| This is a discussion on Speed Sensor Defeat Update within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by efusco No updates guys. Wayne has told me he hasn't forgotten, but he's not very motivated to ... |
| | LinkBack (40) | Thread Tools |
| | #91 | |
| Senior Member Join Date: Sep 2007 Location: Central Florida
. Any way he can have B/T if he has the right phone and a car kit to match. Hope Wayne gets hot as we generally use the wifes car for long trips and it is a pain!
__________________ Every Government interference in the economy consists of giving an unearned benefit, extorted by force, to some men at the expense of others. Ayn Rand. 2007 Classic Silver / Package #2 2008 Silver Pine Mica / Package #6 | |
| | #92 |
| Just another Onionhead Join Date: Mar 2007 Location: Texas
My Car: 2007 Prius Model: Package: #3 Thanks: 5
Friends: 0 | Thanks to all who've gone before, I've finally been able to install the BT defeat switch with relative ease. I used this SPST switch from RadioShack. No need for soldering. Just used two flat F-connectors to connect my zip cord to the two poles on the switch. At the other end I used bullet connectors for the cut wire to make it easier to reconnect it later if needed. I installed the switch between the SKS and Tire Sensor buttons to avoid having to drill any holes. The switch is a little wider than the precut hole, but nothing a sharp hobby knife couldn't rectify. I also discovered that the panel removal tool is excellent for prying the A/C panel out. And it's helpful to open both upper and lower glovebox to give yourself more room to work. Since my car doesn't have Nav, this is all I need. For a car with Nav, I'd imagine a DPST switch in that same location would do the trick very nicely. I can't believe I hadn't done this mod earlier. My wife and I carpool and we take turn driving. This will make our driving experience a lot better (and safer too.) Last edited by zenMachine; 05-03-2008 at 04:15 PM. |
| | #93 |
| Junior Member Join Date: Mar 2008 Location: Oak Park IL
My Car: 2008 Prius Model: Package: #3 Thanks: 0
Friends: 0 | I'm not quite sure what the point of the switch is? I just cut the speed wire ( left enough wire on either side to splice togehter when ready to sell) and left it like that. This way the phone, MP3 detail and FM message info is always on. Why is a switch needed to see 5' consumption bars and the wheels turn? Also, the install is much easier and faster - just pop off the center speaker grill and cut the wire. I don't mean this to sound like it's dumb to add a switch, I'm just not sure what it's for. |
| | #94 |
Friends: 0 | I suppose if you don't have Nav then a switch just for the BT is not as necessary. For me, I prefer the ability to keep the original functionalities intact. If I need to take the car to the dealership for service, for instance, I don't want them to see that something is "wrong" with the car... |
| | #95 | |
Friends: 37 | Quote:
1) NAV speed sensor--clearly necessary as the NAV computer will, after about 30 seconds, detect that you are moving from the GPS signal and will re-gray out the NAV buttons. You have to use the switch to 'reset' to speed sensor sensing and then disable to 'buy' another 30 seconds. 2) BT speed sensor--I like seeing my consumption bars and the wheels turn...just feels normal. But other than that there's no reason you have to put in a switch. In fact I don't have one since I have a circuit that allows me to use the steering wheel controls to disable and enable the speed sensor.
__________________ Evan E. Fusco, MD "It's a damn poor mind that can only think of one way to spell a word." -Andrew Jackson ![]() ![]() | |
| | #96 | ||
| | #97 | |
| Junior Member Join Date: Mar 2008 Location: Florida
Friends: 0 | I also tried the speed sensor "cut wire" approach" for NAV freedom to program while driving. It works, but there are some draw backs. While you are progamming the NAV, the map stops updating your position as you drive along UNTIL you flick the switch back to recreate the factory mode. The longer you program you NAV while driving, the farther off your map will be from your actual location. One time, we had diven so far that the map was "lost" and was not able to figure out our current GPS location until we shut the car off for 30 minutes. If anybody has another explanation for our observations, please post ! THANKS Quote:
| | #98 | |
I can't see any reason the car would need to be off for 30 min. I've used both the speed sensor wire cut method and the "Easter Egg" method available for those of us with an '06 or earlier and at no time have I gotten more than a few hundred yards off my course before the GPS 'found' me and got me back on the map accurately. | |
| | #99 |
Friends: 37 | I used to have a copy of the circuit design, I think there were only 2 or 3 of these ever built...one of which I have. It's a very very sweet way to use the BT (and nav, but I already had my Nav work around so just opted for the BT circuit). But it was labor intensive to build. Not sure why Coastal hasn't done something like this by now. |
| | #100 | |
| Senior Member Join Date: May 2004 Location: Silicon Valley
Here's the schematic of the BT speed sensor auto defeat in case anyone wants to build one: http://www.wb5mrn.com/prius/bt_only_schematic.jpg | |
| defeat, sensor, speed, update |
| disable speed sensor on '07? | indytrailmike | Gen II Prius Main Forum | 3 | 10-08-2007 10:49 AM |
| MFD Speed sensor wire? | Winston | Gen II Prius Audio and Electronics | 4 | 06-25-2007 02:31 PM |
| Bad Speed Sensor | thorn | Gen II Prius Care, Maintenance and Troubleshooting | 18 | 05-06-2005 10:29 PM |
| How To: Nav System Sensor Defeat - Use Nav while driving | dsm42 | Gen II Prius Audio and Electronics | 5 | 09-12-2004 09:31 PM |
| Phone/speed sensor mod. Where are the easiest instructions? | Steve Goldenberg | Gen II Prius Audio and Electronics | 4 | 09-02-2004 11:36 AM |
