This is a discussion on quick hooking up an amp question within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I am about to hook up my amp and sub. I have the non jbl system and still plan on ...
Old 08-07-2007, 07:40 PM   #1
morpheusx
Professor Chaos
morpheusx's Avatar
I have the non jbl system and still plan on using the factory radio by tapping into the rears. My question is where should I connect the remote power wire to turn the amp off when not in use?
morpheusx is offline
Old 08-07-2007, 08:00 PM   #2
beboyle
beboyle's Avatar
<div class='quotetop'>QUOTE(morpheusx @ Aug 7 2007, 04:40 PM) [snapback]492116[/snapback]</div>
There isn't a good lead out of the radio, so you'll have to tap the aux power someplace. I used the center console aux power plug (the "cigarette lighter"). The panel that it is on pops off easily. Carefully pull out the single press-in anchor on the right side of the panel, then pull straight out. That will give you access to the back of the plug, which is powered only when at least ACC power is on.
beboyle is offline
Old 08-07-2007, 08:10 PM   #3
morpheusx
Professor Chaos
morpheusx's Avatar
<div class='quotetop'>QUOTE(Bruce Boyle @ Aug 7 2007, 08:00 PM) [snapback]492124[/snapback]</div>
Thanks, did you also tap into the rears for the signal? My plan is to convert the speaker level inputs then use a Y adapter to plug it into my 4 ch. amp and use 2 of the channels to go back to the rear speakers, the other 2 ch.s will be bridged for one subwoofer.
Old 08-07-2007, 09:03 PM   #4
oly_57mpg
oly_57mpg's Avatar
I've got the JBL system, so my knowledge of a non-JBL system could be wrong, but I think there is still an amp under the passenger seat. you should be able to tap the ACC wire from it if you didn't want to get under the dash.
oly_57mpg is offline
Old 08-07-2007, 09:25 PM   #5
Presto
Has his homepage set to PC
It shouldn't matter whether you tap the front or the rears in a non-jbl Prius. They both get a full signal. Since you're only adding a sub, the rears are a good place. I tapped into the power outlet in the center console for ACC power.
Presto is offline
Old 08-08-2007, 10:08 AM   #6
morpheusx
Professor Chaos
morpheusx's Avatar
<div class='quotetop'>QUOTE(Presto @ Aug 7 2007, 09:25 PM) [snapback]492159[/snapback]</div>
thanks exactly the answers I needed, in the past I have tapped into the fuse box but this is a much simpler solution.
Old 08-11-2007, 02:02 PM   #7
beboyle
beboyle's Avatar
<div class='quotetop'>QUOTE(morpheusx @ Aug 7 2007, 05:10 PM) [snapback]492132[/snapback]</div>
Sorry I didn't respond sooner, but you got good answers. Yes, I tapped into the rears and as others have noted it works fine.
beboyle is offline
Old 08-17-2007, 01:22 PM   #8
morpheusx
Professor Chaos
morpheusx's Avatar
Thanks, everything worked out great, I will post a few pictures of my small simple single subwoofer system later if I can remember when I get home. Sounds pretty good definitely was the kick that I was missing. By the way when I had the rear door panels off to trace back the speaker wire, I couldn't help but notice that the rear door speakers SUCK.... They are the equivalent of the $4 single speakers they sell in Target and Wal Mart, naturally I assume the front door speakers are equally as bad. So add that to the list as next. Does anyone have any suggestions for replacement rear door speakers that fit easily.
Current LIFETIME is 54.2 MPG
Old 08-17-2007, 10:29 PM   #9
morpheusx
Professor Chaos
morpheusx's Avatar
here are the pictures, definitely Factory Door speakers are next.
Old 03-11-2008, 01:59 PM   #10
martinisaacanywhere
Supa Memba
martinisaacanywhere's Avatar
Default Re: quick hooking up an amp question
Oly, do you know which wire to tap in the dash to get REM power?
martinisaacanywhere is offline
Quick Question Electron Gen II Prius Technical Discussion 1 11-06-2007 09:29 AM
Quick question Cherrie CA - Los Angeles 4 09-01-2007 11:29 PM
EV Mode Mod Quick Question SureValla Gen II Prius Modifications 9 07-15-2007 05:18 PM
quick question---trade in value kdailey356 Gen II Prius Main Forum 4 05-29-2007 06:59 AM
quick question seasidetraveler Gen II Prius Main Forum 5 03-09-2006 12:47 PM
