Notices
Fuel Economy This is a discussion on Pulse & Glide vs Cruise Control - a study within the Fuel Economy forums, part of the Toyota Prius Forums category; OK... Jumping on board here. I usually don't do a 15 m ph dV. My largest dV is about 22 ...
LinkBack (5) Thread Tools
Old 04-16-2008, 01:58 PM   #11
Dan.
MPG Centurion
Send a message via ICQ to Dan. Send a message via AIM to Dan. Send a message via MSN to Dan. Send a message via Yahoo to Dan.
Default Re: Pulse & Glide vs Cruise Control - a study
I usually don't do a 15 mph dV. My largest dV is about 22 kph. Dropping below 30 kph gets the gearing a bit to low for my likes (I know eCVT). In competition, I believe I slacked my window to a bottom out at 25 kph, but I probably unconsciously wiggled it back up to 30 kph pulse entry.
My smallest dV is usually around 4 kph. As mentioned before pulse RPM, IGN, and TPS should all be noted. dSoC is also critical.
As a side note I've emailed Texas World Speedway to see about securing some track time. I know they rent it out to speed freaks who want to zip around at 120 without fear of a ticket.
11011011
Dan is an official (Honda) Hydrogen Economy Convert!
Houston Hybrid and Hypermilers Club <106mpg.com>
Click the image to open in full size.Click the image to open in full size.
Best commute = 14.3mi @ 114 MPG (sg2)
Best (non-trivial) tank = 769mi @ 85.7 MPG (fcd)
MPG Centurion-Hybridfest 2007-Prius II-26mi @ 106 MPG (sg2)
Dan <11011011> @ CleanMPG.com
Dan. is offline
Old 04-16-2008, 03:05 PM   #12
nerfer
A young senior member
nerfer's Avatar
Package: #1
I usually don't do a 15 mph dV. My largest dV is about 22 kph. Dropping below 30 kph doesn't getting the gearing a bit to low for my likes (I know eCVT). In competition, I believe I slacked my window to a bottom out at 25 kph, but I probably unconsciously wiggled it back up to 30 kph pulse entry.
11011011
I thought the range in speeds was a bit wide also. P&G is best for rolling hills, from what I've read, CC better for the flats. I want to do some tests at some point based on terrain, when I get the chance (and nice warm weather so I know I'll actually glide).
nerfer is offline
Old 04-16-2008, 05:52 PM   #13
Dan.
MPG Centurion
TWS is interested if anyone wants to fly down to Texas. They haven't quoted rates yet. They are still just interested in finding out more about what our needs are. I have a MMH and a Prius. I can probably muster up a TCH and possibly an Insight if we wanted a broader testing. I could talk to some of the local dealers if anyone has some other models they think might be interesting.
I'll report back with the rates. Pointless unless the rates are reasonable.
TWS: Texas World Speedway
11011011
Dan. is offline
Old 04-16-2008, 05:54 PM   #14
diamondlarry
EPA MPG #'s killer
diamondlarry's Avatar
I have been playing around with deltas of ~5 mph or so and they seem to work best so far. Like Jim, I'm having trouble finding good weather on days that I'm off work. Most of the roads around my area have a stop sign every mile with a few areas of 2-5 miles between stops. On the 1-mile stretches, I usually pulse to 35-40 mph(sometimes maybe only 30) and can glide to the next stop. The only time I like to go below 30 mph is when I know a stop is coming up. As for what little experimentation I've done with cc, I can't even come close to the FE numbers I get with P&G even on the flats. I just got back from my mom's(5.1 miles) and was able to pull into my driveway with 124 mpg showing on my SG2 by P&G'ing to a high of 40 mph and gliding to as low as 30 unless I was coming to a stop sign. A week ago this Friday, I had 132 mpg on a 5.2 mile trip from my Church to home. SoC was at 6 bars from beginning to end. Also, my SG2 is currently reporting my tank at 75.8 after 449.1 miles. Just in case you're wondering about the SG's calibration, my last fill showed at 5.85 gallons and the pump showed 5.9 gallons. Sorry for the rambling.
diamondlarry is offline
Old 04-16-2008, 07:46 PM   #15
JimboK
One owner, low mileage
JimboK's Avatar
Dan and Larry: What are your typical acceleration rates as measured by RPM?
JimboK is offline
Old 04-16-2008, 08:09 PM   #16
diamondlarry
EPA MPG #'s killer
I will have to start keeping a closer eye on the rpm's but, it seems to me that 1700 rpm's is on the high side. Probably closer to the 1500 range. I'll watch it tomorrow.
Old 04-16-2008, 08:47 PM   #17
Dan.
MPG Centurion
That's more of a battery maintenance question than a P&G question. If I'm planning an EV stretch in the next 5 miles I pulse slow (1400 RPM). If I need to bleed off some charge I'll EV. I will also use low speed pulses to heat up the engine if needed. On a deserted road I will usually pulse in the high 14k to low 16k range. Most of the time I'm chasing IGN. I always want to pulse with IGN at either 14 or 15 except in the cases noted above. Sometimes IGN will stick at 17 and you have to lure it down by dropping RPM way low (high 13k).
In the end the RPM comes into the strategy part of the drive. Just depends on what I'm gonna need in the next 10 miles. When I did my HF run I had it pegged at 1600 RPM. I'd consider 1590 to 1610 optimal assuming a 30 kph to 54 kph window. To me it's pointless to go over 54 kph if your playing for high score.
11011011
Dan. is offline
Old 04-18-2008, 09:44 AM   #18
ericbecky
ericbecky's Avatar
My Car: Other Hybrid
Friends: 30
Originally Posted by efusco View Post
Eric, what about a panel discussion format. Sounds like we've got a couple people who are on similar thought processes...have them limit their data presentations to 10 min or so then have a panel discussion of techniques with them and other experts...Wayne Gerdes of course, Jimbo, Dan, Doc, maybe one or two more. Perhaps the sub-goal could be to create an 'ideal' study design that could be reproduced by multiple people at home and then that data compiled...
I really like the idea! Anyone wanna' volunteer to plan this?
I have two hotel conference rooms (1 larger, one smaller) rented for Sunday morning from 8-noon and I'll take care of getting them set up.
I just need someone to "take the bull by the horns" and line up the willing participants for the panel, as well as a moderator (in case things get too unruly. )
PM me email, or give me a call.
ericbecky is offline
Old 07-07-2008, 02:36 PM   #19
ericbecky
ericbecky's Avatar
Friends: 30
Doc Willie is still offering to do his presentation.
Does anyone else want to get in on being a part of a panel discussion on this Sunday morning at the hotel?
PM me ASAP if you are.
Old 07-07-2008, 10:26 PM   #20
Nominated 1 Time in 1 Post
Friends: 20
Eric called me today and I'm going to be on the panel.
efusco is offline
LinkBack to this Thread: http://priuschat.com/forums/fuel-economy/45679-pulse-glide-vs-cruise-control-study.html
Pulse & Glide vs Cruise Control - a study - Page 2 - CleanMPG Forums This thread Refback 05-01-2008 06:05 PM
Pulse & Glide vs Cruise Control - a study - Page 2 - CleanMPG Forums This thread Refback 04-16-2008 10:47 AM
Pulse & Glide vs Cruise Control - a study - Page 2 - CleanMPG Forums This thread Refback 04-16-2008 09:09 AM
Pulse & Glide vs Cruise Control - a study - Page 2 - CleanMPG Forums This thread Refback 04-16-2008 07:39 AM
Pulse & Glide vs Cruise Control - a study - Page 2 - CleanMPG Forums This thread Refback 04-16-2008 07:36 AM
Cruise control operated pulse and glide bwilson4web Prius Technical Discussion 11 05-08-2007 07:32 AM
My Method: "Pulse-Cruise / Neutral-Drive-Glide / Resume Mister Swigart Fuel Economy 39 03-23-2007 02:45 PM
Pulse and Glide Soylent Fuel Economy 26 09-21-2006 10:12 PM
Pulse and Glide or Not hdrygas Prius Main Forum 3 12-28-2005 03:39 PM
Pulse and Gluide Cruise Control Possible? GreenMachine Prius Modifications 6 10-30-2005 10:12 PM
