| This is a discussion on aftermarket speakers w/o an amp within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Along with the sites F8L suggested, I would highly recommend checking out Basic Car Audio Electronics . It may be ... |
| | #11 |
| Has his homepage set to PC Join Date: Mar 2005 Location: Vancouver, BC
My Car: 2005 Prius Model: Package: B Thanks: 0
Friends: 3 | Along with the sites F8L suggested, I would highly recommend checking out Basic Car Audio Electronics. It may be called Basic, but there is a staggering amount of useful information there. |
| | #12 |
| Senior Member Join Date: Apr 2008 Location: Canada
My Car: 2008 Prius Model: Package: N/A Thanks: 2
Friends: 0 | Wouldn't the issue come up only if the new speakers have a different impedance rating than the OEM speakers? |
| | #13 |
Friends: 35 | |
| | #14 | |
Friends: 3 | Quote:
If the impedance of new speakers is lower than OEM, then you risk overheating/blowing the amp. If the impedance is higher, then the new speakers may sound quieter than OEM. I think the stock speakers (at least in the JBL) were 3ohms. | |
| | #15 | |
| Management Scientist Join Date: Feb 2009 Location: Denver Metro
My Car: 2006 Prius Model: N/A Package: #2 Thanks: 91
Friends: 5 | Quote:
I then added a Clarion 4-channel in, 5-channel out 500 watt amp (200 watts for the sub, 75 watts per channel times four for the cabin) and a 10" Rockford-Fosgate Punch sub in a small, down-firing enclosure. The change was dramatic. I now have great, well-balanced sound with excellent bass. good for anything from rock to jazz to classical. Hip-hop might be better with 2 of the subs, but it's certainly adequate. The key is in balancing the system (and, no, the bass "loudness" contour and sub volume knobs are NOT meant to be full up no matter what!). I've spent days tweaking the various controls on the amp, one at a time, then driving my 50 mile commute to evaluate the change. Make small changes and take time to see how they work on a variety of music. I'm not aware of any loss of mileage, but I'm not a hypermiler. Coupled with the Sirius radio add-on, everything is still controlled through the touchscreen (balance, fade, tone - to an extent, and sirius). | |
| aftermarket, amp, speakers, w or o |
| what aftermarket speakers do you have??? | coleman22 | Gen II Prius Audio and Electronics | 13 | 06-17-2008 02:16 AM |
| Where are the speakers? | WayneF | Gen II Prius Audio and Electronics | 2 | 06-04-2008 01:08 PM |
| Aftermarket Speakers Having Issues | Experimental | Gen II Prius Audio and Electronics | 8 | 02-11-2007 09:46 AM |
| Better Speakers? | genalex | Gen II Prius Main Forum | 2 | 09-01-2006 09:15 AM |
| Aftermarket radio and speakers. | Cosmo | Gen II Prius Modifications | 1 | 11-09-2005 11:21 AM |
