This is a discussion on Help! Son put Penny in CD Slot ! within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; My 2 year old recently put a penny in the slot loading CD player. It shorted the speakers and made ...
Old 04-02-2009, 08:47 PM   #1
nathanvoght
Default Help! Son put Penny in CD Slot !
My 2 year old recently put a penny in the slot loading CD player. It shorted the speakers and made a loud Zaap sound. I heard the penny rattle around a little more, and now I don't hear it. Any way to get the penny out to see if my CD/Radio system still works? Any help greatly appreciated...
nathanvoght is offline
Old 04-02-2009, 11:05 PM   #2
KK6PD
_ . _ . / _ _ . _
KK6PD's Avatar
Friends: 11
Default Re: Help! Son put Penny in CD Slot !
Well it's been my experience that the "ZAPP" thing is BAAAD, Egon!!!
First check the FUSE that supplies power to the radio/CD unit.
Look in your owners manual, it will point out the proper fuse location. If it's bad, replace.
But do so AFTER you get the penny out.
If your up to it, and want to try, taking the dash apart is fairly easy enough to do to get to the changer unit. From there it's a bit of more work to unplug and pull the changer. You then have to open the unit and retrieve the penny, and what ever else you didn't notice that was stuffed into the sot. While your in there, smell around for "That Burnt Electrical Smell" smell. it's quite distinct. If something let the smoke out, your gonna smell it!
If you don't sell anything, take a well light look around and see if you see anything that does not look right, I.E. Blackened Spots, Broken Gear Teeth on Gear Wheels, Pieces that are bent, but they should look straight. If it smells OK and looks OK, reassemble, turn the unit on and see what you get, Radio, FM, AM, load a CD.
Load OK?
Play OK?
If so, sigh a sigh of relief and unglue little Johnny out of the corner you stuck him in!!
On the other hand, if you smell the "The Smell" , or see broken teeth, it's usually expensive and a trip to Toyota, or someone you really trust is in order!
Hope you have Good Luck.
Just think, it could have been worse, it could have been a Peanut Butter Samich!!!
Let us know your results!!
73 de Pat KK6PD
KK6PD is offline
Old 04-03-2009, 12:12 AM   #3
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
Before you rip the dash apart, you could try a vacuum cleaner. A fresh bag and a crevice tool to increase the suction just might do the trick.
hyo silver is offline
Old 04-03-2009, 10:07 AM   #4
I suppose you could also turn the Prius on end and shake it. Sorry, I had to say that.
Old 04-03-2009, 01:29 PM   #5
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 11
Did it let the smoke out? Electronic stuff won't work anymore if you let the smoke out.
dogfriend is offline
Old 04-04-2009, 02:13 PM   #6
Inches
Inches's Avatar
There is always the coin return
Inches is offline
Old 04-05-2009, 08:22 AM   #7
HTMLSpinnr
Gen III Forums Moderator
HTMLSpinnr's Avatar
Friends: 18
Having been on a recent hunt for a CD changer for the 2002, I can say there's an abundance of used CD changers on eBay from salvage cars. Try them first if you're willing to tear into the car before making that expensive trip to the dealer.
In my case, I was able to "repair" my unit w/ a bit of superglue on the cracked gear. No penny, but my wife either got a CD stuck or forced it which cracked/broke the gear off of the eject roller spindle. Super-glued it back on (and filled the small split) and other than a clunk clunk clunk as it loads due to the one wider tooth, it works fine now. I'd imagine that even though the form factor is different, the guts will be similar in the 2004+.
Rick Johnson - Prius Expert/Gen III Forums Moderator
His: Gen III 2010 Prius - Blizzard Pearl Prius IV w/ Solar - 6.3k miles - (First in SW Region!) - 2010 Photos - Mods: Curt Hitch, Toyota Premium Horn, Illuminated Door Sills
Hers: Gen II 2004 - Tideland Green Pearl #9 - 117.6K miles - Mods: Bridgestone Ecopia Tires, Homemade mesh foglamp grills
Past: Gen I 2002 - Blue Moon Pearl - Mods: Costal hitch
I am not employed by Toyota, and the opinions expressed by me as a Prius Expert are not those of Toyota.
HTMLSpinnr is offline
Old 04-08-2009, 12:19 PM   #8
nathanvoght
Thanks, everyone, for the tips. No, I didn't see or smell any smoke. I'm hoping the penny is just making a circuit connection that is preventing sound, and that I can remove it safely. What I don't know how to do is take the dash apart to get at the CD slot loader/player. Does anyone have a link to instructions to do this??
Old 04-08-2009, 12:58 PM   #9
dogfriend
dogfriend's Avatar
Friends: 11
Try here:http://techno-fandom.org/~hobbit/car...ragon-dash.pdf
Old 04-08-2009, 03:35 PM   #10
nathanvoght
Thanks!!!
penny, put, slot, son
Leaving fob in "slot" when parked @ work JEFNLSA Gen II Prius Main Forum 10 04-11-2008 03:33 PM
PRIUS KEY POPPED OUT OF SLOT !! Cattaraugus Gen II Prius Main Forum 11 02-09-2007 05:05 PM
$50.00 Penny propking Gen II Prius Main Forum 3 01-31-2006 10:10 PM
