| Notices |
| Fuel Economy This is a discussion on Using "B" for dynamic braking within the Fuel Economy forums, part of the Toyota Prius Forums category; Does anyone else use “B” as dynamic braking instead of hitting the brake pedal to slow down.... |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I am not sure what you mean by "dynamic braking." Here's what "B" does and when to use it: Cars with transmissions always have a way to use the ENGINE to slow the car, for when you do not want to use the friction brakes. "Jake brakes" on an 18-wheeler, low gear on a manual or an automatic. This is useful for steep hills where the friction brakes would overheat. The Prius is different: Wen you step on the brake pedal the Prius uses MG2 as a generator to slow the car (unless you are going slower than 8 mph or step hard enough on the brake pedal to indicate an emergency stop; in both cases the friction brakes are used). Thus in the Prius, stepping on the brakes normally re-charges the battery. This is good. It re-captures energy. The exception to the above rule is if the battery is as full as the car's computer wants it to be. Then the friction brakes are used. This typically happens on a long downhill slope. When you are going downhill AND you see all 8 battery bars green, THEN AND ONLY THEN should you use "B" in order to reduce the amount of usage of the friction brakes, and avoid overheating them. "B" on the Prius stands for engine Braking: It uses the engine to help slow the car, just as first gear in a manual transmission car does. NEVER use "B" except as above. It is amazing and depressing how many wrong and downright stupid explanations some salesmen will give for "B." Many salesmen are hired off the street on a commission basis, and (unlike service people) the dealership may have no incentive to teach them anything about the cars they are selling, especially the unusual Prius.
__________________ Daniel ---------------------- Primary car: Zap Xebra SD: 100% electric car. 1.9 cents per mile, using electrons generated from water power. (The Prius is my gas guzzler, used when I have to travel farther than 35 miles in a day.) "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck |
| Senior Member Join Date: Dec 2006 Location: Somewhere, NY
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | My quick answer: I don't use "B" until my battery goes green on my MFD, and then only if I'm going down a steep hill. Harry |
| Junior Member Join Date: Dec 2003
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Spike Jones @ Nov 4 2007, 09:16 AM) [snapback]534599[/snapback]</div> Quote:
| AmeriKan Citizen Join Date: Apr 2005 Location: San Diego, CA
My Car: 2005 Prius Package: #1 Nominated 3 Times in 2 Posts TOTM Awards: 0 Friends: 7 | I never use B. I don't have long downhill stretches on a steep grade. You might want to read the manual about use of the B mode. |
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Spike Jones @ Nov 4 2007, 11:16 AM) [snapback]534599[/snapback]</div> Quote:
There is no "Dynamic" braking on the Prius, as there is no giant resistor with liquid flowing through the radiator to get rid of the heat. Might be a neat retrofit project though. Could extend mountain driving friction brake life. With the resistor plumbed into the engine coolant system, it would keep the engine warm for instant hybrid capability at the bottom of the hill. The system would need to watch the CAN bus to get the battery SOC. When a switch on the instrument panel is switched to "Mountain Braking" mode, the following action would take place. When the battery is charged to the appropriat SOC (first green bar?) it switches in the resistor. Something more sophisticated might use the engine temp and gas pedal/brake pedal positions. What B mode does is uses closed throttle engine drag to aid down-hill braking. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(MO51 @ Nov 4 2007, 09:54 PM) [snapback]534667[/snapback]</div> Quote:
As long as the battery has some spare capacity, braking will capture the energy while B mode will throw it away. When the battery is full, energy must be wasted anyway, and B mode will not wear the brake pads, while braking will. -Stein | |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 23 | Using B except when decending a hill which will overcharge the battery is like spilling petrol on the road. If you lightly touch the brake pedal you will increase regenerative braking and capture energy to reuse when climbing the next hill. Using B mode dumps energy as heat to the atmosphere by spinning the internal combustion engine generating heat which is dumped through the exhaust and cooling system. |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 26 | B-mode does generate more than just coasting in D---not a lot, but coasting is usually about 12-14 amps (highway speed) where B is closer to 20-24 amps. |
| Abnormal "water" noise during braking/acceleration | flyingprius | Prius Main Forum | 7 | 05-19-2008 06:35 PM |
| Did I ruin my "regenerative braking"? | neka | Care, Maintenance and Troubleshooting | 3 | 07-24-2007 02:37 PM |
| Dynamic Braking | fbacher | Fuel Economy | 7 | 01-23-2007 07:26 PM |
| Top 100 Toxic Polluters in U.S.<img alt="" src="chrome://easygestures/skin/xLink.png" style="border: 0px none ; margin: 0px; padding: 0px; display: in | ghostofjk | Environmental Discussion | 0 | 05-12-2006 10:09 PM |
| Using "B" for dynamic braking | Spike Jones | Prius and Hybrid News | 0 | 12-31-1969 07:00 PM |
