| Fuel Economy This is a discussion on New SGII- What settings do you use? within the Fuel Economy forums, part of the Toyota Prius Forums category; Hi all. Intimidated is the word. I will set it up tomorrow hopefully. But not sure about setting for daily ... |
| C'Mere Sheepie! Join Date: Mar 2008 Location: Sanford FLorida
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Hi all. Intimidated is the word. I will set it up tomorrow hopefully. But not sure about setting for daily use. Does the gauge start off with settings for mpg, soc, rpm etc already? I will be reading the manual tonight after getting home (RTFM!) just hoping for any hints I need that I might miss. Thanks ![]() |
| Senior Member Join Date: Apr 2007 Location: Wakefield, MA.
My Car: 2007 Prius Package: G Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Set-up is easy. Just take your time. You will be setting it for hybrid mode, 1.5 liter engine size, and 9 or 10 gallon tank depending on your preference. The hardest part for me was finding the OBDII port to plug it into. SOC is one of the x-gauge things you need to program for. Duh. The settings I use are: RPM SOC wFT mpg Last edited by Neicy; 05-14-2008 at 11:50 PM. Reason: To answer the question! |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Near your right shin when you are sitting in the drivers seat. I use RPM, WT, IGN, GPH. I don't see many people discussing GPH, but I am convinced this may be the best feedback of all. It is somewhat redundant because it is fuel flow per unit time and you already have Instantaneous MPG from the MFD. However, it has an interesting math relationship to iMPG: MPH / MPG = GPH Jimbo has his theory that the acceleration rate should be so that the iMPG is about 1/2 of MPH on the speedo - this is GPH = 2. I find it pretty easy to accelerate and keep GPH between 1.8 and 2. Hobbit has talked about 60 MPG @ 60 MPH -> GPH = 1 I am able to hold GPH = .5 @ 50MPH -> iMPG = 100 mph on the flat parts of my commute subject to wind, traffic, etc. The combination of RPM, IGN and GPH let me know when I am in stealth mode -> RPM = 0, IGN = 5, GPH = 0 (sometimes 0.01 but I believe this is roundoff error) Warp Steath is RPM ~ 960, IGN =5, GPH =0. Super Highway Mode is RPM ~ < 1600, IGN = 14 , GPH ~ .3 - 1.0. When GPH gets around .2 with low demand, I know it is about to go to WS, so I can adjust to keep GPH @ .3 or a little higher if I want to keep it out of WS. Last edited by dogfriend; 05-15-2008 at 03:11 AM. |
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | wow Dogfriend, Thats a lot of info in a small space! It is gonna take me a bit to internalize and be able to use info like that on the fly. If it werent for forums like this would anyone ever know all this I wonder? Thanks. |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Here is a lot of info in a small space: Prius Stages of Operation & Operating Mode Availability -A Reference Aid |
| Junior Member Join Date: Apr 2008 Location: Liberty Lake WA
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Here is the list of XGauge modes, including the specific ones for the Prius: http://www.scangauge.com/support/pdfs/XGAUGE.pdf Pat |
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
I've seen exactly the values you list for stealth. cool. If I understand Hobbits 60/60 gph=1 all I have to do is keep the gph at 1 or less while at 60mph and I get 60 mpg? I will try that. The KB above opens to an empty pdf for me. drat. | |
| Junior Member Join Date: Mar 2008 Location: Flemington, NJ
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I use the engine coolant temp and RPMs because I miss those gauges from my last car. I also use the instantaneous MPG and the MPG for the current trip (which I had to set in xgauge). I prefer the ScanGauge MPG over that of the MFD because ScanGauge MPG goes up to 9999. I expect that I will tweak these selections as I get to be more conscientious in my driving and learn better how to drive the car for optimum FE. |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Quote:
Too bad about the PDF - it downloads and opens for me. It is a one page summary of the five stages of operation, plus short summaries of the different techniques used to maximize mileage. | |
| speedometer settings | volumedude | Prius Main Forum | 11 | 04-12-2008 12:06 AM |
| Wanted: Used SGII | kdk84 | Prius Modifications | 0 | 05-17-2007 09:46 PM |
| SGII Commands | Dan. | Prius Technical Discussion | 2 | 04-15-2007 08:26 PM |
| Bluetooth settings | densaer | Audio and Electronics | 6 | 03-15-2005 11:16 AM |
| speedometer settings | volumedude | Knowledge Base Articles Discussion | 0 | 12-31-1969 07:00 PM |
