| Notices |
| Fuel Economy This is a discussion on Nitrogen Results within the Fuel Economy forums, part of the Toyota Prius Forums category; regular air has o2 witch will burn/explode n2 don't.so the main reason for n2 is to prevent explosion and fire ... |
| nitrogen mileage improve |
| | #21 |
| junior member Join Date: Dec 2007 Location: el cajon
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | regular air has o2 witch will burn/explode n2 don't.so the main reason for n2 is to prevent explosion and fire due to high heat generated by tires going from 0 to 180 mph in less than one second AND SPECIALLY to prevent tire fires due to hi heat generated during the breaking cycle trying to stop 150 tons from 180 mph to a full stop in a few seconds (like the airliners,military,nasa) but i don't believe it has much to do with significant mileage. improvement |
| | #22 | |
| Senior Member Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
I'll name just one thing I find of value that hasn't made money for someone. A hug. I got one from my little girl last night. She said: "Daddy, I didn't make anything special for your birthday, but I have this for you." She gave me the hug of a lifetime and wouldn't let go. No money maker in that one, but the value is measureless. NASA and Nascar may use it, but they have uses and purposes that go beyond the ken of the driver of a passenger car. I don't think it is practical to have explosive bolts on my car door, nor do I need a full roll cage and a head restraint system to keep my helmet in the correct position. If I drove as fast as those guys and kept only inches from my neighbor's bumper, well, then, I would consider some of these things. Again, the only reason I see for using nitrogen (and it better be 99% pure) is to keep from oxidizing my tires or my alloy wheels. I'll be replacing the tires due to exterior tread wear first, anyway, so I just don't see the value of the extra cost. More than that, I check and fill my tires in my own driveway, so I wouldn't want to be limited to going to a specific place just to get the tires back up to proper pressure. (Oh no -- there I go again. Sorry.) | |
| | #23 |
| C'Mere Sheepie! Join Date: Mar 2008 Location: Sanford FLorida
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Priori, I did not intend to come off testy or angry. I apologize if you read it that way. I personally have no investment in N2. I use it because it is free to me. It has not made a difference in mpg for me so far at 3K miles. I may never know if it has real safety benefits for me. I may never know if it has any real benefits at all. I was defending it mostly from folks who seem to think it pure bunk and I believe that it is not bunk. It is just one more safety percentage in my bag of tricks. It's funny that people that are so forward thinking can be so closed minded on something thats proven already. If it doesnt come from Japan or from a particular church of thought and show immediate mpg, it's disdained. It's just one of the ways some in this forum have prejudices that confuse me.
__________________ Sheepdog- Protecting my flock 2008 Barcelona Red "Lil Rachel" ![]() A Greyhound in the back seat can't hurt! Mods: Rear Bumper Pad, Hood Deflector, No Reverse Beep, Garmin 660 GPS unit, Zaino and Aerospace 303, wheel rings gone, Scan Gauge II, tire inflation at 42/40, PriusChat decal! |
| | #24 |
| Senior Member Join Date: May 2008 Location: Navarre, Florida
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | An invaluable thing, a daughter's hug. Perhaps the reference should have been to financial value. I doubt you have assigned a dollar value to that hug. |
| | #25 | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | Quote:
Filling tires with nitrogen is not pure bunk, but the benefits are very specific and not particularly valuable for passenger cars. Briefly, here are the issues: 1) Tire pressure - Nitrogen in tires behaves as an ideal gas. Its pressure rises and falls with temperature just as any other ideal gas. The diffusion rate of nitrogen is slightly higher than air, which means nitrogen will leak through tires at a slightly faster rate than air. The diffusion rate for both nitrogen and air is so low that this is not an issue. Water vapor is not an ideal gas. The partial pressure of water vapor will vary with temperature more than that of dry air or dry nitrogen. Removing the water vapor from air or nitrogen reduces tire pressure variation as related to temperature. Being able to consistently predict pressure variation is the main reason race cars use dry gas in their tires. Nitrogen canisters provide a convenient and relatively inexpensive source of dry gas in a race track environment, which is the principal reason that nitrogen is the dry gas of choice. Aircraft also use dry nitrogen for this reason. 2) Oxidation - Nitrogen does not promote oxidation, which means that rims and tires will not oxidize on the inside of a tire filled with nitrogen. Oxidation rates with air are so low that this is not a significant advantage. Tire oxidation is much larger on the outside where the tire is exposed to fresh air and sun. Wheel corrosion occurs along the bead seal where it is exposed to the outside elements. Nitrogen fill does not help with either of these. 3) Fire - Nitrogen does not support combustion. This is a real advantage for aircraft and race cars. Its value for passenger cars is minimal if not zero. Passenger car tires are never internally heated to the point where combustion could occur on the inside of the tire. Nitrogen on the inside of a tire does nothing to protect the tire from external combustion. Given these facts, the only real advantage of using nitrogen for passenger car tires is in eliminating or reducing water vapor. The process of producing liquid nitrogen removes all water vapor, so nitrogen expanded from liquid is dry. This is where the whole tire shop nitrogen pitch gets interesting. Tires shops do not get their nitrogen in this fashion. Instead they use a device which increases the concentration of nitrogen in ordinary air. Typically this device has some sort of coined name like "nitronizer" or something of that nature. Ordinary air is almost 80% nitrogen, so the increase is marginal. The important factor is the removal of water vapor, which is the same whether using a "nitronizer" or ordinary air compressor. There is no advantage to using nitrogen fill from a "nitronizer" verses air from a quality air compressor, assuming both use the same desicator. Tom
__________________ Black 2006 package #7 Northern Michigan | |
| | #26 |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The saturation pressure of water vapor tells you the partial pressure of water vapor if the air is saturated with water vapor. It only increases 0.8psi between 50 and 100 degrees F. That's why the effect of temperature on humid fill air is insignificant at the temperatures passenger car tires experience. Between 100 and 212 degrees F, it increases 13.7psi. That's why race cars require dry fill air. Their tires operate in temperature ranges where the partial pressure of water vapor would significantly change the pressure in the tire. Passenger car tires don't operate at those temperatures, so the effects of humidity in the fill air are much less. Water Vapor and Saturation Pressure in Humid Air
__________________ 2009 Toyota Camry Hybrid Black (hers) JBL Audio, Bluetooth, Moonroof, Alloy Wheels, Pink Fuzzy Dice on rearview mirror 2005 Driftwood Pearl Pkg #6 (mine) Katzkin Leather Interior Diamond Audio D661s Component Speakers JL Audio 8W3 Subwoofer JL Audio CleanSweep CL441dsp MTX Thunder 564 Amp 4x100 watts MTX Thunder 421D Amp 1x300 watts OEM Sirius Tuner 2004 Super White Pkg #9 (hers) - sold |
| | #27 | |
Another point is that most tire shops mount tires with water based lubricants. First you slop a bunch of water inside the tire, then you charge extra for "dry" nitrogen. Tom | |
| | #28 | |||
I have a very strong bent toward scientific analysis, but this often gets in the way of dealing with values that have no measurable quantity. I hope not to have contributed too much (just my fair share!) to your confusion over the reasons behind people's varied responses to ideas and questions on this forum. | |||
| Nitrogen Air Fills | CaptainMatt | Prius Main Forum | 34 | 11-06-2007 11:40 PM |
| Nitrogen Self-fill | partipilo | Fuel Economy | 5 | 10-05-2007 11:13 PM |
| Is nitrogen really better? | paprius4030 | Care, Maintenance and Troubleshooting | 36 | 02-19-2007 02:15 PM |
| I put Nitrogen in my tires. | TJandGENESIS | Environmental Discussion | 91 | 02-01-2007 07:44 PM |
| Nitrogen Instead of Air in Tires | YBLee | Prius Main Forum | 33 | 05-26-2006 10:03 AM |
