This is a discussion on Backup camera with CAN-View within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I am taking the plunge and buying a CAN-view v.3 for my '05 Prius w/ NAV and would like to ...
Old 04-15-2006, 01:44 PM   #1
ltu1542hvy
I am taking the plunge and buying a CAN-view v.3 for my '05 Prius w/ NAV and would like to add a backup camera.For those of you who have a CAN-view with backup camera, which one did you use? I don't mind paying extra for a good one that is as easy as possible to install (preferably with night vision) without needing to splice, dice or tap any wires, if possible.
With the CAN-view Norm tells me I will need the LEK-CCR2SRGB converter from http://www.threedoubleyou.com/otherconverters.htm, and a custom cable that he provides. What else will I need to connect a camera to the CAN-view? Is there a camera that comes with connectors that simply plug right into this converter/custom cable combo?
I am not an electical engineer or an experienced auto stereo/accessory installer, so would like to keep this as simple as possible and I would like to know everthing that will be involved before getting into this.
Thanks in advance,
Bill
2005 Prius from January 2005 until December 2006
Mods: Mudflaps, XM radio (PriusXM), personalized North Carolina license plate (/dev/hyb), Treo 650 for BlueTooth connectivity, Coastal Tech EV switch, SunTek carbon-dyed window tint, VAIS AIC-100i iPod interface, BTtech chassis stiffening plate
ltu1542hvy is offline
Old 04-15-2006, 02:35 PM   #2
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
uh oh. D will be so jealous!
if ya need help or advice when installing, let us know.
galaxee is offline
Old 04-15-2006, 05:39 PM   #3
ltu1542hvy
I just sent Norm the payment a few minutes ago. The CAN-view should arrive in about 10 days, which unfortunately will be too late for our next PriusClub meeting. Judging by the instructions on his website the installation of the CAN-view itself looks straightforward enough, however I'm hoping I can talk Doug into giving me a hand with installing the camera once I figure out what to get and I could use some advice on that front as well.
Old 04-15-2006, 07:01 PM   #4
hdrygas
I don't know about best but I used the Costal Tech ( http://www.coastaletech.com/rear_view_camera.htm ) license frame camera. Dave does the wiring harness so it is Prius ready reverses and aims the camera so it is on the bottom of the frame so you can get at the hatch opener. You will have to tap one wire. I had the Toyota dealer do it for me during a routine 5K oil change. I did not want to run the wire from the back to the front. The converter box fits nicely under the Nav computer. It works well in low light but is not "Night Vision" The backup lights provide all the needed illumination even on a "Dark and Stormy Night". It is not cheep but is good.
Belle, a Millennium Silver '04 BC #9
"Becoming one with my Prius, ICE on ICE off"
Belle has been passed on to my daughter. I have a new silver Prius 08. No name yet we have just met but not been introduced.
hdrygas is offline
Old 04-16-2006, 04:40 PM   #5
vlenac
vlenac's Avatar
<div class='quotetop'>QUOTE(ltu1542hvy @ Apr 15 2006, 07:44 PM) [snapback]240212[/snapback]</div>
Thanks in advance,
Bill
Hi,
You can connect any NTSC camera with composite RCA connector to the LEK converter.You have a lot of conversation about this topic on Priuschat. One is:http: //priuschat.com/Recipe-for-a-rear-view-camera-t16338.html
The most complicated version of camera install (the original, expensive, Prius camera) will take you 6-8 hours of work. If you choose some other type of installation I think it will take you less time and complications.So, don't be afraid, the pleasure is great when all is done and working well...
original Backup camera,Can-view,Dell PC plugged in,HID retrofit
vlenac is offline
Old 04-16-2006, 08:32 PM   #6
mrbigh
Prius Absolutum Dominium
mrbigh's Avatar
<div class='quotetop'>QUOTE(ltu1542hvy @ Apr 15 2006, 01:44 PM) [snapback]240212[/snapback]</div>
Thanks in advance,
Bill
An alternative in this Thread
mrbigh is offline
Anytime Camera Mod. Another Variation. Front and Rear view camera. TheForce Gen II Prius Modifications 93 09-18-2009 05:02 AM
Always On Backup Camera walker.627 Gen II Prius Modifications 9 06-19-2008 09:35 AM
CAN-view cheapest way to get a backup camera in an '05? phileFriendly Gen II Prius Technical Discussion 2 07-25-2006 11:12 PM
Backup Camera View linothin Gen II Prius Main Forum 19 06-26-2006 09:00 AM
Backup Camera chiprius Gen II Prius Modifications 0 04-28-2006 01:10 PM
