This is a discussion on 2008 Prius Amateur Radio install.. within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 2008 Toyota Prius, it's a lease so no holes allowed... Here's the what we started with. I custom fabbed this ...
Old 08-31-2008, 04:00 AM   #1
grinthock
Default 2008 Prius Amateur Radio install..
I custom fabbed this bracket, it's made with 1x1 .090 wall square tube and some 3/16 flat stock. it is held down with 2 #12 bolts that normally also hold the centre console in place -- very sturdy.
and here's where we ended up...
Drawers in the back under a cargo cover in hidden box.
Up front.... Still a LITTLE bit of clean up to do.. but it's pretty much there..
Full gallery at this link... Prius Radio Install - a set on Flickr
Justin - Toronto, Ontario Canada
Amateur Radio Operator VE3UDP/VE3SIP
2008 Prius "E", NAV, SKS, Silver, Loaded
1996 Dodge RAM 1500 - Search and Rescue Truck
2009 Can-AM Outlander 650 MAX
1984 Honda Shadow VT500
grinthock is offline
Old 08-31-2008, 04:52 AM   #2
Ogo
Prius Owner since 2008
Package: Sol
Default Re: 2008 Prius Amateur Radio install..
Nice.
You take the energy directly from 12V battery?
73 de S56OA
Ogo is offline
Old 08-31-2008, 07:31 AM   #3
Guy in WNY
Guy in WNY's Avatar
Very Nice!
I'm just using the lighter plug and a mag mount; the V/U rig is just loose on the back seat on styrofoam. I don't adjust my radio while driving.
I've read on here that HF rigs don't work well in the Prius - is that so? It sure seems that you don't have any problem with QRM?
Guy
73's KC2PMM
Guy in WNY is offline
Old 08-31-2008, 09:43 AM   #4
grinthock
Power is coming direct from the on board Gel Cel in the rear. TX'ing with both at the same time would probably be a bad idea from a power draw perspective --- but the way I see it -- if the electrical system of the car can't support 8A of extra draw, then the car is running too close to the threashold you know?
No HF -- Top radio is a VHF 136-174 Motorola Astro Spectra W4
bottom is a UHF 430-470 Motorola Astro Spectra W4
I havn't done much driving yet -- but I can tell you that Motorola's are VERY Selective when it comes to RF, and they are used in vehicles that have lots of RF noise.
Old 01-29-2009, 11:38 PM   #5
grinthock
It's been a few months since I completed this install.
Everything is working swimmingly. The antenna's leave a bit to be desired that's for sure - they are unity gain at best, but considering 90% of my operation is urban repeaters with occasional simplex it seems to work just fine.
I use the top radio to monitor a few public safety systems and it does a swell job at that.
So far no problems - as for power draw - not a problem.
Zero RF noises, however like I previously stated, the Motorola's are probably the most selective radios manufactured, I have never picked up any RF noise.
Old 04-13-2009, 12:15 PM   #6
Ogo
Package: Sol
Here are a few photos of my Amateur Radio install in 2008 Prius:
Kenwood TM-D710 display/controller in front:
And main part of machinery is neatly hidden in boot area:
To prevent discharge of 12 V battery, PowerWerx's APO3 is being used:
Little magnet dual band antenna and GPS receiver on the top of the car:
Separation cables are running on both sides of the car. On the left side I installed head/display separation cable and GPS cable, and on the right microphone and speaker separation cable is running. Everything neatly hidden.
Hardest part was drilling few holes into plastics for Kenwood's speaker install as supplied Kenwood's self tapping screws miss the self tapping part of tapping.
73 de S56OA - Ogo
Ogo is offline
Old 04-13-2009, 03:22 PM   #7
Inches
Inches's Avatar
Very nice guys!! I want to mount an IC-706 but have yet to figure out the antenna issue. My main interest is 10 meters but may stick a VHF/UHF on as well.
Inches is offline
Old 04-14-2009, 09:31 AM   #8
joshuaareed
Justin(grinthock) I was wondering if you could share the measurements with us so that I may make a similiar mount like yours. I would really appreciate it.
joshuaareed is offline
Old 04-16-2009, 06:03 AM   #9
jeteyenite
Grinthock,
How did you manage to connect the antena on the roof to inside? I am assming that you did not cut anything... Don't you get rain inside? I am thinking about putting my gps receiver on the roof too.
thanks in advance...
jeteyenite is offline
Old 06-10-2009, 06:50 PM   #10
grinthock
Awhile since I was on here, and a few have some questions
first: Antenna... I am using 2 Glass Mount antenna's on the rear quarter windows - my intention however, is to go with a mount that re-utilizes the rear hatch gas shock bolts...
Second... Regarding dimensions...
I am sorry I did not measure it when I built it - I could - but I would have to remove the centre console, and get in there, and I would rather not rip the radio heads off, remove the console, because it's all in there rather tight and proper...
However maybe pics at this link will help you..
http://www.flickr.com/photos/grintho...7607028753613/
2008, amateur, install.., prius, radio
Amateur Radio in a Prius lytthans Gen II Prius Main Forum 8 02-08-2010 01:24 PM
Amateur (Ham) Radio ? SKPLLC Gen II Prius Technical Discussion 8 07-26-2008 11:01 AM
Quick install question Sirius install into 2008 darkslide750 Gen II Prius Audio and Electronics 1 01-12-2008 11:38 PM
Satellite radio install on 2005 Prius barefootmatt Gen II Prius Audio and Electronics 8 01-18-2007 10:36 PM
Solara Sirus Radio install in Prius danoday Gen II Prius Audio and Electronics 5 06-02-2005 03:23 PM
