| This is a discussion on VAIS vs DICE vs?? within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I want to integrate my ipods into my system and use all funtions and read/select song lists.... Ok I've done ... |
VAIS vs DICE vs??
| Member Join Date: Aug 2005 Location: Minneapolis
My Car: 2005 Prius Model: Package: Thanks: 0
Friends: 0 | I want to integrate my ipods into my system and use all funtions and read/select song lists.... Ok I've done my research and am totally confused!!! which system gives you the most for the least, I have 2005,with Cassette/6CD/JBL/AM/FM with Nav.. I also saw a photo of an installation using the storage space below the radio....but can't find it now...anyone know where it is?? thanks Berkley |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 229
Friends: 23 | my car's identical except I have no nav and I have the DICE. It's about 1/3 the cost of a VAIS so if it's pure cost, then DICE wins. umm.. check the KB?? |
Friends: 0 | <div class='quotetop'>QUOTE(Tideland Prius @ Oct 11 2007, 06:33 PM) [snapback]524290[/snapback]</div> Quote:
does it do everything it claims? play lists, sterring wheel control, and can you still use your ipod when it's connected? what's the KB?? | |
Friends: 0 | <div class='quotetop'>QUOTE(berkley @ Oct 11 2007, 08:22 PM) [snapback]524314[/snapback]</div> Quote:
The firmware is user upgradeable, which I have done, though it did require me to buy a USB interface. Bob | |
| Member Join Date: Mar 2007
Friends: 0 | KB = knowledge base <div class='quotetop'>QUOTE(berkley @ Oct 11 2007, 07:22 PM) [snapback]524314[/snapback]</div> Quote:
Friends: 23 | <div class='quotetop'>QUOTE(berkley @ Oct 11 2007, 05:22 PM) [snapback]524314[/snapback]</div> Quote:
Yep. I only have 7 playlists though. You can control the volume, track, album, playlist via the steering wheel. The passenger can use the iPod directly if you wanted to and you can use the buttons on the dashboard as well. It shows (if you've labelled them correctly) artist, album in "DISC" and the song title in "TITLE" | |
| VAIS vs. DICE vs. Coastaletech | wmshax | Gen II Prius Audio and Electronics | 23 | 05-17-2009 08:15 PM |
| 2007: VAIS or DICE ? | Sillyboy | Gen II Prius Audio and Electronics | 11 | 03-07-2007 07:55 PM |
| DICE vs Vais + Lockpick 3? | pkittie | Gen II Prius Audio and Electronics | 1 | 01-04-2007 02:50 PM |
| would this be better then DICE or VAIS? | chuckieland | Gen II Prius Modifications | 7 | 08-12-2006 07:49 AM |
| DICE or VAIS? | dlester | Gen II Prius Audio and Electronics | 1 | 07-15-2006 09:00 PM |
