| Notices |
| Fuel Economy This is a discussion on Does the 12v battery have anything to do with MPG? within the Fuel Economy forums, part of the Toyota Prius Forums category; I've asked this before and I never got a real repsonse. Those that I did recieve seemed to conclude that ... |
My Car: 2005 Prius Package: #4 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 15 | I've asked this before and I never got a real repsonse. Those that I did recieve seemed to conclude that a constant drain on the 12v battery from a large stereo system would not have an effect. A week ago I saw a thread where the electrical draws from various factory items (fog lights, headlights, tailights, heater, etc.) were shown and it was implied that these could lead to worse gas milage if all were used often. I'm still toying with maximizing my gas milage and the stereo system has me confused. I know the weight of the subwoofer boxes will reduce my milage but will the energy consumption from my rather large amplifier drain the 12v enough to cause a problem? The amplifier is rated at 1500watts RMS at 1ohm (this is how I run it) and has 4 40amp fuses on the amp. I.E. this is not a cheap fleamarket special. lol
__________________ 2005 Prius ![]() California Rangeland ConservationCoalition Ranchers, Environmentalists, And Agencies Working Together For The Benefit Of All. |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 7 | In purely theoretical terms, if you have a drain on the 12v system, the DC to DC converter will have to supply that energy and that comes from the traction battery which will need to be charged from the ICE, so yes, it theoretically should lower your MPG. You are using energy which could be used to power MG2. Theoretically. In reality, its probably less than the effect of the electric A/C compressor unless you have one monster of an audio system. |
My Car: 2005 Prius Package: #4 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 15 | From a physics standpoint is indeed how I was looking at it. I do not know the charge characteristics of our cars and I was not sure if there was enough current being supplied under freeway driving conditions to power my system AND charge the AUX battery so that I don't end up with a constant low charge condition. The system is not huge in my terms but at a true 1500 watts it's not tiny either. I was contemplating putting my other amp in to run the mids/highs but that would add another 400 watts (a large, very high-end, inefficient amplifier). I want to get a better understanding of how this may effect my milage before I do it though. If it is going to increase my consumption in a negative manner then I cannot do it. |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 9 | Quote:
Another factor is that the Prius inverter has a fuse in its 13.8 volt output (maintains the 12v battery and supplies all 12v accessories when in ready mode. You are pushing it to (perhaps beyond) its limit if you indeed are running at 1500 watts (more than 100 amps, divide power by voltage to get current). JeffD ps. The 12v battery has limited capacity. Don't run ANY heavy electrical load except in "Ready" mode. Last edited by jdenenberg; 12-22-2007 at 09:18 AM. Reason: added thought | |
My Car: 2007 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | A 1500 watt amp doesn't draw 1500 watts all the time, if ever. Look into RMS watts and how it relates to draw watts/ amps. Icarus |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | Quote:
__________________ Black 2006 package #7 Northern Michigan | |
