle lower than the nozzle) so that when the fuel is dispensed, it flows down the side of the fuel filler pipe, rather than cascading straight to the bottom of the tank. Again, it minimises vapour 6. After you're done pumping, partially pull out the nozzle and tilt the handle upwards. You can get quite a bit more from the droplets (and it's not just a few drops.. there can be quite a bit)
__________________ 2005 Tideland Pearl Premium Package as of 25th Oct 2004 VVT-i Emblem, Sport Pedals, OEM All-Weather Mats, Cargo Mat, EV Mod, JDM Prius Interior Footwell Lighting, DICE iPod Integration Kit, LED licence plate lights, Phillips Vision Plus ![]() 2008 smart fortwo passion coupé as of 28th Apr 2008 Foglights, dash pods, leather seats, OEM rubber mats, BRABUS alum. handbrake, LED licence plate lights & dome lamp |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Thanks for the tips! I wonder if they take the density thing into account in the winter time at places such as Ontario, where the temperature difference between summer/winter can be 50oC or more! |
| Senior Member Join Date: Aug 2007 Location: Newport Beach, CA
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | <div class='quotetop'>QUOTE(LYLUVLY @ Sep 7 2007, 10:19 PM) [snapback]508943[/snapback]</div> Quote:
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | <div class='quotetop'>QUOTE(arolf @ Sep 8 2007, 07:09 AM) [snapback]509034[/snapback]</div> Quote:
| Senior Member Join Date: Mar 2007 Location: Albuquerque, NM
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | <div class='quotetop'>QUOTE(LYLUVLY @ Sep 7 2007, 11:19 PM) [snapback]508943[/snapback]</div> Quote:
I guess you verified what somebody else in the gas business told me... that all gas is the same until it gets into the Shell or Chevron or whatever tanker truck. All the gas is the same in the pipeline, separated from diesel etc by a water "pig", and is the same in the common distribution center storage tanks. So the only difference between Shell and 7-11 and Bell and the rest is an additive that is put into the Brand's (like Chevron) tanker truck. How many gallons of those additives go into the tanker?? Do the unbranded stations ever put additives if they are not selling excess Chevron or Shell? Out here Costco sells whatever branded or unbranded gas is excess and cheapest, so you might get Shell one time and no-name the next. | |
| Will I save money? | offroad4x4yota | Prius Main Forum | 30 | 06-20-2007 11:06 PM |
| Alcool won't save money (or E85) | etyler88 | Environmental Discussion | 7 | 05-22-2006 11:32 PM |
| from CNN: Drivers run out of gas to save money | cwerdna | Fred's House of Pancakes | 3 | 04-26-2006 04:04 PM |
| hints from UPS to save gas | DaveinOlyWA | Fuel Economy | 2 | 08-14-2005 04:42 PM |
| I didn't buy a Prius just to save money!! | NewType | Prius Main Forum | 17 | 07-22-2005 05:01 PM |
