| This is a discussion on 2007 Prius Navigation Lockout Disable within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just traded in my 2005 Prius for a 2007 Touring. The trick for the nav system lockout disabling on ... |
Friends: 0 | I just traded in my 2005 Prius for a 2007 Touring. The trick for the nav system lockout disabling on the 2005 (Volume screen, then upper left, lower left, upper left, lower left) doesn't seem to work. What's the trick for the 2007???? Anyone know? Jason |
Friends: 0 | I presume it's the same as for the 2006....cut the speed sensor wire and install a switch. You can see where that wire is here. Don't get fooled by Coastal's Ultimate Lockpick. It does the same thing as the override trick in the 2004-2005 so it won't work in the 2006-2007. |
Friends: 0 | <div class='quotetop'>QUOTE(aaf709 @ Oct 21 2006, 02:44 PM) [snapback]336182[/snapback]</div> Quote:
Friends: 0 | Really? I heard that that trick never worked on the 2006 and there are several threads (here is one of them) on this site to that effect. The 2004 and 2005 are another matter. |
| The One in the Middle Join Date: Jun 2006 Location: Carlsbad, CA
Friends: 0 | <div class='quotetop'>QUOTE(PriusJason @ Oct 21 2006, 05:02 PM) [snapback]336224[/snapback]</div> Quote:
| Senior Member Join Date: Jul 2004 Location: Claremont, California
Friends: 0 | So wait, you can disable the navigation lockout in an 04 without doing any kind of modification? Where can I find an explaination of how to do this? |
| Senior Member Join Date: Nov 2004 Location: Illinois
My Car: 2005 Prius Model: Package: #9 Thanks: 1
Friends: 0 | <div class='quotetop'>QUOTE(aaf709 @ Oct 21 2006, 03:44 PM) [snapback]336182[/snapback]</div> Quote:
| Platinum Member Join Date: Mar 2006 Location: Minnesota
My Car: 2006 Prius Model: Package: #7 Thanks: 39
Friends: 4 | There are several options for the speed wire defeat 1. nav speed sensor - cut the speed sensor to the nav, and you'll have full access, but the car will apear stationary on the screen until it's reattached/it updates location with a satelite. 2. BT speed sensor - cut this wire, and you'll enable full BT cell phone functionality, however the wheels on the energy screen will stop rotating, and the 5 minute bars on the consumption screen will come up 0 while it's disconnected. no information is lost (ie the overall MPG number still updates) except the 5 minute bars. reconnect to reenable these. If you want to wire in a video source, the best bet is to do the anytime reverse camera mod, which works in the same way as these... snip a wire, stick in a diode, and run it through a switch to another wire. Then you just have to put a switch on the video source (being the backup camera or DVD player). Of course, you also need to alter the output from the DVD player to be compatible with the MFD... info for all three mods (nav speed wire, BT speed wire, any time reverse camera) can be found on darell's website, http://evnut.com/prius_mods.htm |
Friends: 0 | <div class='quotetop'>QUOTE(LeVautRien @ Oct 22 2006, 10:37 AM) [snapback]336431[/snapback]</div> Quote:
You can go to here or here to see the proceedure with pictures. Do NOT try to play with the other buttons. While some are information, and others reset, there's one marked LOAD which tries to load the DVD while it's still in there. This will mess up your NAV system until it's reset, and that entails taking it apart to get to the reset button.
__________________ "Blue Belle" Seaside Pearl Purchased April 16, 2005 MODS: Wheelskin Steering Wheel Cover, GT Seat Covers, DashTopper Dash Cover, MFD Sun Hood, Pioneer AirWare XM radio, DICE Silverline iPod Integration, BT Override, Goodyear ComforTreds, Coastal Tech's Auto-Lock kit, NAV Enhancement kit & EV mod | |
| Disable DVD playback lockout while driving? | F8L | Gen II Prius Audio and Electronics | 0 | 10-21-2007 01:35 PM |
| 2007 Prius and the navigation hack | GatorJoe | Gen II Prius Technical Discussion | 4 | 07-18-2007 10:58 PM |
| 2007 Prius phones-Cingular-with Navigation-Help | I give up | Gen II Prius Audio and Electronics | 2 | 04-09-2007 10:07 PM |
| 2007 Touring Prius Navigation System | dcatsss | Gen II Prius Main Forum | 3 | 10-17-2006 03:27 AM |
| 2007 prius navigation | nmeyer79 | Gen II Prius Main Forum | 4 | 09-06-2006 05:29 PM |
