This is a discussion on non-jbl passenger seat subwoofer install/options within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; hi, so ive flopped back and forth and i think in have my solution. im pretty sure i wanna keep ...
Old 03-13-2009, 02:46 PM   #1
superjew1492
Default non-jbl passenger seat subwoofer install/options
hi,
so ive flopped back and forth and i think in have my solution. im pretty sure i wanna keep my stock system as is, just at the risk of messing things up. ive heard adding a sub can detract from the stock shortcomings. i was considering a sub/amp combo in the rear but the idea of an underseat install is starting to appeal to me. im considering these, as they are all i can find. not sure if they'll fit...but i think they will. ideally should i, for ease of install wherever i go, tap the front cig lighter power? since it is always on and i never use the front one. and where should i tap my audio? thoughts?
Kenwood KSC-SW10 Compact powered subwoofer at Crutchfield.com
Blaupunkt THb 200A Compact powered subwoofer 70-watt amp with an 8" sub at Crutchfield.com
Amazon.com: Boss BASS1200 10-Inch Low Profile Amplified Subwoofer with Remote Subwoofer Level Control: ElectronicsAmazon.com: Boss BASS1200 10-Inch Low Profile Amplified Subwoofer with Remote Subwoofer Level Control: Electronics
Amazon.com: Boss Audio BASS600 8-Inch Low Profile Amplified Subwoofer - Single (Silver): ElectronicsAmazon.com: Boss Audio BASS600 8-Inch Low Profile Amplified Subwoofer - Single (Silver): Electronics
and what will i need to install? some sort of line leveler?
thanks!
superjew1492 is offline
Old 10-07-2009, 09:29 AM   #2
Gaujo
Default Re: non-jbl passenger seat subwoofer install/options
I'm looking for the same info on the Base audio system, but for a trunk install instead of pass seat. I found a lot of old threads that reference attached pictures that are described as showing what we would need to know, but alas all of these pictures are missing! I will let you know what I discover, please do the same.
dead pics
Gaujo is offline
Old 10-14-2009, 04:08 PM   #3
sxotty
Package: #5 Touring
Hey guys what is under the seats? There is a large heat sink under the passenger seat with a box around it. I figured someone would have installed some Amps under the seat, but I am coming up blank. I read somewhere that the box under the drivers side is the DVD unit for nav system, but that doesn't explain the passenger side one. I didn't know if it was the factory JBL amp or something as that was mentioned to, but I would like to know for sure just what I am messing about with.
edit: I found this it answers some of my questions and maybe yours
http://www.tom-morrow-land.com/tests/priusaudio/
sxotty is offline
Old 10-14-2009, 08:06 PM   #4
Ophbalance
Passenger seat is the stock audio amp, i believe.
Ophbalance is offline
Old 10-14-2009, 09:53 PM   #5
PriusLewis
Management Scientist
PriusLewis's Avatar
Friends: 5
thanks!
There are existing threads on under seat self-powered subs being used (and at least one where it was placed in the back). I believe most of these self-powered units are designed with speaker-level inputs, since the manufacturers know they will most likely be added to a stock system. You can tap the wiring to the front speakers behind the kick panels. Here's a link to a .pdf telling how to replace the rear door speakers -what does that have to do with this? Simple! He includes a wiring diagram telling us what the colors are for the speaker wires that you will need to tap! Plus he's a PC poster!
http://members.cox.net/scott.sumners...20~sparky~.pdf
Here's a thread on the Boss BASS 8":
Boss BASS-600 8" powered sub
Another thread, this time about the Kenwood installed under the passenger seat:
Subwoofer Location?
OK, that's enough. Next time do your own searches!
Click the image to open in full size. Click the image to open in full size.
Bartlett leather, black Wheelskin, Infinity Reference speakers: 4 2-ways & 2 tweeters, 10" sub, Clarion 500W 5-channel amp, VAIStech SL2xmt XM, 30% tint, custom pinstripe/graphics. My pics.
PriusLewis is offline
install or options, nonjbl, passenger, seat, subwoofer
Seat belt beeping for passenger seat WWJD08 Knowledge Base Articles Discussion 3 09-13-2008 03:51 PM
Kenwood Subwoofer and amplifier install toddhata Gen II Prius Audio and Electronics 13 05-29-2008 11:04 AM
Adapting passenger seat to passenger with MD. Goolash Gen II Prius Modifications 4 05-22-2008 09:54 PM
Under seat subwoofer robertlee919 Gen II Prius Audio and Electronics 2 09-19-2007 04:51 PM
rear seat removal/wiring subwoofer install help please Prizzle Gen II Prius Audio and Electronics 8 05-23-2006 02:18 PM
