This is a discussion on Denison Ice Install Instructions. within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I looked on Denison's site but they don't "show" the Prius install. Is this posted with pics somewhere?...
Old 06-30-2006, 07:10 PM   #1
bshef
bshef's Avatar
bshef is offline
Old 06-30-2006, 07:22 PM   #2
ScottY
ScottY's Avatar
You might want to read thru this thread http://priuschat.com/Ordered-the-Den...nk-t13569.html
The ice:Link Plus locks up MANY times on the Prius. I m getting an exchange for the new DICE Ipod unit from Dension (now DICE).
ScottY is offline
Old 06-30-2006, 07:32 PM   #3
bshef
bshef's Avatar
<div class='quotetop'>QUOTE(ScottY @ Jun 30 2006, 04:22 PM) [snapback]279375[/snapback]</div>
Doh! What the hell did I just buy for $135?
bshef is offline
Old 06-30-2006, 07:35 PM   #4
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
<div class='quotetop'>QUOTE(bshef @ Jun 30 2006, 04:32 PM) [snapback]279381[/snapback]</div>
The new DICE unit. You can go to http://priuschat.com/index.php?act=A...e=post&id=3457 and use those instructions. It's for the VIAS, but it's the same procedure.
aaf709 is offline
Old 07-01-2006, 12:49 PM   #5
bshef
bshef's Avatar
<div class='quotetop'>QUOTE(aaf709 @ Jun 30 2006, 04:35 PM) [snapback]279384[/snapback]</div>
thanks.....
question...
-Do you HAVE TO disconnect the battery for this install?
bshef is offline
Old 07-01-2006, 01:36 PM   #6
LurkAzusa
I didn't disconnect the battery. Just be sure to have the ignition off and radio power off. I even turned off the SKS button under the steering wheel, just to be sure, too.
LurkAzusa is offline
Old 07-01-2006, 06:29 PM   #7
aaf709
aaf709's Avatar
<div class='quotetop'>QUOTE(bshef @ Jul 1 2006, 09:49 AM) [snapback]279718[/snapback]</div>
thanks.....
question...
I just installed it today. I didn't disconnect the battery. I simply had power off and the radio was off before I powered down.
aaf709 is offline
Old 07-01-2006, 08:50 PM   #8
bshef
bshef's Avatar
Got mine in!
Took about 35 mins......15 of it was figuring out I was trying to put the wrong plug into the back of the Stereo! doh!
I did NOT disconnect the Battery either!
I zip-tied the cables then shoved the whole dice unit into the cavity beside the stereo.....fished the Ipod plug through the bottom black panel just above the passenger floor leaving enough cable ipod cable for several different possible ipod locations.
Pretty happy with the functionality so far.
bshef is offline
Old 07-01-2006, 08:58 PM   #9
ScottY
ScottY's Avatar
bshef, do you have the new DICE ipod unit or the old ice>link: plus ipod unit?
In the title you said ice, now you said DICE. If you have the old ice>link unit, you might want to install it where it is easy to reset it (http://priuschat.com/index.php?showtopic=13569&st=60), since the old unit locks up once in a while. If you have the new DICE unit, then never mind.
ScottY is offline
Old 07-01-2006, 09:00 PM   #10
bshef
bshef's Avatar
<div class='quotetop'>QUOTE(ScottY @ Jul 1 2006, 05:58 PM) [snapback]279863[/snapback]</div>
I just bought it through the latest group buy that just started on June 16th! So........I think the "unit" said "Dice" on it!.....
The new DICE system includes an AUX Audio Input (for those of you without a 2006+), and has 3 different modes:
What exactly can I do with the Aux Audio Input?.....I have an '05 Prius!
bshef is offline
fog light instructions please dsyoo86 Gen II Prius Modifications 3 09-08-2007 03:18 AM
new denison unit error.....? bshef Gen II Prius Audio and Electronics 14 07-14-2006 12:46 PM
06 XM Radio Install Instructions SteveS Gen II Prius Modifications 1 06-29-2006 10:34 AM
BIG NEWS: denison icelink plus w/ ID3 text display! konakahuna Gen II Prius Audio and Electronics 4 12-01-2004 12:36 AM
Silver or White, #9, 12/1/03, Denison TX blindsay84 Order Tracking 0 12-30-2003 12:25 PM
