| Notices |
| Fuel Economy This is a discussion on 172 miles on the first pip within the Fuel Economy forums, part of the Toyota Prius Forums category; I have a 2008 with almost 7000 miles. I average 53 to 55 MPG per tank. I have consistently logged ... |
| miles |
| Member Join Date: May 2008 Location: Earth
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have a 2008 with almost 7000 miles. I average 53 to 55 MPG per tank. I have consistently logged about 100 miles on the first pip. I thought my guess gauge was malfunctioning when I looked this morning and notice 172 miles driven with all 10 pips remaining. I know it is a guess gauge. But should I be concerned about the guess gauge not guessing correctly any longer? |
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | No worries, perfectly normal. I've gotten as little as 50 miles in the winter and as many as 250 in the summer. There are lots of threads on the subject and how the flexible fuel bladder affects the (non-linear) gauge. You might consider searching if you want to learn more. |
| Senior Member Join Date: Oct 2007 Location: Gilbert, AZ
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Yep, when it's hot I'll typically get up to 160 or 170 on the first pip...and in the winter I'll get 50 miles or so. It's just how stretched out the bladder is. If I fill up the Prius in the middle of the afternoon on a 110 degree day it will take more fuel in the stretched out and pliable bladder than it does if I fill it up in the evening. |
| Junior Member Join Date: Aug 2008 Location: Pennsylvania
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hummmm.... what am I doing wrong? I am a brand new owner and have 175 miles on my first tank full and I am down 5 of those little lines... Hummmm Very scary. |
| Member Join Date: Jul 2008 Location: Maryland
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
Give it some time -- and a few tanks -- and don't panic. Meanwhile, as I suggested to the OP, the search button is a wonderful tool. | |
| Junior Member Join Date: Jun 2008 Location: Las Vegas Nevada
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | That's about right, we get an average of 194 on the first pip, and now seeing how many miles per pip is. We're down to the last four pips, so I am sure it won't be long to give the numbers. But when you fill up, when the pump stops, just don't stop there, it can take quite a bit more than you realize. At 210 miles on the first pip, the pump stopped at 1.67 gallons, and we were able to keep pumping till we got over 5 gallons, then we divided the mileage to the gallons of gas we put in and all we are averaging is 40 to 42mpg city. |
| Senior Member Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
See the following thread showing how damage made a believer out of another PC member. | |
| Senior Member Join Date: Dec 2007 Location: Stewartstown, PA.
My Car: 2008 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I also get a whole lot more miles before I use up a pip after a full tank. It is perfectly normal. |
| Toyota Fuel-Cell Logs 2300 Miles In Seven Days, Averages Well-Above 300 Miles Per Tank | Danny | Prius and Hybrid News | 21 | 11-29-2007 11:58 AM |
| trip odo in miles and km or just miles? | ranmandx | Prius Main Forum | 3 | 06-06-2007 09:49 PM |
| 200,000 miles? Psh, how does 250,000 miles sound? | Tideland Prius | Prius Main Forum | 5 | 08-30-2006 02:34 AM |
| CPU updates @ 5,000 miles & 10,000 miles - Mileage chngd | Ken Cooper | Fuel Economy | 2 | 09-09-2004 01:19 PM |
| miles per gallon vs. miles per dollar | jamarimutt | Prius Main Forum | 27 | 06-01-2004 01:37 PM |
