Notices
Fuel Economy This is a discussion on Dropping MPG within the Fuel Economy forums, part of the Toyota Prius Forums category; Last year, toward fall, I noticed a decline in mgp despite no changes in where I drove or driving habits. ...
Old 10-01-2007, 06:31 PM   #1
EllenH
Last year, toward fall, I noticed a decline in mgp despite no changes in where I drove or driving habits. As it was getting towards fall, I dismissed it as a change in gas formulations. At best over the winter, my 2005 couldn't do better than 40mpg. As the car wasn't used much during the cold months, I pretty much ignored this. With spring I was hoping for better mpg. It did creep up to 48 at times but that was about it. The previous year and a half, my mpg averaged 52-56 for summer and 48-52 colder weather. Now with cold weather approaching (has the formulation been changed yet?) it has dropped down to 42mpg. I asked the toyota mechanic about this and he said as Prius age, there mileage suffers. This doesn't sound right. Is he correct and should I be looking at a Corolla or other steady mpg vehicle? I am a careful driver, never go over 50 on long trips, keep local trips to a minimum, and don't use air or heat excessively. No problem with the tire inflation either. If I switch mechanics, what should I have them look at. as possible problem areas? The car has 28,000 miles on it.
EllenH is offline
Old 10-01-2007, 08:18 PM   #2
ACORNBLUES
Few questions:
1) are you changing your oil and rotating your tires regularly?
2) what pressure do you have your tires inflated to?
Few factoids:
a) in cooler weathers, the ICE (gas engine) stays on more to keep the emissions stuff hot so it can function properly - ppl stuff their front grills w/ pipe insulators to help keep the engine warm
b ) in cooler weathers, the ICE takes longer to warm up - installing an EBH (engine block heater) will help reduce that time.
<div class='quotetop'>QUOTE(EllenH @ Oct 1 2007, 05:31 PM) [snapback]520026[/snapback]</div>
ACORNBLUES is offline
Old 10-01-2007, 09:00 PM   #3
EllenH
Having read lots of questions in the forums, I have followed all recommendations. Even switched to synthetic oil. The first year of ownership was perfect even as the temps dropped. Now I find, the older the Prius gets the more the mpg seems to be dropping. What else can I ask them to check out? Nothing has changed (driving locations, method, ) but the Prius now doesn't seem to know its supposed to be the best economical car to own.
EllenH is offline
Old 10-01-2007, 10:15 PM   #4
paprius4030
paprius4030's Avatar
Send a message via Yahoo to paprius4030
Our 05 Prius has 75k and mileage hasn't changed at all. My question is...have you changed the engine air filter?
paprius4030 is offline
Old 10-01-2007, 10:30 PM   #5
Nominated 1 Time in 1 Post
Friends: 26
<div class='quotetop'>QUOTE(EllenH @ Oct 1 2007, 08:00 PM) [snapback]520081[/snapback]</div>
Having read lots of questions in the forums, I have followed all recommendations. Even switched to synthetic oil. The first year of ownership was perfect even as the temps dropped. Now I find, the older the Prius gets the more the mpg seems to be dropping. What else can I ask them to check out? Nothing has changed (driving locations, method, ) but the Prius now doesn't seem to know its supposed to be the best economical car to own. [/b]
I've just gone over 65k miles and my last year's mpg is the highest since getting the car. I got 54 in year 2 & 3 and 60mpg this year.
See my thread just posted today: http://priuschat.com/4-Year-Fuel-Eco...ts-t39342.html
efusco is offline
Old 10-02-2007, 09:25 AM   #6
EllenH
Knowing the Prius should be capable of better mpg is even more unsettling. The dealership techs obviously need a little guidance given the answer I received from them previously. Yes all filters have been changed regularly. Any clues as to what needs to be looked at would be appreciated.
EllenH is offline
Old 10-02-2007, 09:35 AM   #7
bwilson4web
bwilson4web's Avatar
My Car: 2003 Prius
Package: #1
Nominated 2 Times in 2 Posts
Friends: 9
<div class='quotetop'>QUOTE(EllenH @ Oct 2 2007, 08:25 AM) [snapback]520239[/snapback]</div>
  • tires and alignment
  • transaxle oil change
bwilson4web is offline
Old 10-02-2007, 10:00 AM   #8
mikepaul
mikepaul's Avatar
I hit a personal all-time record of 59.1MPG over 59 miles in August, so age (and even a weakened wheel bearing) doesn't really impact a Prius that's been decently maintained.
Darn hills around here make these records only possible on road trips, though...
mikepaul is offline
Old 10-02-2007, 10:04 AM   #9
fan-atic
fan-atic's Avatar
[As the car wasn't used much during the cold months, I pretty much ignored this. With spring I was hoping for better mpg.]
Could it be the Traction battery? The Prius needs to be driven regularly to keep the NiMH battery from discharging and aging prematurely. I believe the manual says to start it at least every two weeks.
fan-atic is offline
Old 10-02-2007, 10:24 AM   #10
firepa63
Senior Citizen
Did the mileage drop after an oil change? If so, check the level. If it's overfilled you will definitely get an MPG hit.
firepa63 is offline
Cruise Control dropping my MPG? Drunken_Monk Fuel Economy 4 03-22-2007 07:40 AM
Gas gauge dropping quickly! prberg Fuel Economy 4 11-20-2006 05:31 PM
MPG Dropping prius-yes-dubya-no Fuel Economy 2 08-31-2006 09:28 AM
mileage dropping?!?!?!? barbaram Fuel Economy 11 08-23-2006 12:25 AM
dropping fuel economy Martin Turner Care, Maintenance and Troubleshooting 5 12-04-2005 07:25 PM
