This is a discussion on List of known hacks / "easter eggs" ? within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by Brent Navigation Motion Override 1)Push MENU Button on bezel 2)Tap the VOLUME soft button 3)Tap top left ...
LinkBack (29) Thread Tools
Old 03-01-2008, 01:07 AM   #101
4rosey
Default Re: List of known hacks / "easter eggs" ?
3)Tap top left of screen (where the speaker icon is), then the bottom left, then top left again and finally the bottom left again.
**Perform these taps in rapid sequence. Do not be tentative or it might not work.
4)The Service Menu should appear.
5)Press and hold the OVERRIDE soft button until it beeps and is highlighted.
Full NAV function should now be available until you shut down the car. This can be engaged while in motion but must be repeated each time the car is restarted.
Be cautious experimenting within the Service Menu as you could cause yourself some problems with your Prius is you push the wrong combination of buttons.
I followed the above instruction and was never able to get into the Service Menu. I have successfully used the Hack that gets you to the diagnostic menu but not this highly desired one to override the motion lockout. I have a 2006 prius, is there a different hack for it???
4rosey is offline
Old 03-02-2008, 08:10 PM   #102
brad_rules_man
brad_rules_man's Avatar
Model: V
Package: Adv. Technology
I believe it was earlier noted that you cannot do it in the 2006+ models.
brad_rules_man is offline
Old 03-31-2008, 01:08 AM   #103
FlyEaglesFly
FlyEaglesFly's Avatar
Is there a hack to display the interior temperature? The auto AC setting needs to know. I'd like to be able to see it on the MFD. Any help would be appreciated.
FlyEaglesFly is offline
Old 04-01-2008, 05:30 PM   #104
priuseeker
priuseeker's Avatar
Anybody know how to get the Nav. unlock to work on an 2008 Prius. The one's listed seem to work on the previous version Nav's, not the upgraded 2008 version.
priuseeker is offline
Old 04-02-2008, 12:12 PM   #105
Rich96c4ce
Rich96c4ce's Avatar
Default Webmaster, please.....
Webmaster: How about making a folder file on the tool bar for holding a file for Hacks, and TSBs? That way there is no need to ask or search?
Rich96c4ce is offline
Old 05-03-2008, 04:40 PM   #106
nbali04
About to get an 08 Prius and would love to know if a hack exist for the 08 to use the Nav while driving. Any update on this?
nbali04 is offline
Old 05-14-2008, 01:54 PM   #107
DickW
Package: #5 Touring
No hacks found for my new 2008 Prius with nav ver 7.1. Do NOT buy the CoastalETech Basic Lockpick 3 for this purpose. IT WILL NOT WORK.
DickW is offline
Old 05-20-2008, 01:42 PM   #108
Chris27
Chris27's Avatar
Package: #5 Touring
I have a new 2008 my self.
The only things I have found to work as a easter-egg/soft hack are the following:
1) Disable/Enable reverse Beep
2) Diag Menu (while car is on, hold the INFO button and turn light on and off three times)
Chris27 is offline
Old 05-21-2008, 01:31 AM   #109
ufoPilot
ufoPilot's Avatar
Chris,
Which Dialogue Menu? Can you explain which light you turn on and off three times?
ufoPilot is offline
Old 05-21-2008, 05:39 PM   #110
ryanmorley
Originally Posted by ufoPilot View Post
Chris,
Hold the info button and turn your headlights on and off three times...
When I did it my lights began in the on position and my fog lights were on the whole time.
ryanmorley is offline
easter eggs, hacks, list
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-audio-electronics/11929-list-known-hacks-easter-eggs.html
naugess's Network on Delicious This thread Refback 05-10-2009 02:04 PM
t.earthman's Network on Delicious This thread Refback 05-09-2009 11:07 PM
Vrouwen in een prius zijn hot, hack je prius - Hyves.nl This thread Refback 01-16-2009 04:01 PM
Vrouwen in een prius zijn hot, hack je prius - Hyves.nl This thread Refback 01-16-2009 10:17 AM
List of known hacks / "easter eggs" ? Post #6 Refback 11-21-2008 12:41 PM
desyl's Bookmarks on Delicious This thread Refback 10-06-2008 03:54 AM
MADD vs. GTA4, Google's Orkut, and the Nerf Autocannon - Around the Web by ExtremeTech This thread Refback 06-22-2008 01:41 PM
MADD vs. GTA4, Google's Orkut, and the Nerf Autocannon - OS, Software & Networking by ExtremeTech This thread Refback 06-08-2008 05:41 AM
Archive for DIY : Green Options This thread Refback 05-26-2008 03:20 PM
Archive for hacks : Green Options This thread Refback 05-21-2008 04:57 PM
Gas 2.0 - Biofuels + Advanced Design Vehicles = A Revolution This thread Refback 05-14-2008 06:22 AM
Archive for Fuel economy : Gas 2.0 This thread Refback 05-11-2008 03:46 AM
MADD vs. GTA4, Google's Orkut, and the Nerf Autocannon This thread Refback 05-03-2008 01:43 PM
MADD vs. GTA4, Google's Orkut, and the Nerf Autocannon This thread Refback 05-03-2008 01:10 AM
MADD vs. GTA4, Google's Orkut, and the Nerf Autocannon This thread Refback 05-02-2008 12:37 PM
MADD vs. GTA4, Google's Orkut, and the Nerf Autocannon This thread Refback 05-02-2008 07:30 AM
MADD vs. GTA4, Google's Orkut, and the Nerf Autocannon This thread Refback 05-02-2008 05:37 AM
MADD vs. GTA4, Google's Orkut, and the Nerf Autocannon This thread Refback 05-02-2008 01:45 AM
Green Options » DIY This thread Refback 04-30-2008 03:09 AM
Archive for Fuel economy : Gas 2.0 This thread Refback 04-24-2008 10:54 AM
Gas 2.0 - Biofuels + Advanced Design Vehicles = A Revolution This thread Refback 04-11-2008 07:53 PM
Archive for fuel economy : Gas 2.0 This thread Refback 04-02-2008 12:15 PM
Archive for : Green Options This thread Refback 03-15-2008 03:13 AM
Gas 2.0 - Biofuels + Advanced Design Vehicles = A Revolution This thread Refback 03-13-2008 02:47 PM
Gas 2.0 - Biofuels + Advanced Design Vehicles = A Revolution This thread Refback 03-09-2008 08:52 PM
Archive for : Green Options This thread Refback 03-08-2008 01:22 PM
Archive for cars : Gas 2.0 This thread Refback 02-14-2008 09:35 PM
Gas 2.0 - Biofuels + Advanced Design Vehicles = A Revolution This thread Refback 02-13-2008 06:31 PM
Hybrid Hacks and Toyota Yawns? : Gas 2.0 This thread Pingback 01-27-2008 01:39 PM
List of hacks and easter eggs tag Knowledge Base Articles Discussion 3 11-30-2006 06:36 AM
Prius "Easter Egg" programming Charles Suitt Gen II Prius Audio and Electronics 2 11-16-2006 09:29 PM
GM's Bob Lutz: "Not All Eggs in Hydrogen Basket" clett Prius and Hybrid News 26 10-19-2006 11:28 PM
Any Fog light easter eggs or tips ? HAMMER55 Gen II Prius Audio and Electronics 1 12-20-2005 02:22 PM
Easter Eggs? tntna Gen II Prius Modifications 4 11-22-2004 10:13 AM
