This is a discussion on External GPS system to use with the screen? within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 06 package #4, so I don't have a GPS navigation system in my Pri. My friend tells ...
Old 09-13-2006, 09:23 AM   #1
Michgal007
Michgal007's Avatar
I have a 06 package #4, so I don't have a GPS navigation system in my Pri. My friend tells me that I can get an external GPS system (just the tracker, DVD with maps and some kind of connector) and connect this to the car, so I can use the monitor (the screen) with it. [Not a full GPS navigation with voice recognition system that Magellen or any company like that offer].
Has anyone tried this?
Michgal007 is offline
Old 09-13-2006, 06:30 PM   #2
sl7vk
sl7vk's Avatar
<div class='quotetop'>QUOTE(Michgal007 @ Sep 13 2006, 09:23 AM) [snapback]318874[/snapback]</div>
No, but I'm seriously considering buying a gvn 52 from garmin and finding out if I can make it work.
sl7vk is offline
Old 09-13-2006, 07:43 PM   #3
Presto
Has his homepage set to PC
<div class='quotetop'>QUOTE(Michgal007 @ Sep 13 2006, 06:23 AM) [snapback]318874[/snapback]</div>
If you can get the maps on the screen, you'd need some way to control what's happening. There is no GPS kit that will allow a hookup to the Prius screen with touch capability. An easy solution would be a handheld, dash mountable GPS with display. There are quite a few out there for a couple hundred bucks.
Presto is offline
Old 09-14-2006, 12:31 AM   #4
auart
<div class='quotetop'>QUOTE(Michgal007 @ Sep 13 2006, 08:23 AM) [snapback]318874[/snapback]</div>
The garmin will work and be on screen but you will not have touch screen... you will use the remote control that comes with it.... The price is dropping so in a few months it will be better. It works with the onscreen MFD but no Touch screen is possible.
Check it out.........
http://www.garmin.com/products/gvn52/
auart is offline
Old 09-14-2006, 08:10 AM   #5
Michgal007
Michgal007's Avatar
<div class='quotetop'>QUOTE(auart @ Sep 14 2006, 12:31 AM) [snapback]319335[/snapback]</div>
Thanks!
Old 09-22-2006, 10:59 AM   #6
Frank Hudon
Expected Availability:
3rd Quarter, 2006
has anybody actually had one installed in a Prius and have it working properly?
Frank Hudon is offline
Old 09-23-2006, 09:57 PM   #7
keydiver
keydiver's Avatar
I've been looking for this solution for months, and, thanks to an email from sl7vk alerting me to the introduction of the Garmin GVN 52, I have placed an order for one. With shipping it came to ~$469, far less than the OEM integrated one. As someone else already pointed out, it doesn't respond to the touchscreen at this time, but some of their literature seemed to indicate that it has the intelligence to interface with touchscreens. Perhaps there will be an accessory kit someday for that, hopefully. But, I plan to do a full report as soon as I can get it installed.
* 2006 Package #3, Classic Silver Metallic
* Integrated Garmin GVN 52 Navigation System
* BT Brace
* Anytime Backup Camera Mod
* DVD/Video Input Mod
* EV switch using the headlight switch
* Infinity 63.7/60.7 Speaker Upgrade
* Heatshield Front and Side Reflector Shades
* Rear Bumper Protector
* Mudflaps
* Fumoto Drain Valve
keydiver is offline
Old 09-24-2006, 09:38 PM   #8
auart
<div class='quotetop'>QUOTE(keydiver @ Sep 23 2006, 08:57 PM) [snapback]324090[/snapback]</div>
Where did you buy it for that price?
Did you get the Garmin GVN 52 ?
auart is offline
Old 09-25-2006, 10:25 AM   #9
sl7vk
sl7vk's Avatar
<div class='quotetop'>QUOTE(keydiver @ Sep 23 2006, 09:57 PM) [snapback]324090[/snapback]</div>
Please do! Any suggestions on how to install it, once you've pulled it off would be highly desirable as well!
sl7vk is offline
Old 09-25-2006, 12:47 PM   #10
keydiver
keydiver's Avatar
<div class='quotetop'>QUOTE(auart @ Sep 24 2006, 09:38 PM) [snapback]324476[/snapback]</div>
Gemini Computers
keydiver is offline
external, gps, screen, system
after market improvements to on-board screen system? mikelly321 Gen II Prius Main Forum 0 10-30-2007 07:37 PM
System check screen jamarimutt Gen II Prius Main Forum 3 04-23-2007 05:23 PM
External System not connected TheForce Gen II Prius Care, Maintenance and Troubleshooting 8 03-23-2007 01:51 PM
Navigation System Caution Screen wguynes Gen II Prius Audio and Electronics 5 06-24-2005 01:02 AM
Adding External Navigation System... eck34 Gen II Prius Audio and Electronics 1 03-12-2005 08:22 PM
