| Notices |
| Fuel Economy This is a discussion on High Tire Pressure = false MPG? within the Fuel Economy forums, part of the Toyota Prius Forums category; I just got my Prius last Sunday, and after reading posts here on better fuel economy, I decided I would ... |
| Senior Member Join Date: Sep 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I just got my Prius last Sunday, and after reading posts here on better fuel economy, I decided I would try upping the pressure on the tires a bit. I wonder if some of the fuel economy could now be off. So we know that odometer readings are based on tire rotations. But if the tires are over inflated, could that throw off the circumferance of the tire, leading to less tire rotations covering the same distance. So, even though you cover say, the 50 miles, the car's computer / odometer thinks you did less miles (since less tire rotations are required). So could that give a false low MPG rating? |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 26 | No, the tire circumfrence is not affected...at least not enough to have any measurable impact. If you somehow put enough in to make it buldge out in the center then maybe it would be a slight difference. |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 9 | <div class='quotetop'>QUOTE(Mormegil @ Oct 1 2007, 10:18 PM) [snapback]520127[/snapback]</div> Quote:
Find a road with mile markers and take a 50 mile trip noting the trip meter, fraction of a mile as you pass the markers. Over a 50 mile interval, you'll be able to calculate the percentage difference, a 'correction factor.' In an ideal world, you calibrate the old tires and put the new ones on and calibrate the new ones. Bob Wilson | |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 23 | Hey, where is the problem if it did give a false reading? The reality would be even better than you think you are getting and what you think you are getting would be better so hey, it's all good. Tyre age and wear would have a bigger affect. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm sorry, but I just don't see how air pressure can affect your tire circumference. Perhaps I'm just a noob, but someone should try to explain that. The volume of the tire would be different, that's for sure, but the surface area, and the circumference, aren't going to change. The best way to demonstrate this would be for you to take a tire, with no rim or anything, just the tire, and run it over a set distance. All you'd have to do is mark the tire, so you can count rotations are such, and then run it over like 100 feet, or more, without putting pressure on the tire and then do it again but put a lot of pressure on it so that it looks like a flat tire or something. I'd bet money that you'd get the same amount of rotations. If you do over inflate the tire too much you could cause the tire to expand which would give you false readings, but it'd be like 1%-2% at worst. I'd be more worried about the tire blowing out at that pressure than false mileage readings. |
| Senior Member Join Date: Apr 2007 Location: S.F. Bay Area
My Car: 2007 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Alexstarfire @ Oct 4 2007, 10:39 PM) [snapback]521602[/snapback]</div> Quote:
If you are concerned about whether you are truly getting improved mpgs from adding more air pressure, try this test: Run a calculated test with the factory recommended (35F/33/R?) air pressure. By calculated, I mean fill up the tank until the auto shut-off engages. Note your odometer reading at the fill-up. Then drive your normal trips until it is time to refill. Refill until the auto shut-off engages. Note gallons put in the tank and the current reading on the odometer. Divide miles driven by gallons filled for a baseline mpg number. Then bump the air pressure to something like 40F/38R and repeat the test. I think you will notice an improvement in the mpg number with higher air pressure in your tires. How high to raise the pressure is a personal decision (up to the maximum the tires are rated for). You will be juggling increased ride harshness (from the higher air pressure) against improved mpgs. | |
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi Apriusfan, Your fuel volume measurement technique is flawed. Because the Prius has a variable sized gas tank. The way to get an accurate fuel volume would be to divide the odometer miles driven by the mfd mileage (mpg). As miles (and the effect on the measured miles due to tire variation) are in the numerator and denominator, the effect of the tire variation cancells out, and you get accurate gallons. |
| "Dream" Prius Join Date: Apr 2007 Location: Cincinnati, KY
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | <div class='quotetop'>QUOTE(Mormegil @ Oct 1 2007, 11:18 PM) [snapback]520127[/snapback]</div> Quote:
The bottom line is the tread is what matters. If when you put more air in the tire the tread would stretch, then the tread would get longer. That would affect rotations per mile. The steel belts and the banding prevent the tire tread from stretching. If the tire tread does stretch it is so small as not to be measurable. When you change tires that will change rotaions per mile. Also as the tire wears that changes the circumfrence and thus rotations per mile. | |
| Member Join Date: Dec 2005
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(bestmapman @ Oct 5 2007, 09:08 AM) [snapback]521668[/snapback]</div> Quote:
1) Filled tire pressure to max allowed value. Marked tire and ground; walked bike for two tire revolutions and measured the distance traveled. 2) Same as above except I used about 20 psi less (about 20%) 3) Same as 1 except I was on the bike while traversing the 2 revolutions Results: Longest distance traveled was with 1). Both 2) and 3) gave measurably less distance. Conclusions: At least for bike tires, degree of inflation directly affects the distance traveled per revolution and therefore affects the odometer reading. Same is true for the weight of the "vehicle". The difference between 1) and 2)-3) was about 0.5%. Actions: I used the distance in 3) to calibrate my bike's odometer. As yet I have not tried this with my Prius. | |
My Car: 2007 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(donee @ Oct 5 2007, 03:54 AM) [snapback]521637[/snapback]</div> Quote:
| tire shop broke a TPMS tire pressure monitor sensor during tire change | theorist | Care, Maintenance and Troubleshooting | 28 | 04-18-2008 12:53 PM |
| Tire Pressure MPG | BigusD | Prius Main Forum | 3 | 07-23-2007 07:34 AM |
| Cheap, high pressure tires- actuals please | etyler88 | Fuel Economy | 3 | 08-24-2006 08:21 PM |
| Tire Pressure | Tripod137 | Prius Main Forum | 19 | 04-18-2006 11:23 PM |
| Delivered Tire pressure - way too high? | rflagg | Care, Maintenance and Troubleshooting | 14 | 04-03-2004 04:48 PM |
