This is a discussion on Speed Sensor Defeat Update within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by brosnan Here's the schematic of the BT speed sensor auto defeat in case anyone wants to build ...
LinkBack (40) Thread Tools
Old 05-28-2008, 07:11 PM   #101
ufoPilot
ufoPilot's Avatar
Default Re: Speed Sensor Defeat Update
Originally Posted by brosnan View Post
Here's the schematic of the BT speed sensor auto defeat in case anyone wants to build one: http://www.wb5mrn.com/prius/bt_only_schematic.jpg
If anyone wants to build these, I'm sure we could set up a group buy. I would be first for sure!!!!
ufoPilot is offline
Old 05-29-2008, 07:39 AM   #102
lordbah
Has there been any effort at defeating the BT/nav lockouts by patching the software?
lordbah is offline
Old 06-03-2008, 06:03 PM   #103
stevie_tech
I have been trying to decide on the best way to do this mod with the functionality I want. I'd like to condense it to one switch which will be installed next to my interior lighting dimmer. The functions I'd want would be to have both the NAV and BT circuits broken, the NAV on and BT off, and both on. I'm not too familiar with wiring, but I'm curious if a DPDT w/ center off (On-Off-On) would work. Basically, the bottom position would be NAV on/BT off, the center would be both off, and the top would be both on. Any takes on if this is possible?
stevie_tech is offline
Old 06-08-2008, 01:09 PM   #104
got_prius?
Is it me, or are many of the links posted here (namely http://www.priuschat.com/forums/viewtopic....p?p=24399#24399) dead?
got_prius? is offline
Old 06-08-2008, 01:25 PM   #105
Turbogizzmo
Turbogizzmo's Avatar
Thought thats how everyone does it...you get the newer nav disc and inject it with the older patched firmware...I cant confirm because my Prii doesnt have nav but i see the discs out there
Turbogizzmo is offline
Old 06-08-2008, 02:53 PM   #106
chrisspaulding
sexy, high tech, fun
chrisspaulding's Avatar
Friends: 5
Just how would one 'inject' the older firmware? I'd like to do this rather than the switch option.
Thanks
chrisspaulding is offline
Old 06-08-2008, 03:30 PM   #107
Turbogizzmo
Thanks
Taken from a Tundra Forum:
Ok Guys, I heard it was impossible, but with enough research i was able to figure it out. I have been looking for a way to unlock the Navigation while driving without have cut wires or do anything too major. Well here it is, It took me a few tries, but I now can drive and have my wife enter a destination or do anything else that is locked normally when in motion.
Ok In short here is the process that I used. It is hybrid of a few others i have read.
You will need a dual layer DVD +R (I used Memorex) and DVD burner that can burn Dual Layer disks.
1. Get v6.1 NavDVD's out and make sure they are clean. If not, wash them with warm soap and water and use a soft towel to DAB the extra water away.
2. Make a folder on your computer called "v6.1" and copy the contents of the v6.1 DVD to that folder.
3. Download v5.1 loading.kwi and replace the one that is in v6.1 folder with this one. You can get the file here Override for Navi - v5.1 LOADING.KWI File [archive]
4. Download and install ImgBurn,( The Official ImgBurn Website )set mode to "Build" Select source and point it to the backup directory of the NAV disc that is on your hard disk (refer to steps 1-3). Tell it YES that it is the root directory for the image content.,
Verify that file system under the options tab is ISO9660 + UDF, and recurse subdirs.
Add the UDF label to name the disc under the lables tab.
Press button to "build" ISO image. Give it a name.
Use NERO or other software to burn image on to DVD+R DL disk with book type of DVD-ROM. Book type for nero can be set under "Choose Recorder", Options, Book type settings.
Test disc in NAV system without pulling power yet. The NAV system will be able to read all the data on disc and give you POI's and new locations. The updated disc is now readable.
5. Next you pull fuse or neg battery cable for the 5 min. Then re-attach. Nav should pull new firmware and boot.
Turn on the car, and perform the following on your Naviagtion.
6. Press Menu
(menu screen appears)
Press Volume
(volume screen appears)
Press upper left corner
Press lower left corner
(Service Menu will appear)
Press and hold Over Ride for a few seconds
NOTE: If you are unable to get the SERVICE MENU up w/ the above procedure, this means you are still running v06.1 firmware ... please disconnect your NEGATIVE BATTERY TERMINAL & let the car sit for about 5 minutes ... then reconnect. This will clear out the NAVI's memory & when it comes back on, it will have to reload the firmware from your newly burned DVD, then the procedure should work!!
The above process worked for me. I got most of my information from the below link. Good Luck
Old 06-08-2008, 04:22 PM   #108
chrisspaulding
Friends: 5
Taken from a Tundra Forum...
AWESOME
thank you for the good info!!!!
So, this was successful on your 2008? You have the new v7 software (like me)?
Old 06-08-2008, 08:49 PM   #109
Turbogizzmo
AWESOME
I dont have nav, Ive just helped others do it....
Old 06-09-2008, 02:53 AM   #110
ufoPilot
ufoPilot's Avatar
I live in a Mac world and wouldn't be able to recreate the DVD you laid out in your post. Is there any way you can make copies of the combined firmware, ect., and sell them? Or is this against rules that I am not aware of...
I'm sure there are many of us out there that would cherish a copy!!
ufoPilot is offline
defeat, sensor, speed, update
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-audio-electronics/394-speed-sensor-defeat-update.html
Toyota Prius - Softpedia Forum This thread Refback 06-12-2009 04:44 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 05-24-2009 05:21 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 04-14-2009 03:16 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 01-22-2009 10:17 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 12-02-2008 01:08 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 11-18-2008 12:35 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 10-26-2008 11:16 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 10-14-2008 07:13 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 08-22-2008 07:43 PM
Marc Abramowitz OS X Cisco VPN restart This thread Refback 08-19-2008 11:00 AM
Marc Abramowitz Marc’s Résumé This thread Refback 08-15-2008 02:08 PM
Marc Abramowitz Foo Fighter This thread Refback 08-15-2008 02:06 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 08-09-2008 12:10 PM
Marc Abramowitz OS X: How to resize an off-screen window? This thread Refback 08-07-2008 05:55 PM
Marc Abramowitz Resizing a QEMU virtual machine, partition, and filesystem This thread Refback 08-06-2008 10:11 PM
Marc Abramowitz Linux Kernel Development notes This thread Refback 08-04-2008 10:24 PM
Marc Abramowitz 123-menu.el This thread Refback 08-04-2008 10:22 PM
Marc Abramowitz CakePHP This thread Refback 08-04-2008 10:21 PM
Marc Abramowitz C++ tips This thread Refback 08-04-2008 10:20 PM
Marc Abramowitz Emacs for beginners This thread Refback 08-04-2008 10:20 PM
Marc Abramowitz Emacs This thread Refback 08-04-2008 10:20 PM
Marc Abramowitz Marc’s Résumé This thread Refback 08-04-2008 10:19 PM
Marc Abramowitz Emacs This thread Refback 08-04-2008 10:19 PM
Marc Abramowitz Python cheatsheet This thread Refback 07-29-2008 05:07 AM
Marc Abramowitz Editing .xpi files directly in Emacs This thread Refback 07-28-2008 06:40 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 07-22-2008 01:48 AM
Marc Abramowitz This thread Refback 07-21-2008 10:03 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 07-13-2008 04:51 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 07-11-2008 11:57 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 07-07-2008 05:29 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 07-05-2008 09:57 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 07-01-2008 06:27 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 06-24-2008 09:22 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 06-23-2008 01:27 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 06-19-2008 01:53 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 06-18-2008 12:25 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 06-13-2008 07:45 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 06-11-2008 09:01 AM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 06-08-2008 04:06 PM
PriusOnline.com • View topic - How do I enable navagation selection while I'm driving? This thread Refback 06-07-2008 11:08 AM
disable speed sensor on '07? indytrailmike Gen II Prius Main Forum 3 10-08-2007 10:49 AM
MFD Speed sensor wire? Winston Gen II Prius Audio and Electronics 4 06-25-2007 02:31 PM
Bad Speed Sensor thorn Gen II Prius Care, Maintenance and Troubleshooting 18 05-06-2005 10:29 PM
How To: Nav System Sensor Defeat - Use Nav while driving dsm42 Gen II Prius Audio and Electronics 5 09-12-2004 09:31 PM
Phone/speed sensor mod. Where are the easiest instructions? Steve Goldenberg Gen II Prius Audio and Electronics 4 09-02-2004 11:36 AM
