| Notices |
| Fuel Economy This is a discussion on Mileage vs pump calculating within the Fuel Economy forums, part of the Toyota Prius Forums category; The standard most often used for retail gas pumps is a maximum error of one cubic inch plus one cubic ... |
| calculating, mileage, pump |
| | #11 |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | The standard most often used for retail gas pumps is a maximum error of one cubic inch plus one cubic inch per indicated gallon, but never less than two cubic inches. For five gallons, this means an allowable error of +/- six cubic inches, which works out almost exactly to your +/- 0.5%. Tom |
| | #12 |
| I feel pretty, oh so pretty. Join Date: Apr 2005 Location: Lubbock, TX
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I would concur with the other sentiments of MFD best one tank measure, calculated best long term measure. Something I have noticed because of the combination of the variable bladder and temperature volatility is that calculated tanks can be very disparate with the MFD on an individual tanks. I have had several occasions when I would fill-up in a cold snap and by the time the next fill-up was needed, the temperature would be 20-30 degrees warmer. Nevertheless the calculated mpg would be extremely low. The opposite has occurred with warm spells then filling up in a cold snap.
__________________ "Miren al pepino. sus suaves movimientos tal como mantequilla en un chango pelon." ("Watch the cucumber. Oh, how smooth his motion like butter on a ... bald monkey.") |
| | #13 | |
| Senior Member Join Date: May 2008 Location: Marietta, Ga
My Car: 2008 Prius Package: #3 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Quote:
Second: Your MDF mileage may actually be the more accurate. I'm assuming the GPS usually shows less mileage than the MFD. This may vary by GPS brand and sofistication of the software. It's inherit to GPS since GPS is basically 2 dimentional and tracks your mileage by plotting the distances between a series of points. It does not necessarily take in the terrain. Just as your mileage can vary on a windy road between two points from that of the distant as the crow flies. There's even a greater diffence ove hilly terrain. My assumption is that your GPS would be dead on with your MFD driving across I-40 in Oklahoma, as long as you didn't drive around for 10 minutes in the parking lot to keep the toddler in the back from waking up, while your spouse ran in to get something at the grocery store; while there would be quite a discrepency driving on the Blue Ridge Parkway through Virginia. The first I'm sure of, and yes, averaging it over number of fillups would average it out, but any single fillup could be way off thr average. The second is only speculation. Hope this helps.
__________________ Dave & Joan, wishing all "Happy Motoring" 2008 Prius Touring CVT on-order, Seaside Pearl, Dark Grey Leather, Pkg#3 2000 Toyota Avalon XLS, Silver Spruce, 111K+, Extremely satisfied original owners. | |
| | #14 |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | we can argue accuracy of one over the other until the cows come home and it will do no good since both measure different things. 1) the MFD tells how how far we drove on said amount of gas...period...if straight miles per gallons is all you need, then this is it. 2) the pump tells the volume of liquid was put into the tank. why is this different? ignoring measuring inaccuracies of the pump, we also have to consider contamination (albeit, very low we hope but hardly nonexistent) and evaporation. sure the bladder helps. but it does not eliminate the possibility. i think we can all agree that the pump gallon calculation will be higher (or mpg will be lower...) than the MFD number... not by a lot...less than 2% for me anyways...but that is what it will always be. and one parting comment about the claim that "manual calculations always work if the tank is filled to the same level".... i say it works because there is usually nothing else to dispute the results.
__________________ My 2006: Last tank 463.1 miles @49.2 pump (49.4 computer) 4.22 cpm winter mpg 50.70 summer mpg 54.59 lifetime: 33,038.3 miles 52.79 mpg pump (54.04 mpg computer) 5.74 cpm My 2007 Zenn Driven 5945 miles, 2.01 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh Savings over my Prius $302.66 The Corolla...573.26 The REAL SAVINGS from not driving Corolla 657.39 +Prius= 958.18 (excludes maintenance costs...would be unfair to ICE vehicles) My Plate: DUALPWR (Dual Power) |
| | #15 | |
At least, that's how I understand it and that's all I was trying to point out. Last edited by dwreed3rd; 08-21-2008 at 08:11 PM. | |
| | #16 | |
| Junior Member Join Date: Aug 2008 Location: Ft. Worth, TX
1. Speedometers are never totally accurate. Easy way to check your odometer ... get on a nice long stretch of highway and check your odometer agains the mile markers for at least 10 miles ... 20-25 is better. I have routinely done this for years all over the US. Usually I am only off about 1 or 2 tenths in 10 miles, but I have had some cars WAY off. 2. No two gas pumps will kick off at the same point of filling your tank. The shutoff is controlled by air pressure and THAT can be affected by temperature, how fast you are filling, how the nozzle is in the tank. etc. Keep in mind ... THERE IS NO SUCH MEASUREMENT AS MILES PER TANK ... I emphaises that for the people who are stuck on that number. Miles per gallon has been a standard for over 100 years. Your MPG per tank will not always be the same ... but over many tanks ... it will get closer and closer to being accurate. Also, on the Prius ... or most cars built in the past 20 or 30 years ... DO NOT FILL PAST THE SHUTOFF ... your pollution equipment requires that headroom built into your tank to work right. Unless, of course, you are trying to damage your pollution equipment. | |
| | #17 |
My Car: 2008 Prius Package: #3 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | BTW I want to stand corrected on a misconception that I had. Looking at the illustrations in the Bentley manual, I misinturpreted the Fuel filler pipe and the Air vent's entry into the tank. I thought that the bladder was for the air space and the gasoline went into the tank. I had it backwards. The gasoline does go into the bladder, and the air space is the area surrounding the bladder inside of the tank. This post is not for those members that already understood this, except for an apology for my ignorance, but for those members that did not know and that I may have misled. It's scary though. I think I'm beginning to understand how it works and what is behind some of the fueling issues. ![]() |
| ABS pump replace, does bleeding the brake lines get rid of air that might be in the abs pump? | john1 | Care, Maintenance and Troubleshooting | 2 | 05-10-2008 12:48 PM |
| Calculating MPG's | EarthFriendly | Fuel Economy | 17 | 12-12-2007 01:23 PM |
| Calculating mileage of recent trip | ystasino | Prius Main Forum | 0 | 06-15-2007 11:59 AM |
| calculating gas savings | finman | Prius Main Forum | 22 | 11-09-2004 10:25 AM |
| Calculating the wait | richardgy | Prius Main Forum | 11 | 02-16-2004 04:15 PM |
