This is a discussion on Bluetooth - Verizon RAZR 3M within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just bought the Motorola RAZR 3M (Verizon service) and I'm having problems pairing this device with my 2006 Prius. ...
Old 06-06-2006, 12:58 AM   #1
hairman61
On the Prius I go to Info/Telephone/Settings/Bluetooth/Register (I then get the "Connecting" screen)
On the RAZR 3M I go to SETTINGS & TOOLS/Connections/Bluetooth/Handsfree/[Look For Devices] (my phone then indicates that it is "Scanning..." for devices)
The RAZR indicates that a device was found but then puts up the message "Device Names Found: 0/1" and no device name is shown, and the Prius is still in the "Connecting" mode. I've tried this several times with no luck. The RAZR does correctly identify the Prius' BT device address.
Anyone else have this problem or having any suggestions how I might get this to work?
hairman61 is offline
Old 06-06-2006, 01:37 AM   #2
DaveinOlyWA
3rd Time was Solariffic!!
DaveinOlyWA's Avatar
try turning BT power on to the razr first THEN initialize the Prius connect
DaveinOlyWA is offline
Old 06-06-2006, 02:12 AM   #3
hairman61
<div class='quotetop'>QUOTE(DaveinOlyWA @ Jun 5 2006, 10:37 PM) [snapback]266514[/snapback]</div>
DaveinOlyWA,
Thanks for the reply.
Are you saying I should initiate the [Looking For Devices] on my RAZR first and then initiate the "Register" BT phone on the Prius? If so, it didn't make a difference.
Old 06-07-2006, 12:28 PM   #4
hairman61
I have successfully connected my RAZR 3Vm to my 2006 Prius. Earlier that day I had synched my phone book on my Mac to the RAZR via iSync and a device was created on the RAZR. When I deleted that device everything seemed to work fine after that.
Old 06-07-2006, 12:45 PM   #5
DaveinOlyWA
glad to hear you got it going. you should however be able to sync several BT devices. i have 3 devices sync'd to my LG phone. when i initialize power, the last device used is the one that will work or i can go into found devices and choose another one. but i do have a MAC and it does seem to present less problems
Bluetooth, RAZR and Verizon jcrowis Gen II Prius Audio and Electronics 3 02-22-2009 07:51 AM
Verizon Razr & Bluetooth Dano Gen II Prius Audio and Electronics 3 07-31-2007 05:46 PM
Transferring contacts through BT with Verizon Motorola RAZR V3c DougSlug Gen II Prius Audio and Electronics 3 06-04-2006 09:07 PM
Prius 2005 and New motorola Razr V3C from Verizon mithras Gen II Prius Audio and Electronics 8 04-25-2006 01:46 PM
Verizon Wireless Motorola RAZR V3c fredmertz Gen II Prius Main Forum 6 02-16-2006 01:02 PM
