This is a discussion on Aftermarket stereo experience? within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I went with a package 2 since $1500 was a big price tag when all I really wanted from package ...
Old 08-12-2008, 05:19 PM   #1
CCC712
CCC712's Avatar
Default Aftermarket stereo experience?
I went with a package 2 since $1500 was a big price tag when all I really wanted from package 3 was bluetooth. I've considered getting DICE or VAIS with a visor bluetooth speakerphone, but now I'm thinking about adding an aftermarket stereo. Does anyone have a unit they installed and recommend? I mainly want two things: bluetooth and ipod/iphone integration.
CCC712 is offline
Old 08-12-2008, 08:17 PM   #2
GeoGeek
GeoGeek's Avatar
Default Re: Aftermarket stereo experience?
Sound-quality-wise, prepare to be underimpressed with the Prius. Feel good about the fact that you didn't waste your money on the "upgraded" JBL system, because almost everybody on this message board who has it is equally unimpressed with it as well.
The big sticking point with upgrading the Prius is that you need to keep the factory head unit in order to maintain the radio's interaction with the touch screen, steering wheel controls, and NAV/Bluetooth (if you have it). Therefore, most folks opt to upgrade the speakers & amplifier (and some add pre-amp equalization) and keep the factory head unit.
Unfortunately most of the easy solutions for adding bluetooth and iPod integration come packaged in new aftermerket head units.....but there are options that will allow you to add these features and keep the Prius factory head unit. Dice & Vais both make ipod integration units you can read about extensively here on PriusChat.
Bluetooth is trickier, but do-able...look into some of the Parrot units.
Good Luck!
2010 Blue Ribbon Metallic, Pkg. IV, Solar Roof "Griffin"
XM Satellite Radio
Diamond Audio D6 5.25" Components
JL Audio 10W3v3
More to come....
GeoGeek is offline
Old 08-13-2008, 09:20 AM   #3
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 36
I don't miss having the stereo controls on the MFD. The feautures on the aftermarket head unit more than make up for that loss.
F8L is offline
Old 08-13-2008, 12:55 PM   #4
CCC712
CCC712's Avatar
Which aftermarket head unit do you have? Alpine? Something else?
CCC712 is offline
Old 08-13-2008, 10:03 PM   #5
F8L
F8L's Avatar
Friends: 36
I used a Kenwood eXcelon KDC-X791. You can find the quick write-up I did by using x591 in a search. If I had known I would be later installing all this other super high end equipment I would have went with the X991 which is a great sound quality piece. Alpine makes a very nice headunit in the $500 range but like the X991, it is not really worth it unless you plan on a fairly high-end system.
I'm currently using the old Diamond Audio D9 7" comp. set, D9 800.2, D6 1500.1 and two D9 10D4s.
I was somewhat happy with the stock setup and just the subs and sub amp but the rest of the upgrades were definately worth the effort. Especially since the equipment was just sitting in storage. lol
The convenience of the aftermarket stereo is well worth losing MDF controls IMO and makes switching media sources (iPod, USB, Aux) quite easy.
F8L is offline
Old 08-14-2008, 07:03 AM   #6
Lucky Stars
Gadgit Guru
Lucky Stars's Avatar
Can you post some pictures of the install?
Lucky Stars is offline
Old 08-14-2008, 09:09 AM   #7
F8L
F8L's Avatar
Friends: 36
HERE is the closest I have. The resistor wiring info can be found in a link on page #3.
I didn't take pics of the install because:
#1 I assumed everyone knew how to take the dash apart. I'm sorry
#2 I was in a hurry because I was doing this at work and had to help customers in between.
F8L is offline
Old 08-14-2008, 10:41 AM   #8
Bear68
Friends: 9
Just my two cents worth here... I have a Parrot CK3200L bluetooth added into my Tacoma and have installed the same units in a half dozen other models for customers, (including my Service Director's Prius) The Parrot unit (using an ISO to Toyota wiring adaptor) plugs directly into the factory wiring and into the radio head unit. The microphone is best mounted above the rear view mirror and running that little wire is the hardest part of the install. The kit also includes an ECU and a color screen that shows caller ID. It simulates factory bluetooth in that you hear the incoming call through the left front speaker and the radio is automatically muted when the phone rings.
Since you don't even have to cut the factory wiring, there is no chance of warranty issues with Toyota. Sound quality is quite good, and the nicest feature I noted is that with my Cingular/ATT Nokia phone, (the one they give you free with a contract) the phone book is updated every time I get into the vehicle. If I change a number during the day, it will be in my Parrot as soon as I start the engine.
Toyota Certified Master Diagnostic Tech, Prius Certified
"The only foolish question is the one left unasked."
Bear68 is offline
Old 08-14-2008, 11:40 AM   #9
jogquinteros
I bought a device called VisorTalk from COSTCO (works for me) its portable and I can take it with me to my wifes car or my Z. And if anyone has an iPhone I bought a Kensington LiquidAUX Auxiliary Car Kit with Remote, these 2 items are well woth it. I personally like to keep my cars stock and NOT tear into them. Mods are kool as long as they dont interfere drastically with the original design of any car IMO.
jogquinteros is offline
Old 08-14-2008, 04:44 PM   #10
CCC712
CCC712's Avatar
Where exactly does the parrot plug into? Can a parrot device and a DICE/VAIS coexist or do they use the same 12-pin port?
BTW, F8L - I really like your stealth setup, aside from aesthetics I like to keep things hidden and/or removable as theft is a big problem when you live in a city in the south and don't have a garage. My husband's car was broken into last year just because they saw an empty satelite radio dock on his dashboard. He was not stupid enough to leave the receiver itself in the car (or anything else of value) but we still had to pay to fix 3 of the windows and vacuum out tiny pieces of broken glass all over the car. Not fun.
CCC712 is offline
aftermarket, bluetooth, integration, iphone, stereo
2005 Prius aftermarket stereo install pdf. F8L Gen II Prius Audio and Electronics 12 02-09-2010 08:54 AM
Stealth install an aftermarket stereo in Prius F8L Gen II Prius Audio and Electronics 65 01-12-2010 10:03 AM
Aftermarket Stereo thegameispw Gen II Prius Audio and Electronics 2 07-12-2008 10:37 AM
Problem with aftermarket stereo install. F8L Gen II Prius Audio and Electronics 3 10-16-2007 02:15 AM
Standard Stereo vs Upgraded JBL Stereo blulou Gen II Prius Audio and Electronics 11 11-02-2006 03:09 PM
