| This is a discussion on Fix for Sirius Static within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(Otto @ Jul 28 2006, 10:21 PM) [snapback]294130[/snapback]</div> Anyone know where they install the receiver in a '06 package ... |
| | #21 | |
| What's the catch? Join Date: Apr 2006 Location: Richmond, Virginia
Friends: 2 | <div class='quotetop'>QUOTE(Otto @ Jul 28 2006, 10:21 PM) [snapback]294130[/snapback]</div> Quote:
To answer your question, you might want to ask the dealer where they installed it. Or you can do a search for satellite radio installation guides (Sirius or XM) and they might give you some places to start looking in the meantime. Hope this is at least somewhat helpful. | |
| | #22 | |
Friends: 0 | <div class='quotetop'>QUOTE(GeoGeek @ Jun 11 2006, 10:39 AM) [snapback]269495[/snapback]</div> Quote:
That shouldn't affect other input sources though, for the better or worse. | |
| | #23 |
Friends: 0 | Well thank you very much for making my investment in Sirius perform properly. I checked back in this forum specifically looking for the fix knowing it would come at some time. I had started a post here months ago, and many other were having the same issue. I used the connecters listed above from Radio Shack and they worked well enough. Soldered the wires up then proceeded to install them. After reconnecting the harness and turning the unit back on it defaulted to station 184. By simply changing the station manually I was able to dial in anything I wanted, and reprogram my favorite channels. No need to call Sirius to re-initialize. Thanks again! |
| | #24 |
| Senior Member Join Date: Mar 2004 Location: Southern California
Friends: 0 | Just wondering if someone would please repost the PDF file attached to the first post in this thread. The link to it is now broken. |
| | #25 | |
| Senior Member Join Date: Mar 2006 Location: Auburndale, FL
Friends: 0 | <div class='quotetop'>QUOTE(BMcGraw @ Aug 28 2006, 11:06 PM) [snapback]310936[/snapback]</div> Quote:
Enjoy, Matt | |
| | #26 |
Friends: 0 | Do owners of an '04 benefit from this static fix? Or is this problem not apparent in that model year? Thanks. |
| | #27 | |
Friends: 0 | <div class='quotetop'>QUOTE(luiset83 @ Aug 29 2006, 05:56 PM) [snapback]311310[/snapback]</div> Quote:
2004 & 2005 model year Prii; although I can only vouch personally for the result on the 2006. Regards, Matt | |
| | #28 | |
Friends: 0 | <div class='quotetop'>QUOTE(GeoGeek @ Aug 29 2006, 06:53 PM) [snapback]311336[/snapback]</div> Quote:
| | #29 |
Friends: 0 | Be sure to secure this fix tightly. I had mine jiggle loose on me. I noticed static on my right channel, re-secured the fix and now it's all good. |
| | #30 |
| WeePoo, Gen II Join Date: May 2006 Location: Palms, Los Angeles
My Car: 2006 Prius Model: N/A Package: #3 Thanks: 39
Friends: 39 | Bought my SiriusPrius about a month ago and just got around to the installation (THANK YOU v8cobrakid!). Turns out the unit Jon @ Factory Interactive sent me already had the fix done. It's FANTASTIC! The dog and I are sleeping in the car when the computer-feed stations just aren't enough! WOOO HOOO! Gotta LOVE that MFD! |
| fix, sirius, static |
| Radio static | chanterelle | Gen II Prius Audio and Electronics | 9 | 11-20-2008 12:56 AM |
| Prius Chat Store SIRIUS Kit & Static Issue | stevetanneyhill | Gen II Prius Audio and Electronics | 0 | 07-14-2007 09:49 PM |
| Help / Sirius 06 Package #8 / Delaer claims that the XM and Sirius Tuners are now same?? | DonC | Gen II Prius Audio and Electronics | 11 | 08-02-2006 01:30 PM |
| Sirius Static Fix | Mtichon | Gen II Prius Main Forum | 2 | 05-17-2006 04:13 PM |
| Static on my Sirius radio | AlphaTeam | Gen II Prius Audio and Electronics | 19 | 12-24-2005 11:19 AM |
