Notices
Fuel Economy This is a discussion on Pulse Plugs Make Prius Greener and Faster? within the Fuel Economy forums, part of the Toyota Prius Forums category; Hi Kyle, Are these Pulstar plugs hot or cold plugs? That is the length of the electrode and insulator are ...
pulstar, spark plugs
Old 05-08-2008, 08:23 PM   #11
donee
Default Re: Pulse Plugs Make Prius Greener and Faster?
Hi Kyle,
Are these Pulstar plugs hot or cold plugs? That is the length of the electrode and insulator are such that the tip of the center pin runs at a hotter or colder temperature than stock? A hypermiler, that does not highway drive, may have issues with cold plug fouling. A competition (cold) plug may not be appropriate for such application. A hotter plug can keep the insulation cleaner, and the electrically shunting deposits less.
donee is offline
Old 05-08-2008, 09:08 PM   #12
problemchild
problemchild's Avatar
Originally Posted by Bob64 View Post
99.9% efficient at turning gas into mechanical energy? Is that your FINAL answer?!
More like along the lines of 38% efficient, not factoring in transmission, alternator and other losses.
So your saying the engine only burns 62% of the fuel injected into it? Im saying it burns 99%. The spark plug will not make it burn more fuel then it already burns.
problemchild is offline
Old 05-08-2008, 09:10 PM   #13
problemchild
Originally Posted by Sheepdog View Post
"A real dyno graph looks like this. Not BS numbers on a webpage.
Modern day engines are 99.9% efficient meaning nothing will make them get better mpg. Hotter spark means higher voltage ignition system which they dont include with the plugs. The FAKE video is krap."
How efficient did you say? wow. Thats pretty good. The rest of us are doing considerably less than 40%. In fact I think unless you are in StarFleet, everyone on earth is doing less than 40% .
I'm beginning to understand your screen name.
So your saying the engine only burns 60% of the fuel injected into it? Im saying it burns 99%. That fancy spark plug will not make it burn more fuel then it already burns.
Old 05-08-2008, 09:41 PM   #14
donee
Hi ProblemChild,
Effiiciency has nothing to with how much fuel is burned. It has to do with how much work is extracted from the burning of the specific amount of fuel.
Yes, engines only do about 35 % of the work they could, based on the energy released by the combustion of the fuel. The rest goes into heat, either into the water jacket, or out the tail pipe.
You are right that 99.9 % of the fuel is burning in modern emissions controlled engines, and these plugs will not change that at all. But that does not change their efficiency significantly, over 99.5 % that was burned in 1970's boat cars. Lets see, 99.9/99.5 is like an improvement of 0.4 % in efficiency. The Prius engine alone, is dramatically more efficient than even the engine that uses the same block in a Toyota Echo. But, I wont go into why here (hint the Prius expansion ratio is 13 to 1, so the Tout is allot lower).
What might explain an improvement in efficiency due to a high pulse energy plug is that the burn is quicker. And being quicker, the peak temperature reached is higher. Which would improve the Input Temperature in the heat cycle. And its been known for many years that the efficiency of an engine is directly proportional to the ratio of Tin / Tout . Hell, I even learned this in freshman college physics in the mid 70's. And they told me that this had been understood since the 1800's.
If the Pulstar Plug improvement is happening, one way to explain it is that the larger discharge energy would result in fuel in a bigger radius being ignited simulatneously.
Now, this is actually along the lines of research by other professional engine people. They are working to make a HCCI engine, where all the fuel/air mixture, everywhere in the cylinder is triggered to burn simultaneiously, by a compression ignition scheme. The Saturn Aura will be available with an engine that can run in this mode at low powers in a few years, actually. Yea, they will actually turn off the spark plugs while in this mode.
This is different than a Diesel, in that the fuel in a Diesel is burned as its injected. While in a HCCI engine, the fuel/air mixture is present, and hopefully uniform throughout the cylinder at the time of ignition.
Now the bugabo in all this is NOx. A higher temperature would generate more NOx. Might not be an issue with the Prius, as it will run the engine less to get to speed. But it would be interesting to see the NOx outputs from the baseline US06, and the Pulstar US06 Prius tests.
donee is offline
Old 05-08-2008, 10:00 PM   #15
patsparks
Uneducated bird-brain Aussie
patsparks's Avatar
Friends: 17
I'll stick with Bosch.
patsparks is offline
Old 05-09-2008, 04:14 AM   #16
drees
Nice analysis Donee. I too would be interested in any emissions data obtained with the Pulstar plugs.
In theory, HC emissions should be lower and NOx emissions should be higher, but who knows. Could the ECU actually end up compensating and slightly richening the mixture thus offsetting any fuel economy gain and increase in NOx emissions?
My main concern is that I have heard of some poor QC control with some of the early Pulstar plugs on the NASIOC forums...
drees is offline
Old 05-30-2008, 03:59 PM   #17
lplate
Nicely outlined Donee. Wasn't this what made the Hemi so much stronger - simply lighting up the fuel from the top instead of the side?
As I learn more about my Prius it seems after changing driving style considerably in order to get consistently in the 40-50 mpg range one few reasonable things left is to maximize the efficiency of the ICE. It's the ICE that brings mileage down.
If the Pulstar plugs provide an ROI then that's a win. At $100 for a set and 5% increase in mileage, they would break even roughly a little under 50,000 miles, the manufacturer's listed life span. Then you start all over again. :>)
LP
2007 Barcelona Red Touring
Pkg. #6
BT Stiffening Plate
Amsoil
K&N
Shark Fin
Lockpick3+ & EV
Scan Gauge II
42/40
Weather Tech Mats
lplate is offline
Old 06-03-2008, 11:55 AM   #18
Sheepdog
C'Mere Sheepie!
Sheepdog's Avatar
Friends: 5
"If the Pulstar plugs provide an ROI then that's a win. At $100 for a set and 5% increase in mileage, they would break even roughly a little under 50,000 miles, the manufacturer's listed life span. Then you start all over again. :>) "
maybe its just me... but why would I buy these if their is no advantage?
Sheepdog is offline
Old 06-18-2008, 05:09 PM   #19
butchbs1985
Taking things apart is fun!
Send a message via AIM to butchbs1985
So..... What happened to answering ANY questions?
My boss found this if anyone cares to find out more: GB: Official Pulse Plug GB Thread, Mazda 3/6 Pulse Plugs...................
butchbs1985 is offline
Old 06-21-2008, 12:47 AM   #20
Sheepdog
C'Mere Sheepie!
Sheepdog's Avatar
Friends: 5
Funny the so called "not trying to sell you guys" guy left so soon. He must not have thought Prii drivers were not all that smart and would be a slam dunk. Im all for better parts to make more power and better mpg at less pollution but his price was just too much for too little benefit.
Sheepdog is offline
Pulstar Pulse Plugs thebradens3 Prius Main Forum 24 11-28-2008 07:16 PM
Prius faster than 07" HCH? Locust43 Prius Main Forum 42 11-18-2006 06:08 PM
Oh, so a Hummer is NOT greener than a Prius Tideland Prius Prius and Hybrid News 6 10-11-2006 10:43 AM
Can we "pulse and glide faster?" windstrings Fuel Economy 6 10-12-2005 02:32 PM
NYC tries to make yellow cabs greener NuShrike Prius and Hybrid News 1 07-01-2005 01:48 AM
