This is a discussion on Change Time in Nav System within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hopefully this is not something painfully obvious that's going to make me feel really stupid.... I changed the time on ...
Old 11-05-2007, 06:40 PM   #1
njnick
I changed the time on the small LCD Clock with the Daylight Savings Time change this past weekend, but when I use the nav system, the Time To Destination is showing an hour off. So if I should be arriving at 5pm, it's showing 6pm. Is there a place in the Nav setup to change this? The DST setting is set to ON.
I didn't know if it pulled the time from the LCD clock, or it was set independantly.
I'm one of those anal retentive people that will really get driven crazy by this.....
Thanks in advance!
njnick is offline
Old 11-05-2007, 08:28 PM   #2
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
Time zone and DST adjustments for the NAV system are accessible from the "Set Up" menu.
IsrAmeriPrius is offline
Old 11-05-2007, 09:09 PM   #3
njnick
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Nov 5 2007, 08:28 PM) [snapback]535192[/snapback]</div>
Time zone and DST adjustments for the NAV system are accessible from the "Settings" menu.
Thanks for the reply, but I don't need to change the time zone or the DST settings, just the time
njnick is offline
Old 11-05-2007, 09:13 PM   #4
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
<div class='quotetop'>QUOTE(NJNick @ Nov 5 2007, 07:09 PM) [snapback]535206[/snapback]</div>
Considering it's now standard time, I do believe you DO have to change the DST settings to "OFF"
Tideland Prius is offline
Old 11-05-2007, 09:49 PM   #5
alanh
Set DST to off and that should fix it.
The time on the Nav comes from the satellites, but that only gives GMT time. You still need to specify a timezone and DST status. In theory the unit could adjust for DST, but it would probably be wrong anyway due to the recent changes in the US DST start/stop dates.
alanh is offline
Old 11-07-2007, 07:32 PM   #6
Rest
Anyone know how to change the Bluetooth Call Log time? Mine is showing 3 hours ahead of the actual time calls were completed. Where does this time stamp come from? It doesn't appear to come from the NAV system, as that time is showing correct. Our Cell Phone's call logs are showing the correct time also, so I doubt the time stamp comes from the phones or our service.
Rest is offline
Date and time change not synced outside of Eastern Time? aforkosh PriusChat Website Questions 7 11-04-2009 12:58 PM
Anyone know how to change the time in the NAV system? pbeaule Gen II Prius Audio and Electronics 10 11-06-2007 06:40 AM
Gasoline use up 2.8% since early time change hb06 Gen II Prius Fuel Economy 6 04-08-2007 10:54 AM
Time Change Tlyke1983 Gen II Prius Care, Maintenance and Troubleshooting 3 11-10-2006 05:08 PM
TIME CHANGE??? DaveinOlyWA PriusChat Website Questions 16 04-16-2004 01:15 AM
