Notices
Fuel Economy This is a discussion on Declining MPG in 2004 within the Fuel Economy forums, part of the Toyota Prius Forums category; Originally Posted by smithBYU85 ... Do you think changing those fluids (coolant, transaxle, etc...) would make a big difference? ... ...
2004, declining
Old 08-08-2008, 08:41 AM   #11
bwilson4web
bwilson4web's Avatar
My Car: 2003 Prius
Package: #1
Nominated 2 Times in 2 Posts
Friends: 7
Default Re: Declining MPG in 2004
Before changing my transaxle oil, I did a series of 'hill rolling tests' in cold weather and found the first change made a significant improvement. If you plan to change the transaxle oil, see if you can find a very shallow hill near your home that you can do a "roll down" test over a week. You want the start to be such that your car comes to a stop by itself, using "N" and the engine off _IF_ _SAFE_.
Get the transaxle oil changed and repeat the hill roll down test and share the results.
I have not been able to do a 'warmed', hill rolling test. Even the old oil, when the car was warmed, would reach the end with significant velocity. In my case, the temperatures were around freezing.
Also, what are your front and rear wheel alignment numbers? Rough roads or stress can throw the toe and camber off enough to increase tire drag. Also, what tire size, make and model, are you running now?
Rolling resistance is bad news because it robs performance all of the time. That is why my first efforts have and remain focused on reducing rolling resistance.
bwilson4web is offline
Old 08-08-2008, 09:08 AM   #12
mikepaul
mikepaul's Avatar
I don't mean accelerate so slowly as to make other drivers mad at me, but to keep from really revving the engine. I haven't decided if a slow acceleration or a brisk acceleration to the speed limit is the best, I'm still evaluating that.
That 'revving' thing does eat into your MPGs, but normally a brisk takeoff doesn't do that if your drive battery is happy.
Ever since it got HOT here, I've had battery issues where it goes pink on me almost daily. It's an odd cycle: when it's pink the engine runs more (POOR acceleration since the electric motor won't help) followed by not-quick recharging until everything is normal again. Then later, when going up more than a few hills, I'll notice that the battery is low again like it 'forgot' to maintain charging. I'm wondering if the vent in the backseat needs cleaning or something, to get more of the A/C down there to help the battery...
2004 Seaside #9/BC as of 1/3/2004
Oil now any GOOD synthetic I can get on sale
Goodyear TripleTred 195/65R15 tires since 5/19/05
80,000 miles as of 8/22/2008
mikepaul is offline
Old 08-09-2008, 02:30 PM   #13
smithBYU85
smithBYU85's Avatar
I waited to post so I could try to find those numbers, the dealer gave them to me when I changed my oil a few weeks ago but I can't find the paper that they gave me. If I find them I'll get back with you. I'm about to move out of my apartment so I have stuff in lots of places while I pack.
smithBYU85 is offline
Old 08-14-2008, 12:22 PM   #14
richard schumacher
nacreous lacquer
- I drive with the A/C off as much as possible despite the 90+ temps here
BZZT! *Do* use the A/C, because it also cools the battery system. If you feel too warm then so does the battery. When the battery gets too hot it will throttle itself, and that reduces MPGs.
richard schumacher is offline
Mileage Declining - 3 yr old 2005 model LarryBA Fuel Economy 10 01-01-2008 12:47 PM
Gradually declining MPG bill602 Fuel Economy 12 05-13-2007 11:40 AM
Mexico's largest oil field declining faster than predicted? burritos Environmental Discussion 9 02-11-2007 08:57 PM
Salsa, #7, no, #9, April 23, 2004, no, June 2004 clubmedic Order Tracking 6 01-03-2005 09:04 PM
Driftwood Pearl, 2004 BC package, ordered May 7 2004, Fresno knowledgeseeker Order Tracking 0 09-19-2004 09:48 PM
