| Notices |
| Fuel Economy This is a discussion on Low Mileage on My 07 Prius within the Fuel Economy forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(xibis @ Sep 13 2007, 01:53 PM) [snapback]511975[/snapback]</div> I have an 07 Prius with about 6500 miles. My mileage ... |
| | #21 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(xibis @ Sep 13 2007, 01:53 PM) [snapback]511975[/snapback]</div> Quote:
| | #22 | |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 26 | <div class='quotetop'>QUOTE(callmetuck @ Sep 22 2007, 01:43 PM) [snapback]516240[/snapback]</div> Quote:
I don't recall your first post requesting help, but be sure to check the tire pressure...put it up to at least 38f/36r and preferably 42f/40r. since you do so many short trips you should seriously consider one of the engine block heaters. It will get the ICE pre-warmed and thus even with shorter trips you should be able to get reasonable mileage. Finally, with those numbers I still suspect much has to do with your technique...how far before a stop sign do you take your foot off the gas? If it's under 200 yards you're wasting gas...I often back off the gas as much as 1/4 mile before a light and sometimes as far as 1/2 mile at highway speeds. Are you staying at the speed limit? Do you pass other cars or follow them closely? Do the former, don't do the latter. Not sure where you are, but there are a lot of Prius owners in Florida, many of whom get excellent FE and would likely be more than happy to take you for a spin and give you some tips and critique your driving style on your usual routes of travel. Also, when you filled your tank last did you hit the 'reset' button on the consumption screen? If not then you're looking at a cumulative average since you got the car, it's hard to judge if there's been any improvement unless you reset that at each fill up so you can see how you're doing on each individual tank. (only applies to '06/07). If you're still convinced something is wrong ask the dealer to check the alignment, sometimes there can be significant alignment issues that will impact FE as well, though usually not in a dramatic way. | |
| | #23 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(efusco @ Sep 22 2007, 02:58 PM) [snapback]516246[/snapback]</div> Quote:
I did hit the reset button at the last fill up, although I had been told that this would be dont automatically. It hasn't been under 92 degrees since I got my car, so I'm not too worried about that. As for the tire pressure, I'm going out to check it now. Would you suggest the same psi for my 17" Pirellis? | |
| | #24 |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 26 | A city block is typically 1/8th of a mile...so around 600ft...exactly 200 yards. If the stops are 2-3 blocks then there is ample opportunity to accelerate for about 1/2 to 2/3rds the distance and glide to the next stop. I understand that predicament though, throw in AC in 92F temps, short trips, cold starts, and frequent stops only blocks apart and you're definately in the worst possible situation for getting good FE. Options include seeking out a different route with fewer stops. I didn't mention AC temp setting but if you can set it to 78F or so it should keep you comfortable without running excessively hard. Tint your windows...though I suspect in FL that's an automatic thing for ya. And the reset of the MFD is automatic on '04 & '05, but the MPG will not reset on the '06+...though the trip mileage on the display will. If it's a goal of yours to really improve FE then there are techniques that can do that even with an undesirable commute like you have...but it takes effort, practice and experience....something you're lacking just b/c of the low amount of driving you do. |
| | #25 | ||
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(efusco @ Sep 22 2007, 11:58 AM) [snapback]516246[/snapback]</div> Quote:
With your very low milage I'm assuming you do 5 min drives to the shops. If that's the case, your 30-35 MPG average is not only understandable but appropriate. I'm not sure if you've read other threads on PriusChat about fuel economy--but the Prius uses extra gas during the first 5 minutes of your drive in order to reach the proper operating temperature for the engine. This is why we get poor FE the first 5 minutes of runtime. This is also why your Prius makes odd noises when you turn your car off. It's because the Prius is pumping some of the warm engine fluid into a insulated canister to help expedite your next engine warmup. Anyhow, my understanding with the EBHs is that your fuel economy for the first 5 minutes of your drive is much higher, since the Prius doesn't have to waste as much fuel to reach optimal engine temp. Please correct me if I am wrong Evan! | ||
| | #27 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(efusco @ Sep 23 2007, 05:58 PM) [snapback]516688[/snapback]</div> Quote:
I'm soooo getting one. Still debating the EV mod. Have you decided wether judicious use of the EV mod will improve FE? | |
| | #28 | |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 26 | <div class='quotetop'>QUOTE(Sean Blumenthal @ Sep 23 2007, 08:01 PM) [snapback]516689[/snapback]</div> Quote:
| | #29 |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I also have an 07, but I'm doing 300+ miles a week, mostly highway. Up until the last tank of gas, (at 2400 miles) I wasn't resetting the mpg and it was staying around 42 mpg. On the current tank, after I reset the mpg, it's showing 36 mpg. Most of my diving is highway @ 70 mph, without a/c, and usually on cruise control. I've noticed that by the time I exit the highway, the battery indicator is usually in the green. I'm wondering if that is normal. |
| | #30 |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 26 | Again, check all the stuff mentioned above...tire pressure esp., have the alignment checked. For moderate weather at 70mph on CC 36 is a bit lower than I'd expect. The battery can turn green when you slow for a stop after coming off the interstate, wouldn't sweat that. You didn't say how far you've gone on the current tank or how far your individual commute/drive is. |
| MFD Mileage and Calculated Mileage not even close | Fibb222 | Fuel Economy | 9 | 01-16-2007 04:09 PM |
| City Mileage 10 MPG worse than Higheway Mileage | karat | Care, Maintenance and Troubleshooting | 27 | 10-20-2006 04:24 PM |
| My Prius Mileage | p626808 | The File Library | 2 | 11-15-2005 12:43 PM |
| New Prius mileage | raintree | Fuel Economy | 3 | 04-13-2005 12:25 PM |
| Prius Mileage | zoobob | Fuel Economy | 24 | 03-15-2005 01:02 PM |
