This is a discussion on I got it! "I agree" killer! Cheap, easy, but... within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Yes, a backup has been done, using a full DL copy. (Not by me, by someone else). It works well. ...
Old 01-03-2005, 12:49 PM   #31
naterprius
Default Re: I got it! "I agree" killer! Cheap, easy, but
Yes, a backup has been done, using a full DL copy. (Not by me, by someone else). It works well. Must have been +R, since there is no -R DL spec.
Nate
naterprius is offline
Old 01-03-2005, 01:40 PM   #32
tag
Super Moderator
tag's Avatar
I backed up v3.2 and v4.2. Both backups worked fine with Verbatim DVD+R DL media burned with DVD Decrypter. Other DL branded media (e.g., Ritek), well, different results. YMMV, of course, but I'd recommend sticking with the Verbatim brand.
tag is offline
Old 01-03-2005, 03:04 PM   #33
DanMan32
Someone has posted here or on PriusOnline that they successfully created an SL DVD by only copying the file pertaining to their region, and creating dummy files for the remaining regions.
DanMan32 is offline
Old 01-03-2005, 04:08 PM   #34
rydot
I don\'t know if this is dragging the thread off-topic slightly, but I\'ll go down this branch anyway...
Would finding a way to remove the French-language audio "utterances" save a worthwhile amount of space?
rydot is offline
Old 01-03-2005, 08:26 PM   #35
tag
Super Moderator
tag's Avatar
I'm not at all sure about that. However, I noted, while perusing a circa 50MB file, that it contained both French and English. Thus, any space savings would require dissecting individual files (or at least one).
So, with regard to going the SL route, it would be infinitely easier to copy files for one region and create dummy files for the unused regions, as Dan mentioned. Actually, that same process could be done for each region so one could have all regions available but on separate SL disks. I haven't done the math but I believe it might be possible to fit more than one region on an SL disk.
tag is offline
Old 01-04-2005, 05:46 AM   #36
MashedPotato
Multiple regions will fit on a single-layer disk. I use a 4.2 disc that has regions 1, 2, and 3 on it.
I've tried three brands of -R and one +R. They all worked fine. I haven't tried any RW's or DL's.
The only trouble experienced was upgrading from 3.1 to a region-limited 4.2. The region was unexpectedly changed to one that had been deleted from the disk. I couldn't get out of the "problem reading DVD" message to switch regions back. (It's in another thread.)
<div class='quotetop'>QUOTE(xevious\";p=\"61074)</div>
I have quite a bit of experience with disc mastering; I'll take a look at the nav disc tomorrow and report any interesting findings.
Steven, in 3.1, I couldn't copy one of the files using conventional methods, so I create an ISO image of the disk, and used MagicISO to delete the unneeded regions' files from the image before burning. This worked, so I followed the same procedure with 4.2. (I noted, however, that the file that wouldn't copy in 3.1, does indeed copy in 4.2, so maybe the cumbersome ISO method isn't needed with 4.2.)
MashedPotato is offline
Override for "I Agree" on 2006??? GreenMeanie Gen II Prius Audio and Electronics 10 10-26-2007 09:15 AM
Putin joins OJ in search for "real killer" jared2 Fred's House of Pancakes 0 10-11-2006 12:43 PM
Free (sort of) "I agree" and NAV Override kit Rick Grahn Gen II Prius Modifications 13 09-08-2006 05:52 PM
DVD video and "I agree screen" question Escalade_on_22s Gen II Prius Audio and Electronics 2 04-11-2005 09:44 PM
Get rid off English/French or "I agree" screen pooja Gen II Prius Audio and Electronics 2 04-04-2005 09:18 PM
